No Vcore on GTX 1050 Ti
  • ilod
    • May 2020
    • Israel
    Hi, I got a Gigabyte GTX 1050 Ti that may or may not have suffered some water damage (a lot of corrosion on the shield and the ports, but not as much on the board itself, which I cleaned). The card has no shorts that I can find on any of the rails but is not detected. I have 12v, 3.3v, 5v, 1.8v, pex and Vmem, but not Vcore. However, the core do get a little hot when I turn on - not to much, I can safely touch it. Obviously no voltage on the main coils. How should I proceed? I'm not sure about the proper way to test the mosfets for shorts because of the very low resistance on that card. I've attached board file and schematics for reference as my board is a little difference revision (no external 12v connector, for example).
  • vcaina
    • May 2023
    • 12
    • Philippines
    Re: No Vcore on GTX 1050 Ti
    Hi ilod, you can try measuring the gate on diode mode red probe on ground. You should get around 0.4-0.7 voltage drop on them. If you find an odd mosfet, try to then measure the gate in resistance mode to see if it's a short. Just my 2 cents.
    Not a professional advice
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
      NVIDIA GeForce GTX 1050 Ti Schematic & Board View
      The GeForce GTX 1050 Ti was a mid-range graphics card by NVIDIA, launched on October 25th, 2016. Built on the 14 nm process, and based on the GP107 graphics processor, in its GP107-400-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 1050 Ti. The GP107 graphics processor is an average sized chip with a die area of 132 mm² and 3,300 million transistors. It features 768 shading units, 48 texture mapping units, and 32 ROPs. NVIDIA has paired 4 GB GDDR5 memory with the GeForce GTX...
      10-01-2024, 02:47 PM
    • Hakuu
      by Hakuu
      Hi There,
      More Details
      TV Model - LG OLED77G1PUA
      07-12-2023, 02:37 PM
    • canadaboy25
      Panasonic TC-P54VT25 No image. A or D board?
      by canadaboy25
      I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
      I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
      01-17-2021, 01:06 AM
