Netgear = By far the most horrible support ever!
+ More Options
Posts
    • 30978
    Re: Netgear = By far the most horrible support ever!
    i like that it says HP
    none of that "keysite" / "agilent" bullshit.
    now lets see inside the netgear - see if it has vented some shit caps!
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      Will do. Autopsy coming up.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        Originally posted by Topcat
        Netgear can go piss up a rope....replaced the POE switch with this:
        New HP 2520-8 POE switch. 10/100 is all I need, the cameras are only 100-base anyway....does just fine....and YAY, the cameras are working again!!
        Good for you. If enough people took your course of action, then either netgear would change or they would be out of business. It is called people power.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          Originally posted by redwire
          The big brick 48V 1.75A 84W hopefully runs cool.
          It runs very warm, but not hot.....but the other day I did notice that it's making some unpleasant noises; kind of a 'crackling' sound...but seem stable. There are 6 cameras powered by POE @ ~10w ea, which would put it ~60W + whatever the switch overhead is...I think it's a bit overwhelmed. If I back a couple of the cameras off, it quiets down....so I don't think it's very happy with this arrangement. I ordered a 350w 48v open frame PSU that will replace this.
          stj, I did autopy the old netgear, no *visibly* bad caps on either the mainboard or the power supply. I took some pics but forgot to dump the camera.
          Team : 49813
          Join in!!
          Team Stats
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16956
            The autopsy....
            No visibly failed caps.
            The PSU, built by Delta....Cap quality is good; Rubycon & UCC. PSU is rated @ 50v, and was steady at 49.8 with or without a load. Outputs were clean on the scope.
            Piece of shit....by a shit company.
            Team : 49813
            Join in!!
            Team Stats
              • 30978
              50V psu? that could come in handy!!
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16956
                Indeed. I will not scrap it.
                Team : 49813
                Join in!!
                Team Stats
                • kaboom
                  "Oh, Grouchy!"
                  • Jan 2011
                  • 2507
                  Delta is/was always OK, at least when not "strongarmed" into cheap caps. Dell-OLOL!
                  "pokemon go... to hell!"
                  EOL it...
                  All style and no substance.
                  guilty,guilty,guilty,guilty!
                  guilty of being cheap-made!
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16956
                    This one was of the better....good caps and clean outputs... The reason I put it back in the box and put it in the storage room rather than the e-waste bin....
                    Team : 49813
                    Join in!!
                    Team Stats
                    • televizora
                      ghettomodmaster
                      • Nov 2016
                      • 957
                      • Bulgaria
                      #30
                      My advice is to buy Mikrotik equipment. Not only there are plenty of options, but I never had issues with warranty.
                      Anyway, I think that it can be fixed. Usually it is issue with the switch chip. But for all ports to die simultaneously - strange.
                      Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
                      1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
                        • 30978
                        it's a "managed" device, if the mcu fails or it's bios gets corrupt then it wont run
                        corrupt 8pin bios wouldnt surprise me.
                          • Jul 2011
                          • 6033
                          NETGEAR
                          Word to the wise, avoid Netgear at all costs....spend a couple bucks more for the Cisco.
                          Can I ask you where you bought it from because I want to see if it this new crap about only certain company’s can handle there products under warranty and it depends on where you bought the product from
                          Because I also have NETGEAR router but mine seems to fail after the warranty has expired
                          Because I have seen this with Milwaukee has done this crap now which was never this way until recently
                          I have a drill that I bought from Home Depot and I took it to the Milwaukee service center to get repaired and the first question that was asked was did you buy it from at Home Depot because now the serial number shows where it was bought from
                          Milwaukee service center can and sell Milwaukee products but there is a catch not all models are available because what you see at Home Depot is not available at the Milwaukee service center and the the same holds true the other way around as well
                          Milwaukee service centers no longer service Home Depot bought products dose not matter that you have a sale slip no warranty when you buy it from Home Depot you have to buy the extend warranty which means that you get a new one ( the term consumables has also changed more items are in this list that was not there before )
                          I would highly recommend that when ever you buy a product now that you first find out where you can get the warranty service done and dose make a difference where you bought it from because I do not understand what this crap is all about
                          ( if it you want it repaired under warranty highly recommended that you check first )
                          One note if more companies are going to do this crap and not really have warranty anymore when bought at certain retailers then these products need to come down in price and you should be told that if you buy this product from us you have no warranty so we can be informed
                          I probably should not have been ranting and raving about this crap on this post but this is nothing but crap
                          Please excuse me for this if it was unacceptable
                            • 30978
                            buy cheap shit from china, the warranty is the same obviously - so why pay for a name?
                            if the big-names want to fuck around then let them die.
                              • Jul 2011
                              • 6033
                              I also want to see this as well
                                • Jul 2011
                                • 6033
                                I could not agree with you more about this
                                  • Jul 2011
                                  • 6033
                                  I have a question might not be related to this post but has Best Buy started doing this crap as well I only once in a while buy anything from them if I am going to buy something from them I going to find out how there warranty work on what ever item I buy from now on
                                  • redwire
                                    • 3906
                                    Make products extra cheap
                                    Warranty claims go up
                                    Profits go down
                                    Make warranty claims harder or impossible for consumers
                                    Warranty claims go down
                                    Profits go up
                                    This is the latest scumbag MBA method to get their bonus.
                                    No mention of the warranty period on BestBuy's website, or Netgear or their user manuals or brochure, or Amazon listings etc.
                                    "Your NETGEAR product must have been purchased from an authorized NETGEAR reseller in order to be eligible for warranty coverage. "
                                    "To receive warranty entitlement for your NETGEAR Business products, you MUST register your product." What about home stuff? What about purchases from Dell, Newegg etc.?
                                    Netgear website shows a BestBuy, Walmart, Amazon, Target etc. icon to hint they are "authorized" resellers but there is no list or anything formal.
                                    It's just fuckery to get you to buy an extended warranty. A company screwing consumers this hard will never make a decent product in the first place.
                                      • Jul 2011
                                      • 6033
                                      I guess no one is making a good product anymore very sad state of affairs really
                                      • Topcat
                                        The Boss Stooge
                                        • Oct 2003
                                        • 16956
                                        It was a reputable vendor from Ebay; unit was new in box, seals not broken....
                                        For a warranty covering HARDWARE, where it came from is irrelevant...according to the serial number, it was under their fake 'warranty' validated through the NETGEAR WEBSITE. This was just a dickmove way for them to get out of standing behind their product.
                                        NEVER AGAIN NETGEAR!! I actually sent a link of this thread to their warranty claim scumbag that messaged me to deny the claim....and got a reply saying my claim was being 're-evaluated'.....of course that was weeks ago and I haven't heard anything since. Liars will lie.
                                        Team : 49813
                                        Join in!!
                                        Team Stats
                                          • 30978
                                          well, as they may be reading this - fuck netgear!
                                          and routers dont need to use a "cloud" to administer the settings either!!
                                          • gripa
                                            looking for netgear WN2500RP schematic
                                            by gripa
                                            I am looking for a schematic of the netgear WN2500RP repeater.
                                            best regards
                                            12-17-2024, 12:39 PM
                                          • greatdragon
                                            Looking for schematics for Netgear Nighthawk c7500
                                            by greatdragon
                                            The markings on the board say
                                            tmt YAML 1 94V-0
                                            e114139
                                            1806
                                            03-20-2025, 11:58 AM
                                          • shovenose
                                            Netgear JGS516PE Switch Fan Replacement
                                            by shovenose
                                            I got a free Netgear JGS516PE PoE switch and it works fine but the fan makes a grinding sound.
                                            It uses a 12V 3 pin fan with a non standard pin out. So I took a Noctua fan and moved the wires around in the connector to make it work.
                                            Unfortunately, the fan spins for just a couple seconds before it turns off and the Fan Fault LED comes on.
                                            I think it's stupid they designed it to stop powering the fan when it detects a fault but I guess that's what they chose to do.
                                            Instead of spending $30 on the correct replacement fan, does anyone have a clean...
                                            12-12-2024, 03:24 PM
                                          • ay_erdi
                                            Netgear R7500 Router Dead
                                            by ay_erdi
                                            Hi everybody,
                                            My router netgear R7500 is dead.There are four burnt components inside.Can you help me identify?
                                            VR8-U17-U78...
                                            02-16-2024, 10:58 AM
                                          • suiramix
                                            Netgear R7200 (AC2100) no boot up
                                            by suiramix
                                            Hi there,
                                            Netgear router, model R7200 [similar to R6800, R6700v2] pressing power button, the WiFi LED glowing solid white, with NO Power LED light… so no boot up properly! Done the hard reset for 30/30/30sec …no change. Checked the power adaptor voltage output= 12.02V
                                            Remove the cover and check all components … no visible damage. The inductors and solid capacitors show reasonable voltages [between 12.0, 5.0 ,3.3 and 1.0V] except L10 and C205 = 0.67V, [my guess is kind of low].
                                            The U21 and U23 ICs [voltage reg] have similar application circuit but unable to identify...
                                            11-09-2023, 01:00 PM
