H.P. vs19e good170vdc. no 5v or 12vdc
  • PlainBill
    • Feb 2009
    • 7034
    Re: H.P. vs19e good170vdc. no 5v or 12vdc
    Originally posted by alexanna
    I have verfied voltage on the three sm resistiors. starts out at 167 and I see 2.7vdc at the last one.Also 2.7 vdc at pin 3 of smps controller.This way above my head,What do we know at this point?
    Assuming the voltage at each junction of the resistors decreased linearly (112 volts at the junction of R912 and R915; 57 volts at the junction of R915 and R918), we know the SMPS controller (SG6841SZ) is bad; it can be replaced at a cost of $6.00, and that others have repaired monitors with the same symptoms and the same IC simply by replacing the SG6841SZ.
    If I had the monitor on my bench, the SG6841SZ would have been ordered, as well as the caps to completely recap it. I'd already be writing up the copy to sell it for $65 on Craigslist so I can free up the space and justify buying another 'toy'.
    PlainBill
    • alexanna
      • Mar 2010
      • 1346
      It is doing just as you describe. Thankyou for all the help,I feel i have learend quite a lot on this project.
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        Funny you mentioned that Plainbill, I just sold this same type of monitor for $57 on ebay. All I had to do was recap and it's back in service. I wanted it to be sold for more but ebay just isnt the way to go. Then there's shipping. Ugh.. Too much house traffic for CL, not safe here in Baltimore.
        It was a nice monitor though.
        • PlainBill
          • Feb 2009
          • 7034
          The supporters of SB1070 claim that Phoenix isn't safe, either. When I'm buying I would much rather go to the seller's home or place of business. Meeting in a K-Mart parking lot isn't conducive to a good business relationship.
          Still, to each his own.
          PlainBill
          • dkneyle
            Onkyo DX-V500 Laser Disc Player - weird SMPS fault
            by dkneyle
            This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
            Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
            02-01-2022, 02:08 AM
          • shamsudeen
            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
            by shamsudeen
            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
            i know that in linear power supply the noise will be very low comparing to SMPS supply....
            07-19-2025, 07:14 AM
          • abhishekkumar1902
            Huntkey HK340-72FP SMPS shut on load above 2 amps
            by abhishekkumar1902
            I have this Huntkey HK340-72FP PC SMPS where I am facing a strange problem where the SMPS shuts down when the load on any of its 12v output rails goes above 2 amps while the rating of each 12v rail is above 10amps capable.
            I have checked the following:
            1. All output caps are OK, and all output rails read correct voltages at no load
            2. All output diodes are OK
            3. NTC is ok
            4. Hi voltage cap on input correctly reads 150uF on LCR meter per the spec, also the bridge rectifier is OK
            5. No short in main switching MOSFET
            6. All other components...
            12-18-2022, 09:52 AM
          • madan1
            Mackie Th15 SMPS low Vout
            by madan1
            I'm troubleshooting a PA speaker Mackie Th15 (schematics attached).
            It is basically a smps with amp and some dsp.
            The issue is that on the secondary side I read +/- ~23V instead of the expected +/- 38V. Indeed all secondary side and feedback/aux rails are like 1/2-3/5 of the expected values.
            Q2, Q3, C35, C40, C33, C36, C41 and C42 were tested out of circuit with a component tester and read fine. Most of the other components on the primary were tested in circuit and seem to be fine. +HV to -HV on primary is ~330V.
            By the way, the ferrite core of L10 is broken,...
            02-16-2025, 04:15 PM
          • rewease
            Replacement for the Siemens Bakelite caps in an early 1980s SMPS
            by rewease
            There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
            Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
            Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
            09-17-2023, 12:53 AM
