Repairabilty of an old GTX660Ti nvidia gpu...?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    I salvaged an old GTX660Ti but found out perhaps why it was dumped: it's not stable.
    It boots fine, runs fine, but under heavy GPU load it works for a minute, but then artifacts up and hangs the machine. Sort of implies a heat issue but it's too consistent, crashes the same way though hard to predict exactly when it will crash, but crash it does.
    This isn't exactly my first experience with dying video cards, though my RadeonHD 3650 and GeForce4 MX420 had a similar fate, but it has artifacts from bootup and truly unusable. Then there's the RadeonHD 5770 that won't let the computer even boot.
    Is this nvidia card worth trying to see if it's possible to stabilize or is it ready for the dump as well? It's too bad, this thing should be significantly faster than any other video card I've ever had...
    BTW the first thing I did was blow out dust from its HSF. It didn't seem way too dusty however, so dust clogs shouldn't have been the problem.
    Last edited by SMDFlea; 09-12-2023, 02:05 AM. Reason: Added "an old GTX660Ti" to thread title
    • 31214
    Re: Repairabilty of a nvidia gpu...?
    any non-polymer caps on it?
    and dont overlook a failing ram.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Don't think it's ram, the way it fails is very consistent, just don't know when.
      I haven't pulled the plastic air guide (course it's a double slot) so unsure of capacitors yet.
      I tried bumping up the fan speed and didn't seem to help, still crashed. Forcibly reducing frame rate seemed to increase time between failures but this is only good on simple scenes... on dynamic scenery I may even have to reduce the frame rate to below that of my ATI R7, which of course means that I'd be burning more power to get fewer FPS - the R7 doesn't even need a direct connection to the PSU!
        • 31214
        you need to strip it down, who knows what you may find in it!
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Looks like all polys... as usual there's never an easy fix ...
            master hoarder
            • May 2008
            • 12175
            You can use GPU-Z or MSI Afterburner to watch the temperature as you put load on the GPU... though it's probably best to just remove the heatsink and check on the thermal compound. If it's dry, that might have broken the GPU already. And even if it's not dry, chances are the GPU chip is on its way out... or possibly the RAM. But with older cards like these, it's usually the GPU.
            Easy "fix": give it a reflow and cross your fingers. If it does get "fixed" by this, make sure you keep the running temps nice and low. This should / could prolong the "fix". Aim for load temps under 50-55C... though I can tell you for a fact that this won't be possible with the stock cooler. So either you'll have to limit FPS / power draw or use a much bigger cooler (or water cooling if you have it?)
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              Unfortunately GPU-Z and MSI Afterburner don't quite work in Linux I don't think? nvidia-drivers does however have a utility to track temperature though tough to monitor it as it gets corrupted when it crashes.
              Need a way to underclock this thing perhaps...
              • ribcage
                • Sep 2020
                • 45
                • Earth
                Re: Repairabilty of an old GTX660Ti nvidia gpu...?
                First run mats/mods to see if a memory channel is bad, then try https://gpuzelenograd.github.io/NVIDIA
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  hmm...the whole linux GPU scene is a royal mess IMHO, probably mostly because GPUs are so different from each other and there's no way to support them all in a unified manner. I did run across the vulkan memory tester but not sure what is needed to support vulkan and which of my cards support it or not...
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    I just tried nouveau on this card...while no artifacts, it still crashes -- but Nouveau seems to kill the X server when it gives up and I can just login again.
                    However nouveau seems sllllloooowwwww... at least for the benchmarks I tried. Perhaps I set it up wrong, need to check it again.
                    And eiew. binaries. that depend on systemd. eiew. my sysvinit system does not approve.
                      • 31214
                      neuv' as far as i know has no hardware acceleration becaese NV wont opensource the drivers or internal register/commandset info.
                      • piernov
                        • Jan 2016
                        • 4437
                        • France
                        nouveau cannot change the clocks from their boot time defaults in a lot of cases, so you are stuck at like 200 MHz instead of 1 GHz of core frequency. This can also explain why there can be "less issues" running a dying GPU (or VRAM) with nouveau.
                        Even when it can do it (this GPU being a Kepler it may work), it does not do it automatically and you need to change power levels manually. Even with that, you cannot expect to perform as good as the closed-source Nvidia driver.
                        • piernov
                          NVidia bumpgate
                          by piernov
                          Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                          Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                          May complete this post at a later date with more details.
                          Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                          03-27-2021, 10:34 AM
                          NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                          The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                          10-02-2024, 08:52 AM
                          NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                          The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                          10-02-2024, 07:51 AM
                          NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
                          The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
                          10-01-2024, 01:54 PM
                          HP ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) ProDesk 400 i5-6500 Specification for Upgrade or Repair
                          This specification for the HP ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) boardview and ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                          09-12-2024, 03:30 PM
