Wifi signal
  • nosugartonight
    • 107
    • united states
    Wifi signal
    Hay. Not sure if This post is in the right place but here it is. My neighbor said I can use his wifi. The signal is weak. I assume it's because of the distance. Approximately 150 feet. Also there are other open wifi but are weak also. Is it possible to extend the antenna wire out of the tv to the outside to a antenna to improve signal strength.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8203
    Re: Wifi signal
    get yourself a ubiquiti oudoor AP or similar.
    • nosugartonight
      • 107
      • united states
      Re: Wifi signal
      Not looking for gadgets was just wanting to know if its possible. All smart TVs I've been into. Only have a small piece of metal at the end of antenna wire. So could that wire be extended to the outside, maybe connected to an Ariel antenna or simply to so aluminum foil to pick up better. any thoughts will be appreciated.
        • 31070
        Re: Wifi signal
        no, the losses in the cable will remove anything you gain from a decent 8dB+ antenna
        • petehall347
          • Jan 2015
          • 4427
          Re: Wifi signal
          antennas on the router might help
          • nosugartonight
            • 107
            • united states
            Re: Wifi signal
            Ok. I have routers .Not on his network.
              • 31070
              Re: Wifi signal
              maybe you can use a router in reverse to link to his router.
              some have that option, others can sometimes have better software installed.
              what routers do you have?
              • madan1
                • Nov 2016
                • 682
                Re: Wifi signal
                Get a cheap tp-link 740, install dd-wrt and connect it to the other wifi network as a client. After that you can use cable to connect your TV ( and other devices ) to that router or add a virtual wireless network to which to connect your devices.
                • Curious.George
                  • Nov 2011
                  • 2305
                  • Unknown
                  Re: Wifi signal
                  +42
                  Relocate the router closest to the neighbor's house. Add a "cantenna" pointed directly at his source. Use CAT5 to make up the distance to the router's previous location. (note "router" can also be a laptop, etc. acting as a bridge)
                  If neighbor really wants to cooperate, he can add a cantenna on his end pointed back to yours.
                  If you can't get close to a mile with such an arrangement, you're not trying hard enough!
                  • televizora
                    ghettomodmaster
                    • Nov 2016
                    • 957
                    Re: Wifi signal
                    This is neither smart, nor reliable. If you have money for smart TV, at least buy a cheap router with AP client function, waterproof junction box and put the router on your chimney and then connect it to the TV at your home. Second hand 5210G or M2 costs about 30$. Don't you have 30$ to save from cigarettes and whiskey? Even I have 3 AP's in storage - 2 TPLinks and one Bullet M2. Don't do stupid things if you don't want to be constantly frustrated with dropping connection. I used 5210G to connect to Repotec router on a 1.5km distance without issues. At least 15Mbps at any time.
                    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
                    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
                      • Jul 2011
                      • 6040
                      Re: Wifi signal
                      I send you PM message
                      • simitaktas
                        • Feb 2020
                        • 21
                        • switzerland
                        Re: Wifi signal
                        If youre not looking for a gadget, your best bet is to get your neighbor to reposition his/her router to accomodate you
                        • simitaktas
                          • Feb 2020
                          • 21
                          • switzerland
                          Re: Wifi signal
                          I did more research and found a list of practical solutions that may be of help of to boost wifi signal
                          • llonen
                            • Sep 2014
                            • 495
                            • hampshire
                            Re: Wifi signal
                            This was the setup I had when using someone else's wireless network, a D-link AP with detachable antenna arrangement and a small 2.4ghz dish. The AP once configured was sealed up in a box and stuck up the pole with dish, power over Ethernet completed the arrangements. This setup worked flawlessly for a few years until they rolled out ADSL thus rendering the setup redundant.
                              I need an answer to how to amplify my WiFi signal because it is so weak outside
                              I have a really bad situation right with a very weak WiFi signal outside of the house and I have been told that I can not have two routers on my modem because it cause issues so what is the solution for this issue
                              I can fix the garage door opener with a cat5 cable to device modem or at least that is what I call it and it works very well so far but by doing this I have no router in the garage and no WiFi signal inside the garage unless the door is open but it is extremely weak if not at all
                              The MyQ cameras can NOT hookup to a cell phone hotspot I have tried it need...
                              11-19-2023, 06:23 PM
                            • AstutePauciloquent
                              Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                              by AstutePauciloquent
                              Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                              I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                              11-23-2023, 11:02 PM
                            • howardc64
                              M557-G0 no WiFi/Bt no WIFIVendor file?
                              by howardc64
                              Thanks to Diah, got M557-G0 LCD panel buffer board repaired and running ( link ) Next challenge is no WiFi/Bt despite module on the main board and getting 3.3v supply (3.45v measured)
                              • TV Menu shows Network Access Point option (enet unplugged) but menu can't select that entry
                              • Service Menu shows many Bt/Wifi info missing
                              • Vizio app shows no WIFIVendor file
                              Prior owner used enet and said turned off wifi somehow. It seems system config info for wifi might be missing. Anyone experienced this before?
                              • Tried countless enet unplug (user manual said need to unplug enet to get to wifi menu), factory
                              10-15-2024, 01:12 PM
                            • ugamazing
                              820-00850 & 820-01949, No WiFi *In Recovery*
                              by ugamazing
                              I've got two boards with the exact same issue, and it's confusing the hell out of me. In short:
                              1. Both boards behave *exactly* the same; they will show WiFi networks to connect to, and will boot fully to Internet Recovery, but they each show zero available WiFi networks once booted to Internet Recovery. I also cannot switch WiFi "off", as in, the toggle will not move.
                              2. Both boards will erase perfectly fine using the "erase mac" function; I can wipe them with disk utility, but if I try to install MacOS from Internet Recovery, it says to connect...
                              01-25-2023, 05:39 PM
                            • AlexVG
                              Replacing the WiFi module on a vacuum cleaner iROBOT i7
                              by AlexVG
                              I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
                              I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
                              (This board does not respond, only the LEDs light up in a circle.
                              The liquid damage is catastrophic and restoration is impractical).
                              (I bought this board to get the WiFi module and camera).
                              The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
                              If...
                              10-22-2024, 07:20 AM
