Help with GeForce 6600gt AGP Card not receiving enough power
  • erdos
    • Jul 2012
    • 14
    hey guys,
    I have an old homebuild PC with MSI K8N Neo Platinum 754 NVIDIA nForce3 250Gb ATX AMD Motherboard and Evga geforce 6600gt agp Card.
    whenever I booted into windows7, an onscreen message pops out - warning that nvidia card is not receiving enough power and is at reduced performance level. When I opened the case, the GPU fan on the nvidia card is not spinning. after a while, the card becomes extremely hot when touched. I have a new Cosair RMS 750Watts PSU for the pc - replaced an old TruePower 380Watt ATX12V Power Supply, and the extra molex connector on the AGP card is plugged in.
    I need some advice on how to diagnose/fix this card.
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Help with GeForce 6600gt AGP Card not receiving enough power
    Start by removing the graphics card and verify that the fan is free to spin and can spin when powered with 12V. If it can't, then this is why you're probably receiving the message: the GPU is throttling and running in reduced performance state because it's overheating.
    Clean out the fan and any dust in the heatsink.
    If the card has been like this for a while (i.e. overheating), the thermal paste might have dried out. Thus, it is also recommended to re-apply fresh thermal paste between the heatsink and GPU core.
    Lastly, maybe post some pictures of the video card and the message you're getting. Though, if you find out the fan is not running due to dust or being stuck, DO NOT wait to get the error message in Windows. Running the video card one too many times with the fan stuck WILL damage the GPU chip eventually. So the less you run or use the GPU with the stuck fan, the better.
    Note that this is an old video card, back from the days when the fan was always set to run (and not like new GPUs that throttle down and turn off their fans to save power and generate less heat.) These old GPUs tend to use almost as much power in idle as they do under load. So without constant active cooling from the fan, they will overheat very quickly.
    • erdos
      • Jul 2012
      • 14
      Here are the screenshot of error and pictures of actual card
      • R_J
        • 9556
        Check the fuse (F1) top side, near empty Q16 It looks like a polyfuse so check the that you have voltage on both sides as it may reset without any current through it.
        • ribcage
          • Sep 2020
          • 45
          • Earth
          Hi, are you in Devuan forums? Cool coincidence if so.
          • erdos
            • Jul 2012
            • 14
            yes, that's me as well! good to see you here too!
            • erdos
              • Jul 2012
              • 14
              pardon me for the late reply...
              Just revisiting the thread, i was onto other stuff but the graphics card stopped working completely recently, pc showing a blank screen during bootup.
              afterwards I took out the card from pc and checked the F1 as mentioned on the card, it shows continuity across the element, is that normal? or should i check it while the card is installed while pc is running?
                NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                10-02-2024, 08:52 AM
                NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                10-02-2024, 07:51 AM
                GeForce RTX2080 Super Aero video gaming card issues help need
                by sam_sam_sam
                This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                05-07-2023, 08:12 AM
                NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
                The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
                10-01-2024, 01:54 PM
                MSI GeForce GTX 980 GAMING 4G MS-V317 Graphics Card Schematic
                GTX980 Rev 1.0...
                11-01-2024, 05:19 AM
