CMV CT-934D won't power on - secondary voltages disappear
  • retiredcaps
    • Apr 2010
    • 9271
    CMV CT-934D won't power on - no power LED
    SUMMARY
    This is a CMV CT-934D made in 2004 LCD. It won't power on. The power LED does not turn green.
    THINGS TESTED
    1) Measured steady 164V DC across main filter capacitor.
    2) With the power board ONLY (i.e. logic board is disconnected), the secondary voltages 19V and 5V DC are present at connector location CN100. The 19V and 5V DC voltages are steady and do no fluctuate.
    3) Fuse FP1 on logic board reads 0.3 ohms.
    4) All connectors from power board connector CN100 to logic board location CN2 read 0.3 ohms. That is, the connectors are fine.
    PROBLEM
    1) Press the power button and the power LED does not come on.
    2) When the logic board is connected to the power board, the voltages found at CN100 disappear. The 5V DC disappears immediately. The 19V DC drops slowly from 19V to 0V. I can see the voltage dropping on the multimeter. It drops about 1V every 5 or 10 seconds. The voltages at CN2 on the logic board show the exact same behaviour as CN100 (drop and disappear).
    QUESTION
    What could cause the secondary voltages to drop/disappear when the logic board is connected to the power board? When the logic card is disconnected, the secondary voltages are solid and steady on the power board.
    --- begin sig file ---
    --- end sig file ---
  • PlainBill
    • Feb 2009
    • 7034
    Re: CMV CT-934D won't power on - secondary voltages disappear
    SUMMARY
    THINGS TESTED
    PROBLEM
    QUESTION
    Probably a short on the 5V rail on the logic card. Most monitor power supplies use a transformer with three secondary windings. One secondary (I often refer to it as a tertiary winding) powers the SMPS controller. Another is rectified to provide 5 volts. The last winding is rectified to provide the inverter voltage - anywhere from 12 to 20 volts, depending on design. On an SMPS design with current limiting on the primary an excessive load on a secondary will cause the SMPS to shut down. Because there is very little load on the 19V supply, it's voltage drops slowly.
    Now you have the fun of locating the short on the logic card. I would suggest investigating the four voltage regulators, U8, U10, U12, U13. If it turns out I am wrong (it happens) and there is no short, investigate the small capacitor in the SMPS primary.
    Edit: Interesting, I just noticed there are TWO optoisolators on the power supply. How interesting. What, pray tell is U101 on the power supply?
    PlainBill
    • retiredcaps
      • Apr 2010
      • 9271
      PlainBill
      I measured the ohms on U8, U10, U12, and U13. U10 with red on pin 1 and black on pin 2 measured 146 ohm (I measured this 4 times). All other voltage regulators readings were well over 800 ohms.
      Pin 3 of U8 and U10 are tied to the 5V rail. I figured this out by using the continuity beep test by probing around.
      On the CN110 connector (read vertical down), the 2nd pin is GND, 3rd is 5V and last pin is 19V.
      The small cap at CE107 was the first thing I replaced when I didn't get secondary voltages (before I discovered it was stable without the logic card). The original cap was a Capxon 22uF 50V.
      I replaced it with a Samxon GK 22uF 25V. When I first replaced it, I didn't realize my mistake of substituting in a lower voltage cap. It wasn't until I went to write this response and checked the original cap that I had made this mistake.
      Anyways, I don't have a 22uF 50V spare. And I had the same problem of disappearing voltages before with the original Capxon cap. If I had to, I could try and see if one of my working boards has a 22uF 50V that I could borrow to figure this one out.
      U101 is LM358 PBGP. Datasheet is at
      http://www.datasheetcatalog.com/data.../5/LM358.shtml
      PS. I also changed out 2 caps that were rated 10V (all others are rated 25V), just to rule out bad caps on the 5V rail. I used Rubycon MCZ and Nichicon HN(M). Same problem with disappearing voltages.
      • PlainBill
        • Feb 2009
        • 7034
        The lower voltage cap shouldn't be a problem. Many manufactures don't make 22uF caps in the lower voltages.
        On this one, I would suggest tracing the outputs of the two optoisolators. One should be used for feedback for voltage regulation. I just came across an application note that used a second optoisolator to shut down the SMPS controller.
        PlainBill
        • pedro
          • 199
          • AUSTRALIA
          More important is to identify the voltage at their pins - looking for one (or more) with an output dragged down to ground or similar.
          Friends don't let friends buy Samsung ....
          • retiredcaps
            • Apr 2010
            • 9271
            Can you send a link for that application note? I'm having a tough time finding the datasheet for PC617?
            U100 and U103 (optoisolators) is part
            B T2
            PC617
            Sharp
            Pins 1 and 2 are on the secondary side. Pins 3 and 4 are on the live power side.
            I tested both with the diode functionality on pins 1 and 2 and got 1.04 in one direction and 0L in the other. Pins 3 and 4 give 0L in both directions.
            I measured ohms between pin 1 and 2 and they are not shorted. Same for pin 3 and 4.
            I'll do the trace.
            All the diodes on the back in that section test okay.
            ZD102 measures0.72 and 0L with the diode test.
            D102 measures 0.59 and 0L with the diode test.
            ZD101 measures 0.72 and 0L in the diode test.
            • retiredcaps
              • Apr 2010
              • 9271
              I'm not sure I completely understand what you are asking, but the input and output pins of all the voltage regulators on the logic card measured 0V I if remember correctly. This would make sense since the 5V disappears right away.
              • PlainBill
                • Feb 2009
                • 7034
                B T2
                PC617
                Sharp
                I'll do the trace.
                The PC617 is a jellybean part. Equivqalent part numbers for the optoisolator are LTV817BM and PS2561L1-1-VW. It's an LED facing a phototransistor with an insulating material (glass?) separating them. As the output voltage increases, the current through the LED increases. This causes the phototransistor to turn on, increasing the voltage on the feedback input of the SMPS controller.
                I'll try to figure out what power supply schematic I was looking at with the dual optoisolators.
                PlainBill
                • PlainBill
                  • Feb 2009
                  • 7034
                  Remember, this application note is for what may be a different SMPS controller (you didn't mention (and I didn't ask)) what that part number is. However, it describes something similar to what this monitor has. Look at the circuit on page 10, particulary the part in blue.
                  PlainBill
                  • pedro
                    • 199
                    • AUSTRALIA
                    Ah, I was hoping that the death of the 5V was "fast but not instantaneous", so that by monitoring the various reg outputs you might see a transient reading on some (but none on the culprit with the shorted output).
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      PlainBill
                      Thanks.
                      The concept is what I'm trying to understand first. I'll study it and see if I can take it to the next level.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        When I hit the switch on the power bar and get the probes in place, the 5V rail is already down in the 0.35V range. And I don't think my multimeter is that fast to capture a 5V -> 0.35V drop.
                        • pedro
                          • 199
                          • AUSTRALIA
                          If you can't get the probes pre-connected (i.e. solder a short stub onto a relevant track) what I would do - and it comes with the usual caveat(*) - is to put an external current-limited (but not foldback) 5V supply onto the video board, and "smoke out" the fault. By allowing it to pull a decent current the offending device can often be located. The monitor's PSU states 2.5A @ 5V, so I'd start with something less than 0.5A and see what gets warm to touch. You DO risk blowing a voltreg if its load is the short and it can't handle the current/power into the short, but it DOES help to locate the short. The only other route that works for me is to start lifting voltregs - either totally or one of the I/O legs - and see when the short disappears.
                          (*) "THE PERSON IS A TRAINED PROFESSIONAL - DO NOR TRY THIS AT HOME"
                          • lucky13
                            • Aug 2007
                            • 412
                            Retiredcaps,
                            Did you check these CrapXon caps on the p/s for ESR and capacitance? They don't look domed but you say this monitor was made in 2006.
                            If the logic board regulators are OK (i.e., not shorted), then go ahead and try with a current limit p/s and feed 5V to the logic board.
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              Go ahead and replace the caps anyway - i've had a similar issue on LG monitor (power supply would shut down when the display board was plugged in, but running the CCFLs alone worked fine) and all there was to it was the caps. If it still doesn't work, at least you ruled them out.
                              A working TV? How boring!
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                Originally posted by lucky13
                                Retiredcaps,
                                I don't have an ESR tester. I did replace all caps that were on the 5V rail, but not on the 19V rail. The capxon are all 25V rated which I assume is on the 19V rail.
                                I may try and left the legs off the regulators to see if I can narrow down the short.
                                I tested the voltage regulators in an earlier post and none are shorted using a resistance test. If you have another multimeter test to suggest on the voltage regulators, let me know.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  Thank your for sharing. I'll keep it in mind.
                                  One reason I'm hesitant to change the caps right away is I'm trying to learn more about the sense circuitry. I'm in no rush or need to fix this monitor quickly.
                                  It could very well be the caps causing the problem, but I want to see "proof" through detective work and inference rather than just a "blind" cap job.
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    Well, if you don't have an oscilloscope to actually see what's happening there isn't much to learn by just looking at the board. When i changed the caps in that monitor the result was visible on the scope - a dramatic reduction in ripple on the 5v rail.
                                    I've worked without a scope for quite a while, but at one point i decided that i can't work like that anymore (that was a few months ago, when i decided to get into SMPS stuff seriously), and spent $120 on an old Russian scope. It's built like a tank (also about as heavy as one but oh well...), works up to 100-something MHz, and the seller also gave me the full service manual and schematics for the thing. I also bought some 50-ohm coax and a couple nice BNC connectors, and 3 hours later i had my own 1x and 10x probes without spending another $25. The body of the 1x probe is a mechanical pencil, for the 10x i had to use a marker as the voltage divider wouldn't fit in anything smaller. :p
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      So today I replaced the caps one at a time and then retested for disappearing secondary voltages. I hate recapping all and if it works not knowing which one was faulty.
                                      By repeating the above process, I eventually recapped all the caps on the power/inverter board and I still get disappearing voltages.
                                      All caps I used are new Rubycon low ESR caps (ZL or MCZ).
                                      I'm not giving up though.
                                      • Rtech
                                        • Jul 2010
                                        • 1095
                                        Although 'logic' says the fault is on the 'Logic' PCB(pardon the pun..).I assume that if you had another Logic PCB,you would have tried that to confirm that is the case ????.
                                        A situation that can occur with any Power Supply,is that although a Meter can measure the Voltage outputs ie NO Load,,,when a Load is applied the Voltage disappears,as the PSU cannot supply the Current requirement,even though there is NO shorts in/on the Load itself.
                                        I have done a few measurements this morning,and perhaps the following may be of interest:-
                                        Set up the PSU/Inverter ONLY..ie NO Logic PCB,Plug in the CCFL's,and on the connector which normally goes to the Logic PCB,apply Approx 3volts DC(from an external battery perhaps),between the ON/OFF pin and Ground.This will light the Lamps.HOWEVER I had lying around a little PC Fan,a Standard 12v,250Ma one,and a little experimenting showed that applying 12v to it, it actually took 62Ma,BUT applying
                                        5V to it the current increased to approx 160Ma,So with the Set up as above,if you have a Fan,or similar, put it on the same connector between the 5v pin and Ground.The question is DO the CCFL's light ???and the Fan spin ???
                                        • tomodachi
                                          Lenovo Ideapad Gaming 3 15ARH05 NM-D191 processor voltages disappear at startup
                                          by tomodachi
                                          MB schematic and boardview
                                          https://www.badcaps.net/forum/troubl...86#post1802186
                                          This one came in with no display complaint.
                                          MB powering up with all CPU coil voltages of CPU and GPU present, appear to be drawing around 1 to 1.8 amps on boot cycle, then in 3 seconds CPU phases on PL3003,PL3002,PL3001,PL3000 disappear, leaving MB drawing only 0.25 amp with GPU core voltages still on.
                                          Trying to...
                                          10-03-2024, 04:21 AM
                                        • Capacitorial
                                          Powersupply has all the voltages - Monitor still no power
                                          by Capacitorial
                                          Hello guys,
                                          I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                          I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                          On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                          The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                          The weird thing is, that the Power LED is powered over the TCON board.
                                          On The TCON...
                                          12-28-2024, 02:12 PM
                                        • gjgib
                                          Help reading schematic voltages input/output
                                          by gjgib
                                          Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
                                          I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
                                          I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
                                          I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
                                          05-06-2024, 08:11 PM
                                        • RossMoodley1967
                                          HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
                                          by RossMoodley1967
                                          Hello
                                          Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
                                          Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
                                          03-01-2024, 06:07 AM
                                        • lol999
                                          Asus Prime x299 Deluxe - no VCCIO VCCSA voltages
                                          by lol999
                                          Motherboard after starting show Q code 00.
                                          No shorts on any rail ( at last I can't finde any)
                                          All voltage are correct on SIO - 3.3V, PCH power 1V , DDR 1.2V, SPI 8 leg 3.3V
                                          Nothing get hot, PSU starting, all lights came ON....
                                          One thing i can see incorrect is no VCCIO and VCCSA voltages and no main power on CPU.
                                          After deep looking I found dead Synchronous Buck converter CSD97374Q4M that is powering VCCIO for CPU but after replacing it nothing changed. Voltages on it are correct....
                                          This buck converter is PWM'ed by Asus DigiVRM ASP1405I-62T. Can't finde any datasheet...
                                          01-21-2024, 02:25 PM
