General Intel Chipset/Dell Design inquiry for the PCH to output CPUPWRGD
  • lustre
    • Jul 2021
    • 14
    For reference, I am using the schematics of a Dell Optiplex 7050 Micro, D24M8, and will include them in the post if I can (I am a new member, so I'm not quite certain if it's against the rules or possible atm).
    My question, what are the prerequisites for the PCH to output CPUPWRGD? I have a board that won't assert the signal, even though I have all prerequisite signals listed on the power sequence map, and I have confirmed all crystals are oscillating at proper frequencies as stated on the CLK diagram. The PCH has been replaced, and a known good SPI is flashed and installed. No dice. After hours of probing and reading correct values, I chalked it up to some internal trace damage and called it a day. But now, it's haunting me that I couldn't actually confirm the issue. Is there a possible timing issue involved? I've checked that the sleep signals are asserting at proper timing intervals with my oscilloscope but it seems like there's no obvious issues like ripple or signal assertion delays from what I can see. Is there anything I'm missing? Any help would be appreciated, including but not limited to posting in the proper threads lol
    Side Note: I've read the Intel Chipset datasheets for this particular architecture pretty extensively, and I fix these things for a living, so that's my knowledge basis if anyone was wondering.
  • lustre
    • Jul 2021
    • 14
    Re: General Intel Chipset/Dell Design inquiry for the PCH to output CPUPWRGD
    I hope this doesn't come off as condescending or haughty; I am kinda nervous about the first time asking this kind of question online lol
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
    • lustre
      General Intel Chipset/Dell Design inquiry Optiplex 7050 Micro
      by lustre
      My question, what are the prerequisites for the PCH to output CPUPWRGD? I have a board that won't assert the signal, even though I have all prerequisite signals listed on the power sequence map, and I have confirmed all crystals are oscillating at proper frequencies as stated on the CLK diagram. The PCH has been replaced, and a known good SPI is flashed and...
      03-19-2023, 08:29 PM
    • F R 2568
      Dell Latitude 5420 does not start (no post) need help to find the reason why
      by F R 2568
      Hello all,
      this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
      I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
      If the laptop is only connected to the AC adapter (battery removed):
      When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
      The power/battery...
      01-08-2025, 05:45 AM
    • diamon
      Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
      by diamon
      I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
      Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
      Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
      Pictures of these boards:
      Dell Latitude 5520 https://www.ebay.com/itm/256052956663
      Dell Latitude 5530 https://www.ebay.com/itm/125844181534
      Dell...
      02-28-2024, 12:51 PM
