Thanks for this forum and all the good info here
I have this 8RDA+ that I have had since new , it would be close to 3 years old , and for a long time I was running a XP 2600+ mobile on it overclocked but lately have been running it standard , it has been running W2K/ Ubuntu edgy and I have had no problems with it . Just recently I noticed some of the caps were swollen , so I have pulled it out of service and have decided to have a go at recapping it .
I havn't had much success at this previously , probably because the m/b's I have tried to fix may have had other problems , but this one with the great instructions you give I will give it a go
Now there only seerms to be about 5 caps that seem to be swollen , but I will replace them all as it has been pointed out that is the best way if I want this board to last .
The thing I wanted to know is 4 of the ones that are swollen are 1500 uF@ 6.3v and they are 10mm x 20mm and the one that is also swollen on the end dimm3 at CE38 which I couldn't tell what it was until I took it off is also a 1500 uF @6.3v 10mm x 15mm , a bit shorter that the other 1500 uF @ 6.3v . Now would it make any difference if I kept all the 1500 uF @ 6.3v the same ?
I hope I have explained it properly and that you can understand what I have written .
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
