Fortinet 50E Slowing down internet throughput
  • the Benninger
    • Nov 2022
    • 189
    • venezulan
    Hi folks
    Recently Fortinet seems to change the firmware download policy,If the warranty has passed,Even if you are a member,Can't download firmware,Just one of the 110Cs in hand recently is a bit abnormal,Firmware needs to be repainted,But can't find the dilemma that the firmware can download。After asking the manufacturer for help, I finally got a firmware,Then, go online and search for the firmware file that can be found,Stay here as a spare,It is also provided to emergency friend
    mon2
    Thanking you for the help you have offered me selflessly and to everyone in general, I can offer you the update file. I don't have them all, but I do have most of them and in the latest available versions. However, I would have to do it by logging into the firewall. If it's possible to log in, I would recommend making a backup of all the configurations first and then re-uploading after the update.
    I hope it's not too late, one last thing, is there a way to restore it to factory settings from the hardware! Be careful, this will erase all existing configurations and parameters. It goes like this: disconnect the power supply, press and hold reset button with a clip, then connect the power supply and keep holding the reset button for 10 seconds. Remove the clip and wait about 5 minutes for it to complete. (HardReset)
    Once it is restored in a browser, type the default address; in my case it is (192.168.1.99) which could vary depending on the country, the default user is (admin) and the password is left blank.
    I sincerely hope it helps you.
    • harp
      piezo worn out issue
      by harp
      I wonder if it is real, or missleading some other problem? ?............... https://m.youtube.com/watch?v=ceb09rxPohA ?....... in video is presented claims that new piezo fix problem of poor production of moist, what is electronic science stand behind that conclusion? Can piezo be worn out and hot to tested it for that condition.............. in the past I see video where is piezo torturing through test vith high voltage, various frequency, and it is amazing what can survive and operate after damaged.
      10-13-2024, 03:40 PM
      AD7276, AD7277, AD7278, AD7274, AD7273​ Datasheet
      The AD7276, AD7277, AD7278, AD7274, AD7273 are 12-bit/10-bit/8-bit, high speed, low power, successive approximation analog-to-digital converters (ADCs), respectively. The parts operate from a single 2.35V to 3.6V power supply and feature throughput rates of up to 3 MSPS. The parts contain a low noise, wide bandwidth track-and-hold amplifier that can handle input frequencies in excess of 55 MHz.
      The conversion process and data acquisition are controlled using CS and the serial clock, allowing the devices to interface with microprocessors...
      10-07-2024, 05:32 AM
    • TrumanHW
      A1708 13 MacBook Pro Fn WiFi stops working | Turn OFF-ON WiFi = Temp Fix (1-6 min)
      by TrumanHW
      WiFi menubar symbol shows hardware stays connected (even when issue occurs)
      WiFi adapter shows normal connectivity symbol & stats: Using Opt+WiFi shows:
      • Tx Rate: 867 Mbps
      • RSSI: -44 dBm
      • Noise: -90 dBm (same as working MBP connected to same router)
      After ~1 min - 7 min, connectivity is lost (no traffic works) until I Disable / Enable WiFi (temporarily fixing again)
      Inspected Antenna connections (look secure) & UP / DL is quick when working (same as good laptop)
      • DL = ~400 Mbps
      • UL = ~17 Mbps...
      09-06-2022, 10:45 AM
    • Peterpies
      How to repair ffc connector on microwave panel
      by Peterpies
      I have a sharp microwave front panel connectors which link to the motherboard via ffc strips into push in connectors, see images, the connector strips are worn I have cut them back but they still don’t make a good connection any ideas how I can overcome this would be appreciated. All switches on panel which are touch type work fine, have thought about conductive pen or paint anyhelp appreciated....
      09-21-2025, 10:29 AM
    • w1nk0
      Thinkpad X1 Carbon 5th Generation DX120 NM-B141
      by w1nk0
      Hello!
      I'm looking for help with Thinkpad X1 Carbon 5th Generation DX120 NM-B141:
      - no image
      - fans spins for second or two (not sure why once it is second and once its two or smth)
      - keyboard and power button lights for split second
      Not sure about SN because sticker got worn after time.
      Any help would be appreciated!...
      07-07-2025, 05:27 PM
