Dell 2007WFP Won't Power On
+ More Options
Posts
  • Ritalin
    • Sep 2010
    • 194
    #41
    Re: Dell 2007WFP Won't Power On
    @peterfares (if you still are watching this post): One thing you might want to fix (and I don't know if you did or not) is to resolder the plug in. I picked up this monitor for free on craigslist and replaced all the capacitors and it somewhat worked, I noticed that this was completely coming undone and resolder it and it now works 100%!. And yours looks like it might be starting to do that as well.
    @core2kid: Make sure to check for cold soldering, as now I've seen 3 different monitors have this issue. (On top of what retiredcaps/PlainBill said)
    • core2kid
      • Jan 2011
      • 15
      #42
      Are there any specific areas I should be checking for cold solders?
      I don't have any idea where to start to even look for the voltage regulators. I have an idea of where the diodes are though (Are they the two by the 12v power connector?
      How do I check them with a digital multimeter?
      Here's some pics of my board. Do you all need better pics or pics of the back? If so, I'll be able to post better pics that I can take in daylight.
      • Ritalin
        • Sep 2010
        • 194
        #43
        Yes, we'd like to see both sides of the board and in better light, keep in mind we're looking at rather small parts through the computer. So make sure the whole board takes up the picture.
        • core2kid
          • Jan 2011
          • 15
          #44
          Sure thing, I'll do it tomorrow afternoon after college. Thanks again for helping me out!
          • retiredcaps
            • Apr 2010
            • 9271
            #45
            1) Voltage regulators (U designation) can be bad. They can be shorted or output the incorrect voltage. The test described below only tests the former.
            If you have a manual range multimeter, set it to 200 ohms (two hundred). You can test voltage regulators "in circuit" for shorts by (power off and unplugged)
            a) black on pin 1- red on pin 2 - record ohms
            b) black on pin 1- red on pin 3 - record ohms
            c) black on pin 2- red on pin 3 - record ohms
            If any ohm reading is less than 30 ohm you might have shorted voltage regulator. Remove from circuit and repeat the tests to verify.
            2) To test a diode in circuit,
            a) put your multimeter in diode test mode
            b) put your black lead on one side and the red lead on the other - record reading
            c) reverse the leads - recording reading
            A good diode should read 0.4V to 0.7V in one direction and 0L in the other. If you get a reading in both directions, you will have to desolder one leg and retest to verify.
            3) PLEASE follow the instructions in PlainBill's signature on how to post pictures so they are posted here and please don't post inline.
            --- begin sig file ---
            --- end sig file ---
            • core2kid
              • Jan 2011
              • 15
              #46
              Sorry for the delay all, I'm still waiting for a good sunny day when I can take pics. I've been hit by the east coast storm and I haven't had a good sunny day yet, just dull days :/
              I'm hoping to have pics for you tomorrow.
              • core2kid
                • Jan 2011
                • 15
                #47
                Here are some pictures of the board.
                • Ritalin
                  • Sep 2010
                  • 194
                  #48
                  Not that this is the fix, but is that some cold soldiering on the upper left picture of the back side of the power board?
                  • core2kid
                    • Jan 2011
                    • 15
                    #49
                    I tried to reheat most of the solder points, maybe I missed that one. I'll try it tonight and post back.
                    I can however say that occasionally it'll power on for 2 seconds and then start flashing.
                    • core2kid
                      • Jan 2011
                      • 15
                      #50
                      I resoldered that and it didn't work. Any other suggestions?
                      • jetadm123
                        • 2169
                        #51
                        Try checking the fuses circled below. With power off and your meter set to resistance, place your probes across each fuse. Reading should be around 0 ohms.
                        • core2kid
                          • Jan 2011
                          • 15
                          #52
                          All the fuses read .00 to .02 Ohms, they also show continuity. Could one of the capacitors have failed?
                          • core2kid
                            • Jan 2011
                            • 15
                            #53
                            Sorry to bring this old thread back to life but I'm still trying to get this monitor back up. I'm using a CRT for now. Any ideas on what may have failed of the USB board?
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              #54
                              See post 45 to test the voltage regulators and diodes.
                              Are you saying that if you hookup a working computer with your favourite wallpaper that the computer shows the wallpaper for 2 seconds and then go to black?
                              If yes, you could have
                              a) bad capacitors
                              b) bad inverter transformer
                              3) bad ccfl
                              4) bad ccfl wiring/soldering
                              For the all of above, see starting with post #13
                              https://www.badcaps.net/forum/showthread.php?t=10419
                              • core2kid
                                • Jan 2011
                                • 15
                                #55
                                I have 2 of these monitors, one is my dads and this one was mine. Basically when it went out, I replaced the USB board with one from a known working monitor and it worked fine. That rules out #3 and #4.
                                About it working, occasionally it'll work but it'll only go as far as to turn on the backlight for a second and then it'll go off. This happens about 5% of the time.
                                All capacitors aren't bulged out or leaking. Could they still be bad?
                                What's the inverter transformer?
                                • jetadm123
                                  • 2169
                                  #56
                                  One thing you could try is measuring the voltages at the power connector of the usb board. It looks like the pins are labeled 1-6 and 7-12. Try measuring the voltages with the "good" board installed and again with the "bad" one installed. Also, measure voltages while pushing the on/off button on the front panel. Compare the voltage output of the two boards. If you find a major difference, then try to trace what that pin is connected to.
                                  Yes, a cap can be bad. However, since you have no way of testing them, you'd be replacing them based on a "hunch".
                                  • core2kid
                                    • Jan 2011
                                    • 15
                                    #57
                                    Okay, i'll work on replacing the caps first. Can I test a cap with a multimeter?
                                    I don't want to take apart the other monitor at the moment, my dad needs it every day and if something goes wrong, I'm dead...
                                    • jetadm123
                                      • 2169
                                      #58
                                      Other than a dead short, you will not be able to test cap with a DMM. Replace with good quality caps like panasonic FC or FM series from digikey.com.
                                      • chad720
                                        • Jan 2011
                                        • 16
                                        #59
                                        Hi there! I´m also trying to repair a 2007wfp dell monitor, had replaced a shorted J598 mosfet, and the two diodes S4 62A (with similar FU4007: 1000V, 1A, 75ns) (one of the S4 diodes was shorted) and also the 3A fuse.
                                        But the result is that I still get a short and is caused by the ZD701 (very little zener diode, the only one on the pcb)
                                        Does anybody know of a proper replacement? I can´t get to figure wich voltage is it suposed to work with, guessing for the size that it´s a 1/4W diode.
                                        Thanks for your wisdom!
                                        Chad
                                        PW: I think pcb voltages are 19V and 5V for the usb, but do not know if there´s another/s.
                                        • PlainBill
                                          • Feb 2009
                                          • 7034
                                          Chad
                                          Earlier today I saw this thread. The gentleman provided a good description of the problem, just like you did. He ALSO provided pictures and a datasheet. This changed a 10 or 20 post problem into a simple analysis.
                                          The best solution to your problem is to identify the zener diode. Many SMD components have a two or three character marking code on the device. With that information, identifying it becomes easy.
                                          PlainBill
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • Borse2008
                                            Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                            by Borse2008
                                            Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                            I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                            • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                            • There’s
                                            07-15-2025, 04:55 AM
                                          • Mark01
                                            Dell Optiplex 7490 AIO - red power led after flash
                                            by Mark01
                                            Hi guys,
                                            This is my first post! 🚀
                                            I have no idea what I’m doing, but I’m learning by trial and error.
                                            I’m currently working on a Dell Optiplex AIO 7490—one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
                                            07-04-2025, 12:54 PM
                                          • zlr8r
                                            Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                                            by zlr8r
                                            hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                                            Ill try and give as much info as I can.
                                            Dell Inspiron 17 (7786) Laptop
                                            Service Tag: 5J0NHT2
                                            Bios: 1.9.0
                                            When I received this , it would only flicker on the KB backlight for a second, then off and on.
                                            Then it started getting weirder!
                                            Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                                            12-12-2023, 09:31 PM
