No SCLK from CPU on AsRock H61M-VG3
  • xnRS
    • Feb 2021
    • 85
    • Belarus
    I have Asrock H61M-VG3, which, for some reason, doesn't have VIDSCLK(800mV instead of 1.05v), which should go to PWM controller, also pin on pwm controoler which is getting VIDSCLK, seems corroded(Voltage measured from resistor which then goes to PWM controller)
    Any ideas why this could happen?
  • master3112
    ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
    by master3112
    I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
    When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
    10-29-2024, 09:32 PM
  • gabrieljma1
    Request: Full BIOS dump for ASRock Z790-CX (DDR5)
    by gabrieljma1
    I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
    The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
    I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
    10-08-2025, 03:32 PM
  • ronnygracias
    Help with freemotion incline trainer with controller comm error
    by ronnygracias
    The treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...
    11-04-2024, 01:32 PM
    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
    I am comparing them to a brand new one that I installed
    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
    I going to let it run for several days before I remount back on the wall next to the...
    09-05-2024, 06:48 PM
    Tankless hot water heater controller board not powering up when power is applied
    I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
    I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
    However I would like to know if I could figure what happened to this controller board if possible
    Tomorrow I will take some better pictures of both side of both boards
    The...
    12-09-2022, 09:14 PM
