D-Link Power Supply "AF0605-E"
    Just wanna share this with you guys: In past years I have had a few of these wall warts (5V / 1.2A) that come with many D-Link products on my desk. The faulty part was ALWAYS the output filter cap which is a TEAPO SY series 10V / 680uF (8x15mm).
    I recommend Panasonic FR, FM or FC as replacement.
    The case does not have any screws, hooks or clips. Just use a vice and some cloth. Apply pressure where the upper and lower part are glued together and the housing will pop open easily.
    Re: D-Link Power Supply "AF0605-E"
    Yeah, sealed case, lots of heat ... not much you can do, things go bad in time.
    FR series from Panasonic is rated for up to 10000h @105c depending on the capacitor case (diameter+height)
      If there's a start-up cap in there, make sure to replace that too while you have the adapter open (if the cap is from a bad brand, of course - which it probably will be).
      I always keep a stock of 4.7 uF, 10 uF, 22 uF, and 47 uF 50V caps handy. A lot of cheaper power adapters develop start-up cap related problems over time.
