P400 Broken Packets, 1/4 speed internet :-(
  • bodhibody
    • Oct 2013
    • 27
    Hi I have recently got a Lenovo P400 and I did a speedtest on it with my wifi after I got it and it was about 4MB/s (30Mbps) which is 1/4th of my usual speed.
    The worst:
    My tabs instead of loading all at once I have to load each of them one at a time because some of them do not load (too many connection attempts and network packets discarded?). :-/
    I would tolerate the 1/4 speed reduction but the above problem is horrible. Sometimes I will click on a page and it will load only text or only part of a page! I have to click reload and it'll load the page.
    Any ideas on how to fix this? I've uninstalled my antivirus, uninstalled and reinstalled my latest wifi drivers, doing speed test each time.
    I'm doing a malware scan now and it showed 2 things detected... still running.
    More info:
    --I'm running Windows 8 64bit
    --My other computers when speed test done shows 30-40Mbps
  • bodhibody
    • Oct 2013
    • 27
    Re: P400 Broken Packets, 1/4 speed internet :-(
    It wasn't any malware. Just two trainers for games.
    Thinking all this may have something to do with the way packets come to this computer...
    And I forgot to mention that the speed is what it is supposed to be (30Mbps) on the other computers at my house including my phone -_-'
    • joshnz
      • Feb 2011
      • 969
      • New Zealand
      ping gateway to see if you loose packets.
      My pc
      CPU : AMD PHENOM II x4 @ 3.5Ghz
      MB : ASUS M4A89TD PRO USB3
      RAM : Kingston ValueRAM 16gb DDR3
      PSU : Cooler Master 850W Silent Pro
      GPU : ATI Radeon HD 6850
      • bodhibody
        • Oct 2013
        • 27
        No bytes lost.
        And that was weird. Downloading a test porn file off piratebay fixed my internet connection.
        From 5mbs to my good 'ol 30mbs+.
        I clicked "forget connection" and when reconnecting I changed to "turn off sharing."
        I think this may have been the entire issue.
        Ugh nevermind. It keeps going back to ~10mbs after I reconnect.
        I notice that the signal is "very strong" and at 180-300mbs when I get my 30mbs+
        whereas "strong" and ~"150mbs" when I get ~15mbs.
        Edit: nevermind that's wrong too and varies
        OH well. It's good now for the next hour I guess. At least I know to reconnect when I need fast internet. :-/
        Lame that this doesn't happen on any of my house computers or phones. All get stable access to that full blast 30mbps. Mind be a wifi card thing on this new laptop.
        • bodhibody
          • Oct 2013
          • 27
          So yeah to conclude this thread:
          My 1TB HD RPM is 5400 (slow) and I've been doing a lot of PDF processing/program installing/uninstalling in the BG whenever I'm testing my internet on and off.
          My HD was getting USED to the max.
          That's basically why the internet was slow sometimes and fast sometimes, the test files themselves couldn't load onto my computer fast enough.
          I've gotta get a SSD. Maybe next year they'll have 500GB SSD for $100.
          • bodhibody
            • Oct 2013
            • 27
            Also FYI if your pages get broken in Chrome, make sure to disable "predict network" option in advanced settings. The prediction itself slow it down.
            • tmiha71
              • Apr 2010
              • 130
              No bytes lost.
              How about "Lost waves!"
              Ping says nothing, except that connection can be established...
              I would try to find better position for laptop, to rule out "deaf corner", or problematic position...
              If there's statistics (some wireless nic-s have it), look at
              - retransmitted packets, that can be reason for low throughput...
              - packets received with CRC-error, can be reason for low throughput...
              If better position could not be found, than sw-problem, or hw-problem...
              • AJ847.63e
                Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                by AJ847.63e
                Hi Folks,
                Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                05-06-2025, 10:37 PM
              • chth96
                Is it possible bridging tiny broken trace
                by chth96
                When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                cutting tiny trace.
                This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                12-03-2022, 11:32 PM
                FUJITSU ESPRIMO P400 ESPRIMO P G630 Specification for Upgrade or Repair
                This specification for the FUJITSU ESPRIMO P400 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ESPRIMO P400 boardview and ESPRIMO P400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for FUJITSU...
                09-12-2024, 03:44 PM
                HP Elite x2 1012 G2 + Elite Presenter Mouse + Essential Top Load Case Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                This specification for the HP Elite x2 1012 G2 + Elite Presenter Mouse + Essential Top Load Case Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1012 G2 + Elite Presenter Mouse + Essential Top Load Case boardview and 1012 G2 + Elite Presenter Mouse + Essential Top Load Case schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                09-06-2024, 08:20 AM
                HP ProBook 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                This specification for the HP ProBook 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse boardview and 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you...
                09-06-2024, 06:21 AM
