MSI 6318 Ver:5
  • hakan_11
    • Jul 2006
    MSI 6318 Ver:5
    U42 chip sploilt, burn
    help me
    micro star 6318 Ver:5 mainboard block diagram and schema subject help any
    thanks
  • Taurus12
    Optiplex 3050 micro 2 blinks followed by 3 blinks issue
    by Taurus12
    Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
    I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
    i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
    Any recommendation on what I have to do next? Thanks in advance
    06-10-2025, 05:05 PM
  • tranquility
    Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
    by tranquility
    i want to repair an Onkyo TX-NR809 receiver.
    symptoms:
    on power on, display appears and i hear one click. enue functions is given.
    - no hdmi output
    - audio output not tested, but i think it is not there
    - usb sticks are not recognized
    if i read out the chips with display+standby button + tone+
    both dts show only ????
    chip is D830K013BZKB4
    things i have done:
    - reflow of the dts chip without taking off and reballing
    - changed the aluminium caps without the big one with 25v because i dont...
    08-25-2025, 01:04 AM
  • hs5424
    Dynacord powermate 1600 block diagram.
    by hs5424
    Hi All,
    I obtained a schematic diagram for the above mixer but I am wondering if a block diagram exists as I am trying to fix a problem in the protection circuit which I find a little confusing using a circuit diagram only. In the good old days the workshop manuals always had a block diagram with a circuit discription. Very useful for fault finding.
    The protection light is perminently on. The right sode has a -80DC on the feed to the speaker, hence the protection led on. I have removed all the O/P transistors which checked out OK. I tested all other transistors in circuit which seem...
    07-31-2025, 01:35 PM
  • Isabella91
    Possible to convert eMMC Socket to a micro SD Card socket?
    by Isabella91
    I have seen many posts where the eMMC can be read via a SD card reader, however can the opposite be achieved?
    Read/Write a Micro SD Card from an eMMC Socket.
    I have a Motherboard with a Kingston BGA153 ball socket, using HS400 bus mode, which is 8bit, as Micro SD is usually 1bit or 4bit mode, I accept that a loss of speed in read/write will occur, but I would sill like to convert.
    Theoretically speaking, Im thinking if I hard solder DAT0-3 from eMMC to SD Card Reader, this should force 4-bit mode, or only DAT0 to force 1-bit mode.
    Not to remove...
    01-14-2024, 05:10 PM
  • Stunt
    Dell Optiplex Micro 7010 Computrace
    by Stunt
    Device: Laptop
    Brand: Dell
    Model: Dell Optiplex Micro 7010
    Board : 212045-1
    S/T : 2RP6VX3
    Request : Computrace Unlock
    08-12-2025, 06:15 AM
