Had an interesting board-level repair come across the bench on an Ubiquiti AmpliFi Alien (amplifi-xg) mesh router. Documenting the diagnostic steps and rail measurements here in case someone else runs into a missing 2.4 GHz band on these units. Symptoms & Initial Troubleshooting
Notes for anyone servicing these Alien routers: Do not assume a dead RF band is a blown Qualcomm SoC. Check the discrete buck supplies and bypass capacitors around the shield cans first—these MLCCs run hot in the enclosed tower and are prone to dielectric breakdown.
- Symptom: 2.4 GHz Wi-Fi band completely disappeared overnight. 5 GHz / Wi-Fi 6 band and ethernet switching operated normally.
- Standard software troubleshooting (factory resets, firmware re-flashes, NVRAM review) had already been performed with no change. OEM tech support had written it off as a dead Qualcomm baseband radio.
- Stripped down the tower assembly to access the mainboard and the mPCIe radio daughtercard (Qualcomm QCA9984 architecture).
- The 5 GHz radio card pulled cleanly, but removing the radio card did not restore the missing circuit behavior.
- Cold Resistance-to-Ground Sweep:
- Checked resistance to ground across all major switch-mode buck converter inductors surrounding the primary PMIC / regulator stages (including the uP1708p buck controller circuits).
- Most digital/RF power rails measured in the expected range (several hundred ohms to kilohms).
- Found Inductor L17 reading 0.2 Ω directly to ground—a dead hard short on that dedicated buck regulator net.
- Isolating the Short:
- Pulling the mPCIe radio card confirmed the short was on the mainboard itself, not inside the Qualcomm RF package.
- Injected a low-voltage test rail (1.0V with a tight current limit) into the shorted L17 node while monitoring the board under thermal imaging / isopropyl alcohol evaporation.
- The buck controller IC itself was cold and intact; the heat concentration centered on a single bypass MLCC in the filter array decoupling the output of that rail.
- Rework & Resolution:
- Desoldered the shorted MLCC under the microscope.
- Resistance to ground on the L17 pad immediately bounced back from 0.2 Ω to high impedance / normal circuit operating resistance (kΩ range).
- Replaced the failed shorted cap with a fresh 22 µF X7R ceramic capacitor, cleaned the area, and replaced adjacent filter caps (FC-labeled nets) for any thermal degradation.
- Verification:
- Reassembled the heatsink cage and antennas.
- Bench tested on an isolated bench supply; the buck regulator produced steady operating rail voltage without excessive ripple.
- Booted into firmware: 2.4 GHz beaconed immediately with full RF output power and client negotiation.
