Dell Optiplex GX280 no boot and fan going crazy
  • BigTroll
    • Sep 2010
    • 1317
    • LAMBDA SOND
    #41
    Re: Dell Optiplex GX280 no boot and fan going crazy
    my gx280 ate a power supply last month, i was using it and it just shut off, trying to turn it back on it would come on a sec then go out. so i just swapped in another untouched psu, the odd thing is that when put to a psu tester it passed, but they don't really put a load on them so probably bad caps.
    My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
    • FMFDoc
      • Sep 2012
      I have two of these I am troubleshooting with a run away fan and no boot. One I changed the bad caps with no change so I broke out my meter. What I have found is there apears to be a short in the circuit that the caps and transistors (attached to the big heat sink) are in. If I measure across the caps I get an instant and steady 2 ohms, same with two legs of the transistors. The other board has the same readings. Anyone every see this?
      Searched for schematics online but no luck.
      • FMFDoc
        • Sep 2012
        Forget my previous post. Did not realize one board had a cpu and one did not when I was ohming. Put cpu in the good board and caps read like a short (2 ohms), same as the bad board...
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Originally posted by severach
          GX280 turbo fan syndrome on a normally working system is often caused by the PCIe VGA card pulling out just a bit. Reseat it.
          Reseat the RAM! My Inspiron 530S does stuff like that and traced it to finicky RAM slots!
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • Arpajon
            • Oct 2013
            • 14
            Originally posted by JayArr_BC
            We've repaired over 50 Dell boards, 270s, 280 and 745s that have what we call "runaway fan"
            I was able to talk to JayArr_BC on the phone last week about reflowing these boards. I have a couple dozen and, at present, my buddy who does my recapping is too busy to try reflowing one of these 280s. I thought I might check here to see if anyone stateside had any experience fixing these.
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              #46
              I haven't tried it as I haven't repaired enough of these systems to say... but I wouldn't be surprised if bad BGA for the Northbridge and/or Southbrdige is the cause for the "Turbo fan" syndrome. After all, I know for a fact that the GX270 and other Dells of that era tend to have quite hot-running NBs. In addition to that, the motherboards usually also have a hot regulator or two, typically located near the NB or SB. So again, I'm not surprised if some of them do need a relofw. But keep us posted what you or your friend finds, and particularly what chip needs reflowing. I still see GX270 and 280 systems every once in a while in medical offices and whatnot. These systems are workhorses despite the bad caps.
              • jiroy
                • Jun 2016
                • 2416
                • Lebanon
                #47
                I've been through lot of Optiplex and what i can say , they are very sensitive to their Original Cpus and even Fans . Once i was offered one working board because its owner tried to use another type of fans and it wouldn't boot . A very stubborn and sensitive bios they have , and that include Memory sticks if older than two or three years . Resetting memories isn't a perfect solution , just a small turn around for the next trouble . Better replace them with Dell's ones if available .
                And yes , the North and South bridges always get hot .. For my units , not intended for sale , i used to add a small fan as initial precautions at the very first time bought , and therefore extending their life's expectancy . Fact is i preceded Dell in putting heat sinks on south bridge , and maybe if they didn't succeed in going down in microns , we would see fans on the North bridge too . You can say that those fans were also precedent precautions to prevent reflowing issues ..
                Bad caps were also very frequent in those boards especially the big ones ...
                • mpower1226
                  Dell optiplex 7090 boot problem
                  by mpower1226
                  Hi masters, need your help in solving this mystery.
                  i have a dell optiplex 7090 micro that i bought from local kijiji.
                  when i turn it on, error comes out saying no hard disk.
                  i go to bios to check the boot option, only httpboot shows. If i try to add boot option, it only shows file search but nothing happens when i click.
                  i took out the ssd and put it into old laptop and format and installed the windows 10 and put it back into the desktop. It boots up and same error again no hard disk.
                  it seems as if the computer doesnt recognize the ssd...
                  01-22-2024, 10:37 PM
                  DELL OptiPlex 5060 OptiPlex 5000 i5-8500 Specification for Upgrade or Repair
                  This specification for the DELL OptiPlex 5060 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 5060 boardview and OptiPlex 5060 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                  09-12-2024, 03:44 PM
                  DELL OptiPlex 3060 OptiPlex 3000 i5-8500T Specification for Upgrade or Repair
                  This specification for the DELL OptiPlex 3060 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3060 boardview and OptiPlex 3060 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                  DELL OptiPlex 5070 OptiPlex 3000 i5-9500T Specification for Upgrade or Repair
                  This specification for the DELL OptiPlex 5070 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 5070 boardview and OptiPlex 5070 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                  DELL OptiPlex 3040m OptiPlex i5-6400T Specification for Upgrade or Repair
                  This specification for the DELL OptiPlex 3040m can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3040m boardview and OptiPlex 3040m schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
