schematic for askey rtl0010vw
  • deepdarkfantasy
    DeepDarkFantasy
    • Dec 2023
    • Iceland
    I need schematic for
    "ASKEY RTL0010VW"
    router.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    What’s wrong with it? What does or doesn’t it do?
    • Russ1
      Starlink GEN2 Router Internal Power Supply Chicony UTP-211C Schematic
      by Russ1
      Sick of seeing big numbers of these routers dead no power light underneath.....
      Chasing Schematic of this power supply I have searched high and low....
      Already spotted a few swollen caps, but Ac fuse ok.....
      This is a dual output 50Vdc 2.5A and 12Vdc 1.25A psu
      Can anyone help with any type of schematic and parts list ?
      Thanks and Regards, Russ
      07-10-2025, 11:01 PM
    • 2elw
      (Move please wrong category!) HP Elite x2 G4 (EMP20 LA-G931P) schematic/boardview
      by 2elw
      Hey,
      Does anyone have a schematic or boardview for the HP Elite x2 G4? Motherboard shows "EMP20 LA-G931P". I've gotten 200 of these from my employer to unlock and its been hell since the EC rom is on the back of the board, im trying to find test points or any way to communicate to the EC or its rom without having to dissasemble the whole thing just to get to the back.
      Thanks.
      07-03-2025, 02:33 PM
    • cheeky2
      Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
      by cheeky2
      This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
      I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
      Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
      06-15-2025, 05:12 AM
    • ShadowAi
      ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
      by ShadowAi
      Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
      Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
      After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
      03-15-2024, 10:46 AM
    • windorey
      Help me troubleshoot my Aspire A715-75G's display connector
      by windorey
      My Aspire A715-75G's display cable got snapped,
      I thought a cable I have from an Aspire A315-56 would be compatible, seeing the same pinout in the schematic.
      Very stupidly, without checking boardview files, I just connected my cable to my LCD panel and to my motherboard and suddenly the cable became very hot, and let out the magic smoke.
      I have realised that the pinouts are the same, but mirrored, so I plug in the cable in reverse ( to mirror the pins ), but the motherboard doesn't turn on at all with it plugged in.
      When the cable's...
      01-26-2024, 10:18 AM
