Fortinet 50E Slowing down internet throughput
  • mon2
    • 14632
    Hello. Coming to you from the laptop forum. Have a client with the Fortinet 50E that has 320 Mbps as internet input speed but only 20 Mbps output on each and every downstream port (using FAST.COM to benchmark).
    Reseller is stating the Fortinet is 'worn out' which does not sound logical at all unless the flash memory is 'worn out'. They, of course, want to sell another + onsite installation fees.
    Can anyone share feedback on this unit? What can cause this sluggish behavior. From our knowledge, this device is snooping on the traffic to halt viruses / hack attacks, etc. so is database driven.
    How can we restore this unit back to a proper working throughput? Many thanks in advance.
    • 31204
    check the caps.
    or monitor the network for packet errors.
    if the caps start to fail the electrical noise will start corrupting packets and they will need to be re-sent
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8327
      Also make sure you actually get 320Mbps from the modem! Not that you are blaming the wrong part! Never seen a “worn out “ Fortinet.
      • rogfanther
        • Jul 2006
        • 458
        • Brazil
        Also, check configurations. If the poor fortinet is doing a lot of checking in the traffic, that will slow things down.
        • mon2
          • 14632
          Thanks for the feedback. We applied the latest firmware onto this box and now this POS is operating @ 9 Mbps. Garbage. Will investigate further. The unit is at a doctor's office and is managed by Telus so we are the odd man at the wheel and trying to diagnose without proper access to the device (password restrictions).
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8327
            Are the pins in the Ethernet ports good and not bent? I wonder if it’s defaulting the cable to 10 Mbit or if it is really a software / or other hardware issue? So without that fortinet box you get full speed?
            • rogfanther
              • Jul 2006
              • 458
              • Brazil
              Something happened along the time the problem started ? Like, someone changing configurations, electrical problems in the place, new cabling installed, etc ?
                • 31204
                if it's "managed" by a company then tell the fuckers to sort it - they are being paid to do so!
                • mon2
                  • 14632
                  1000% agree. Telus wants $800 to sell them a new unit + $1000 for an onsite installation fee (Toronto driving to our city = ~3.5 hour drive). After some strong arming, the customer did get Telus to remotely upgrade the firmware to the latest (thanks SMDFlea for the suggestion) but the throughput fell to the reported 9Mbps. This is a new low. Each of the 5 ports are benchmarking at the same slow speed. Cogeco has their modem feeding into this VPN with a Cisco unit between. Cogeco (series 860) has pinged their modem and the Cisco unit and confirmed their devices are @ ~300Mbps till the traffic hits the Fortinet. Being a doctor's office, Telus has to be involved for this VPN and only they can alter the configuration.
                  Cogeco has assured us they can remotely ping their 2 pieces of hardware in front of this Fortinet and are benchmarking this data rate. To date, with us, Cogeco has never been wrong on such claims.
                  • mon2
                    • 14632
                    Given that the same hardware setup degraded to 9Mbps from the original 20Mbps after the firmware update, perhaps some more rules are being checked by this VPN?
                    To date, we have used fast.com as our test tool. Is there a better method? The customer was complaining about the slowdown of the internet and this website confirmed the slow throughput. For an office, this is like Morse code slow.
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8327
                      Did you try flashing back a very old firmware to the fortinet and factory default everything? As far as a speed test made by the ISP, I’ve rarely seen accurate testing or repair methods, unless they send a senior that knows what he is doing. So unless you can verify that claim yourself or can look that person over the shoulder, I’d take their word with a grain of salt.
                      as for speed check tools google “Speedtest” and you find quite a few. The test depends also on how far the server is away. Some servers are faster than others.
                      Also on some devices like fortinet and other routers there is something called IPS and whatever else “inspection” there are many threads on Google. Search for “fortinet slow”. Tons of chit to read about this cheese box
                        • 31204
                        unplug the box, plug in a laptop and download the biggest file you can find - like a Linux dvd image.
                        see how fast it is.
                        the issue with ping is it checks latency and not true speed.
                        to check speed you have to move enough data to fill the buffers
                        • mon2
                          • 14632
                          Thank you all for the support and feedback. The case was resolved today and Telus ended up being hired to replace the unit with a new one with an onsite installation ($1800 CAD). They continue to claim these boxes wear out after 4 years. The doctor's office still has the older unit and we hope to investigate further on whether the fault is in the hardware or something else. They spent 4 hours on this setup of the box and the end result is that the expected speed is finally back to the ~300 Mbps. Cogeco benchmark was correct as they had claimed. Due to liability issues this client must retain the services of Telus but we can certainly review the condition of the original hardware. Will update this thread after the review. Thank you all again.
                            • 31204
                            is Telus an israeli company?
                            "tell"-"us" ??
                            kind of sounds like the company doing all the phone billing in the u.s. that got outed after 9/11!
                            that was AmDocs btw.
                            "American" "docs" ??
                            they love to give it away in the names!
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8327
                              I would have told them to take their new fortinet and shove it 1800 times every 4 years. The fortinet is good, but not $1800 every 4 years good.
                                • 31204
                                well are you allowed to open the old one now for a visual inspection of the caps?
                                also, as the old one is decomisioned they should have reset the password or told you it.
                                • mon2
                                  • 14632
                                  The vendor (Telus) is quite fishy. Telus is keeping the old equipment password locked and insisted to the client to retain it as a backup for the future. Respectively, Telus does not want us to open up the unit to maintain the certified box status for their sensitive data. Once again, we are locked out of the review. Clients like this one are often held hostage by their suppliers. We do not agree with such nasty business tactics.
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 8327
                                    Huh? What’s the old one good for if it does only 9mbps? Makes no sense.
                                      • 31204
                                      fuck telus - send me the main pcb and i'll pull and dump the flashchip.
                                      passwords for everybody!
                                      serve them right if they only use one globally!!!!!
                                      get the top off and take pictures - it's not theirs and never was.
                                      wouldnt it be interesting if it's forwarding to an external address!!!!!!
                                      • CapLeaker
                                        Leaking Member
                                        • Dec 2014
                                        • 8327
                                        Would I ever be tempted to flash the shit out of it and make Bob my uncle.
                                        • harp
                                          piezo worn out issue
                                          by harp
                                          I wonder if it is real, or missleading some other problem? ?............... https://m.youtube.com/watch?v=ceb09rxPohA ?....... in video is presented claims that new piezo fix problem of poor production of moist, what is electronic science stand behind that conclusion? Can piezo be worn out and hot to tested it for that condition.............. in the past I see video where is piezo torturing through test vith high voltage, various frequency, and it is amazing what can survive and operate after damaged.
                                          10-13-2024, 03:40 PM
                                          AD7276, AD7277, AD7278, AD7274, AD7273​ Datasheet
                                          The AD7276, AD7277, AD7278, AD7274, AD7273 are 12-bit/10-bit/8-bit, high speed, low power, successive approximation analog-to-digital converters (ADCs), respectively. The parts operate from a single 2.35V to 3.6V power supply and feature throughput rates of up to 3 MSPS. The parts contain a low noise, wide bandwidth track-and-hold amplifier that can handle input frequencies in excess of 55 MHz.
                                          The conversion process and data acquisition are controlled using CS and the serial clock, allowing the devices to interface with microprocessors...
                                          10-07-2024, 05:32 AM
                                        • TrumanHW
                                          A1708 13 MacBook Pro Fn WiFi stops working | Turn OFF-ON WiFi = Temp Fix (1-6 min)
                                          by TrumanHW
                                          WiFi menubar symbol shows hardware stays connected (even when issue occurs)
                                          WiFi adapter shows normal connectivity symbol & stats: Using Opt+WiFi shows:
                                          • Tx Rate: 867 Mbps
                                          • RSSI: -44 dBm
                                          • Noise: -90 dBm (same as working MBP connected to same router)
                                          After ~1 min - 7 min, connectivity is lost (no traffic works) until I Disable / Enable WiFi (temporarily fixing again)
                                          Inspected Antenna connections (look secure) & UP / DL is quick when working (same as good laptop)
                                          • DL = ~400 Mbps
                                          • UL = ~17 Mbps...
                                          09-06-2022, 10:45 AM
                                        • Peterpies
                                          How to repair ffc connector on microwave panel
                                          by Peterpies
                                          I have a sharp microwave front panel connectors which link to the motherboard via ffc strips into push in connectors, see images, the connector strips are worn I have cut them back but they still don’t make a good connection any ideas how I can overcome this would be appreciated. All switches on panel which are touch type work fine, have thought about conductive pen or paint anyhelp appreciated....
                                          09-21-2025, 10:29 AM
                                        • w1nk0
                                          Thinkpad X1 Carbon 5th Generation DX120 NM-B141
                                          by w1nk0
                                          Hello!
                                          I'm looking for help with Thinkpad X1 Carbon 5th Generation DX120 NM-B141:
                                          - no image
                                          - fans spins for second or two (not sure why once it is second and once its two or smth)
                                          - keyboard and power button lights for split second
                                          Not sure about SN because sticker got worn after time.
                                          Any help would be appreciated!...
                                          07-07-2025, 05:27 PM
