Trying to fix junked MicroStar - MS-6312.
Symptoms: / Problems / and questions.
* Will never turn on with the power switch...
* Let it sit for a minute,and it will come on by itself.
* Gets to "cmos setting wrong" press F1 or F10 etc. cause bios was reset.
CAN not press anything cause the USB keyboard does not work! Although it Does detect the mouse.
* Then it shuts itself off.... with a few power light glitches...
Is it only the capacitors or the power supply?
I see two capacitors that are bad looking.
"swoll up on top a bit" and a spec of the brown stuff on top.
In the top pic at the post below.
https://www.badcaps.net/forum/viewtopic.php?t=129
The two green ones at the top right are the ones that are bad.
Everything else looks ok.. although it looks like the power supply has been hot before...thats' what I was thinking that was wrong with it But It never got hot while it was on. But then I noticed that the two bad capacitors got really hot right before it shut off...
So, if I replace those two capacitors and it fixes it....
HOW am I even going to press F1 or F10 to reset the bios back up when the USB keyboard don't work? and of course this model of motherboard doesn't have a PS2 port. Has nothing but usb ports. and it only detects the mouse,which I can't click F1 with. lol What do I do?
I see an empty plugup hole with com1 on it.. maybe install a serial port and use a serial keyboard?
Thanks for any suggetions...
