.LAN domain on network devices
  • japlytic
    • Oct 2005
    • 2086
    Some manufacturers use a ".LAN" domain on network devices, mainly those intended for home or SOHO applications, to make it easier to find and configure.
    It is highly unlikely that the Internet would ever use a ".LAN" domain.
    Caution should be exercised when using a domain name on network devices, which means if there are two or more devices with the same domain name on the same local network e.g. www.mywirelessrouter.lan (and enter this into your web browser), problems can occur.
    This problem can be prevented by adding the last 6 digits of the MAC address to the domain name of the network devices.
  • mattch
    • Mar 2010
    • 121
    Re: .LAN domain on network devices
    that "feature" drives me NUTS, netgear has the same thing www.routerlogin.com
    It manipulates standards to make things easier which i find LAMEx10.
    I typically disable that, some AMPED have option to disable, others, well just sucks.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      I like the routerlogin thing... except on mine it's .net
      Cool thing is, they have both the domains for real, which redirect to their support site.
      Now WTF is up with charging money for support? lol
      • seanc
        • Nov 2008
        • 1319
        Well there's the default 192.168.0.1 which always works if you're running on the default range and Netgear Firmware, but I'm running on DGTeam firmware on a 192.168.5.0/24 range.
        • smason
          • 1652
          I don't see why they bother with a name or bogus domain, it's a local network device, just use the IP address.
          • Agent24
            I see dead caps
            • Oct 2007
            • 4978
            • New Zealand
            The Thomson I'm using has a ".Local" domain...
            But the firmware is so shitty you can't even disable that 'feature'
            -David VanHorn
            • howardc64
              Samsung UN55JU650DF network/streaming problem
              by howardc64
              Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
              This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
              07-09-2025, 12:44 PM
            • davg
              Home network connection problem
              by davg
              I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
              03-06-2021, 07:13 AM
            • harp
              simple win network with optimization issue
              by harp
              simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
              06-23-2025, 11:01 AM
            • muhuruu
              PS5 too many USB devices connected
              by muhuruu
              Hello. I have a problem with a PS5 console that I bought to learn electronics repair. The auction description indicated that the console had been dropped. The HDMI port and USB ports were damaged. The HDMI port was replaced by the previous owner, and after his repair, the console worked for 2 days and then became dead. After receiving the console, I replaced all the USB ports. After replacing them, the console started to turn on. On the logo screen, it displays "too many USB devices connected". My further attempts to fix the error involved replacing the Southbridge, 4 TPS2001D chips,...
              05-19-2025, 07:14 AM
            • dqtech
              Lenovo Yoga 12 LA-A342P usb not detected but does charging devices
              by dqtech
              this laptop has been done by other tech...he did replace new usb port but problem still persist and early problem is both usb port not detected thumbdrive but it does charging device/phone...i need help to diagnos this problem
              here the link for schematic - https://www.badcaps.net/forum/troubl...42p-schematics...
              03-15-2025, 09:59 AM
