Asus P4P800-VM - NO post, no standby 5V, no 3.3V on PCI
  • retiredcaps
    • Apr 2010
    • 9271
    Got this Asus P4P800-VM recently.
    There is no standby power light on the board. There is also no 3.3V DC on the PCI slots.
    The transistor C5706 is shorted between B-C, C-E, and B-E. I'm used to seeing the shorted C5707 in Benq monitor boards.
    Here is a shot of the c5706 chip. It is sandwiched between the PCI slots and I'm not sure how difficult it is to desolder or even possible without destroying the surrounding chips. I thought about cutting off the legs (inner and outer) and just "stacking" a c5707 on top, but I can't fit my side cutters in between the PCI slots.
    Any ideas on how to remove this c5706 chip? I don't have a solder station, chisel tip, or liquid flux to remove the tab. If this is removable with proper tools and technique/skills, then I'll try to find someone else to remove it.
    --- begin sig file ---
    --- end sig file ---
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Asus P4P800-VM - NO post, no standby 5V, no 3.3V on PCI
    Another mysteriously dead ASUS :-(
      master hoarder
      • May 2008
      • 12170
      • Bulgaria
      I think it should be do-able with a regular iron. Just preheat the area around the transistor with a hair dryer or heat gun to make it a little easier to desolder it (don't make it too hot, though - after all you want to be able to hold the board). It may also be helpful to remove that green LED so it's out of the way.
      Not really. It has a dead transistor and a OST RLP cap next to it. When you use such fantastic components, you ought to get fantastic results .
      • severach
        • Aug 2007
        • 1055
        Removing that transistor takes less than 30 seconds with hot air in one hand and an iron in the other. No parts will be bumped off and the PCI slots won't be damaged. It comes off in good shape so you can test and reattach as necessary.
        It can also be removed with two irons and two people. Unfortunately since neither of you will be any good at soldering and won't know how much heat needs to go where, it will be like two bulls in a china shop. The legs will be bent, pads ripped off, and nearby parts will be dislodged. Many of the nearby parts are too small to reattach without hot air. Very small parts like C135 next to the skyscraper are difficult even with good equipment.
        sig files are for morons
        • c_hegge
          • Sep 2009
          • 5219
          It's no mystery at all. It's just got the ASDS (ASUS Sudden Death Syndrome)
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            looks like u31 on the left edge got wet.
            • c_hegge
              • Sep 2009
              • 5219
              Good find. I didn't notice it.
              • retiredcaps
                • Apr 2010
                • 9271
                I did notice that after I looked at my photo.
                The person who I got this from said it wouldn't power up one day and then it was put away for about 10 months (presumably somewhere inside their house) before I received it. The person didn't say anything about power spikes or spilling any liquids on it.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  it was live when it got wet.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    I desoldered the OST RLP cap (1000uF 6.3V) next to the c5706 since that is I all I can do for now. It read 1013uF on my multimeter. I don't have an ESR meter so I don't know the value.
                    • Phaihn
                      • Jan 2009
                      • 842
                      would you like the board i have?
                      i think it just needs new bios chip.. can use the one in yours.
                      My Computer.
                      AMD APU A4-3300 2.5ghz 1mb cache
                      Motherboard GigaByte GA-A75M-S2V
                      Kingston HyperX Blue DDR3 8GB (2x4GB)
                      SB Audigy 2 ZS [B800] Sound Card
                      500GB WD Caviar® Blue™
                      1 Terabyte WD Caviar® Black™
                      2 Terabyte WD Caviar® Black™
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        I appreciate the offer, but the cost of shipping the board to me would probably be in the $10 to $15 range which makes the board economically not feasible considering I can buy a complete used 3Ghz P4, 1GB DRAM, hard drive, power supply for about $30.
                        However, I can ship you the bios in my board if you want. This assumes I can remove it without destroying it AND it is good (I don't know if it is or not). Shipping this small chip should be way cheaper than shipping the board.
                        • Phaihn
                          • Jan 2009
                          • 842
                          ok.. so your not going to try to replace that part after all?
                          My Computer.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            I have a whole pile of other projects in front of that board. Tell me the best way to remove that bios chip. I have no extractors other than a screwdriver.
                            • Phaihn
                              • Jan 2009
                              • 842
                              theres a tool you can get or you can use a very small screw driver and pry both corners a bit at a time..
                              http://www.bioschip.com/remove_dip.html
                              My Computer.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                Did you try a bios recovery as per
                                http://www.biosman.com/biosrecovery.html
                                Bios at
                                http://www.asus.com/Motherboards/Int...00VM/#download
