UniFi U7 Pro (IPQ5332) - U-Boot hang at 'NAND:' init - Hardware isolation and troubleshooting
  • lukasg26
    • Mar 2026
    • Brasil
    I'm troubleshooting a bricked UniFi U7 Pro (IPQ5332 platform) that suffered a power surge. I’ve reached a point where I need expert insight into the Qualcomm boot flow to determine if the SoC is permanently damaged or if there’s a logic/firmware bypass I’m missing.
    Note: I have attached the full serial console log in a .txt file to this post for detailed analysis.
    Current Symptom: The device is stuck in a boot loop/hang. On the serial console, it consistently stops at the NAND: initialization line, as shown in the attached log.
    Steps already taken:
    1. SPI Flash: Desoldered and reflashed the 8MB Winbond chip with a known-good dump. No change in the boot hang.
    2. eMMC Removal: Suspecting a short in the Kingston eMMC, I physically removed the NAND chip from the board. Surprisingly, the U-Boot still hangs at the exact same NAND: line instead of reporting "No device found".
    3. Power Rails:
      • V_CORE is stable at 0.95V (measured with an oscilloscope during the hang). No ripple or drops detected.
      • Power consumption on the bench power supply is 73mA to 100mA @ 1V (injected into the core rail), suggesting no hard short-circuit in the silicon.
    4. Impedance Check: Measured the core rail in diode mode; it shows approximately 10mV/10 Ohms. While low, the stable current consumption suggests this is the normal impedance for this SoC family.
    The Question: Does the IPQ5332 U-Boot implementation for Ubiquiti enter a "Spin-lock" or "Hard Hang" if the eMMC controller fails to initialize or if the chip is missing?
    I would appreciate any insights from anyone familiar with the IPQ53xx/90xx boot sequence or if there is a way to force the U-Boot to skip NAND detection via serial commands (though the console is unresponsive at this stage).
    Thanks in advance!
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8880
    I think you jumped the gun on removing the EMMC. You should have investigated with an oscilloscope the data lines. Then you should have maybe tried reading the EMMC with a programmer through ISP. There are many reasons why the EMMC won’t do anything. For instance if a resistor on the D0 line changed value. There is a bunch of stuff that needs to be ruled out. But with a programmer and ISP (flying wires soldered to the board) is your best bet to kill a few flies with one swat. If the reading of the EMMC would have worked, it would have told you that this wasn’t the cause.
    If you do swap out the EMMC it has to be same speed or better. It’s sucky work trying to get the little wires on the board and you also have to know which wire goes where.
    Could be also the controller on the NAND inside the EMMC bad… etc.
    Good luck!
    • eddyevans
      • May 2026
      • US
      Interesting case. The fact that it still hangs at the exact same NAND: stage even with the eMMC physically removed makes me think the bootloader is stalling inside the controller init routine itself rather than waiting for actual media detection.
      On some Qualcomm platforms, especially vendor-modified U-Boot builds, I’ve seen hard hangs happen when the NAND/eMMC controller clocks or PHY init fail after surge damage. In those situations the code never reaches the “device not found” path because the controller register access itself locks up.
      Since you already verified V_CORE, I would probably start checking:
      • eMMC/NAND controller related rails
      • clock generation around the SoC
      • reset lines to the storage subsystem
      • possible damaged pull-ups on CMD/CLK/DATA lines
      A surge can also partially damage the SoC I/O domain while leaving the core apparently healthy, which would match your relatively normal current draw.
      sports games
      One thing that may help narrow it down: does the UART log timing freeze instantly at NAND: or is there a delay before hanging? Sometimes a timeout delay can indicate firmware waiting for response, while an instant freeze points more toward bus fault / controller crash.
      • Bill_Parl
        • Apr 2023
        • Greece
        Hello!!! I have the same problem with ne U7-Pro. Is it possible to send me a known-good dump for the 8mb chip? Thanks in advance!
        • cristidvx
          MacBook Air M3 stuck at 5 V after NAND replacement — missing NAND power rails
          by cristidvx
          I bought a MacBook Air M3 that displayed an exclamation mark and a message with a restore address. I tried restoring it several times, but none of the attempts completed successfully.
          I then replaced the NAND chips with chips from iPhone 14s. I reprogrammed them using a JCID V1S Pro and a firmware file obtained from dosdude1’s website. The programming process completed without reporting an error. I reballed the chips using a stencil and solder paste; the balls looked shiny and appeared to be in place. After soldering the NANDs back onto the board, I checked...
          11-02-2026, 03:26 AM
        • anik0101010
          [REQ] RCF M18 Digital Mixer - NAND Recovery files (uImage / ubi.img) or Dump
          by anik0101010
          I'm working on a bricked RCF M18 digital mixer. The unit was completely dead, but I managed to resurrect the hardware doing a low-level recovery via the internal UART header and the Debug Jumper method (as per RCF Service Note 1903B).
          I successfully booted from the SD card, wiped the NAND, and flashed U-Boot. The CPU is alive and I now have a working serial console at the RCF-M18# prompt.
          The Problem:
          The recovery script halted because the official firmware update provided by RCF on their website (.mpk format, ~1.5MB) is just an application...
          04-07-2026, 02:34 PM
        • Turoha
          PS5 EDM-031
          by Turoha
          I am having an problem with the EDM-031 board.
          At first it had overheating problem and was taken to service. After that it worked fine, and after shutting it down and starting to game again after 5 hours, it ran 2 seconds, beeped and showed bluelight.
          In the attached image, i marked the two places i found which measures 0 Ohms to the ground. And i lifted up the induktors other side (marked with blue circle) and the short stays at the where the arrow is pointing.
          Any idea how i should continue the troubleshooting? There seems...
          09-25-2026, 02:20 AM
        • tranquility
          Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
          by tranquility
          i want to repair an Onkyo TX-NR809 receiver.
          symptoms:
          on power on, display appears and i hear one click. enue functions is given.
          - no hdmi output
          - audio output not tested, but i think it is not there
          - usb sticks are not recognized
          if i read out the chips with display+standby button + tone+
          both dts show only ????
          chip is D830K013BZKB4
          things i have done:
          - reflow of the dts chip without taking off and reballing
          - changed the aluminium caps without the big one with 25v because i dont...
          08-25-2025, 01:04 AM
        • Marcus3235
          Qubo Dash Cam Pro X Stuck During Boot: SigmaStar SSC335R + W25N512GV SPI NAND
          by Marcus3235
          Note: I am not a professional electronics/embedded engineer. Everything I've done so far has been learned through YouTube videos, datasheets/forums, and guidance from AI. I've been proceeding cautiously, measuring and documenting each step, and have deliberately avoided writing/erasing the NAND or making irreversible changes.
          Qubo Dash Cam - SigmaStar SSC335R stuck at "Load BL from SPINAND"
          I'm trying to recover a Qubo dash camera that stopped booting. Qubo support told me the unit has gone bad and recommended replacing it, so I'm investigating...
          08-09-2026, 08:45 PM
