Ubiquiti US-48-500W – No LAN Port LEDs, Possible 12V Issue?
  • dizzyadam
    • Nov 2021
    • 13
    Ah I dreaded to hear it be one of the main chips because they use some really hard thermal application with the heatsink that I'm scared that I might rip it off, guess theres no more harm trying now. I can also only do reball since im not gonna spend another 20-40 for a BCM on Ali, I'll either reball and see if it works or keep it for spares until next switch comes in.
    As for ES -> US, so you're saying I need a new BIOS chip from a US model and flash the dump from the ES onto it?
    I might be wrong here since it was a while ago, I messed around with UAP-AC-PRO that also has the A12 error. I believe after just swapping the BIOS chip over from a working one, it started working with no issues but ofcourse has the MAC details from the previous one. So I think there is something into what you're saying and could be the goal to fixing this A12 issue (granted everything else on the board works).
    P.S. I now have a working US-24-250W after replacing PSU from a donor switch if you ever need a dump from that.
    • dimasiki
      • Jun 2017
      • 8
      • Ukraine
      I’ve found a way to convert the ES to a US model!
      Now all I need is a working dump from a US unit and a similar ES unit.
      You flash the US dump onto the ES and you end up with a US clone.
      I’ve also sorted out the A12 error.
      I’m currently in the process of resolving the issue of changing the MAC addresses and serial numbers on these units.
      • ezenia
        Gigabyte B450M S2H POST/boot issue
        by ezenia
        So I got a faulty Gigabyte B450M S2H motherboard off eBay. It was listed as having a potentially faulty CPU socket. When I got the board, I went straight to checking the CPU socket under a microscope with the plastic cover removed to verify if it was actually damaged. None of the pins looked broken or damaged.
        So I started troubleshooting the board to see what's actually wrong. The 1st issue I found was there was 0.7V at the power button header. I found the cause was the 6-legged ESD chip that was next to the header. So I removed the chip which brought 5V back to...
        04-19-2026, 03:20 PM
      • Clarify4082
        Ubiquiti Unifi U6 Lite Access Point POE power issue
        by Clarify4082
        I bought a Unifi access point for cheap which has no power when connected to POE.
        If I insert 5V manually, the AP is starting and I can connect via the unifi app.
        When connected to POE the board is dead .
        There is a damage and a missing component/capacitor? [C8329], but I´m not sure if this is POE related:
        I already replaced the poe-controller (LM5071MT-80) but nothing changed.
        Need help to understand the POE input-circuit......
        07-02-2026, 12:49 PM
      • tronitas46
        B&W ASW1000 output stage transistors bias imbalance issue
        by tronitas46
        hi everyone!
        I'm having an issue with my subwoofer and this is getting beyond my basic knowledge and at this point I'm not sure what I'm doing so I decided to stop and ask for help.
        long story short:
        I bought this sub about 5 years ago for cheap with no audio issue, I found out it was a simple dirty phase switch that contact cleaner fixed, the sub was working great with the exception of making a poping noise when turning off (which was super annoying)
        since I was using it every day I figure I'll just put to switch to always ON and be good with it (I know,...
        02-13-2026, 03:53 PM
      • ezenia
        ASUS ROG STRIX B450-F GAMING REV 1.01 - USB Overcurrent Issue.
        by ezenia
        Bought an ASUS ROG STRIX B450-F GAMING REV 1.01 off eBay. Seller said fault was board wouldn't POST and was stuck on CPU LED (and occasionally VGA/DRAM). When I tested the board, it actually does POST. However, it complains about a USB Overcurrent issue and shuts down in 15 seconds.
        Work has been done on this motherboard already. They removed the audio codec, a chip labelled U31U3 on boardview and some ESD diodes/SOT23's near the USB ports. It appears they tried to resolve this overcurrent issue and weren't successful. I did my usual resistance checks on the 24-pin connector and found...
        06-19-2026, 12:07 PM
      • Teeheeze
        Strange Issue After A2681 Panel Only LCD Replacement
        by Teeheeze
        Hey everyone,
        I have a pretty strange issue I've experienced w/ 2 different A2681 2022 MacBook Air 13" devices now.
        The problem occurs after I replace the LCD panel on the screen assembly (panel only repair). After the repair and being assembled, I'll power on the device and you'll see the backlight illuminate, but the image on the LCD panel itself remains black. Once the keyboard backlights light up and the device boots to the macOS login screen, if I close and re-open the lid, then TADA.. The image comes up perfectly and the device continues to function normally...
        04-28-2026, 11:19 AM
