My monitor instantaneously turned off when I was using it, with no symptoms before it happened. I took it apart to find a blown fuse. I replaced the fuse, plugged in the power supply, and the new fuse blew immediately. All of the capacitors on the board look perfect. What might be causing my fuse to blow?
Gateway FPD2485W 24" LCD Fuse Blown, caps the cause?
Re: Gateway FPD2485W 24" LCD Fuse Blown, caps the cause?
Originally posted by CATPartMy monitor instantaneously turned off when I was using it, with no symptoms before it happened. I took it apart to find a blown fuse. I replaced the fuse, plugged in the power supply, and the new fuse blew immediately. All of the capacitors on the board look perfect. What might be causing my fuse to blow?
A more helpful answer, probably a short in either the bridge rectifier or the power transistor.
Pictures of the front and back of the power supply will help. Read the thread in the FAQ entitled 'Inserting pictures in your posts'.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. -
Originally posted by PlainBillShort answer - a short.There are 10 kind of people in this world: those that understand binary, and those who don't.- ASUS ROG Maximus IX Code
- Intel Core i5-7600K 3.8GHz
- 16gb GSKILL TridentZ RGB DDR4-3200
- 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
- Windows 10 Pro x64
- GeForce GT1050
2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job)
Originally posted by PlainBill...probably a short in either the bridge ...There are 10 kind of people in this world: those that understand binary, and those who don't.- ASUS ROG Maximus IX Code
- GeForce GT1050
Going through the same problem with the same Gateway FPD2485W. Maybe we can kill two birds with one stone (thread). I already replaced all the caps on the power supply board (DigiKey), except the big 150uf/450V. Fuse blows immediately when power cord is plugged into the PB. Note to readers; there is no external power supply to these monitors, just a cord.
Power Board:
(All the purple caps were replaced after this picture was taken.)
As you guys mentioned, the problem is most likely a short blowing the fuse. Being a bit naive, where on this board should I check for the shortages? Rather than just "bridge rectifier or the power transistor", Can you point them out please?
I can take more pics if needed, just let me know specifically where...
Thanks for the time and help!
PS: Testing will be done with help of local electronics store tech.Last edited by RacerX; 05-10-2010, 05:29 PM.Comment
Originally posted by RacerXGoing through the same problem with the same Gateway FPD2485W. Maybe we can kill two birds with one stone (thread). I already replaced all the caps on the power supply board (DigiKey), except the big 150uf/450V. Fuse blows immediately when power cord is plugged into the PB. Note to readers; there is no external power supply to these monitors, just a cord.
Power Board:
Can you do a close up of the black "thing" at the right of the transformer?
Or can you confirm that is a black square-like component with four legs soldered to the board?
Or you can take the board to the local electronics tech. He should be able to tell you (and test) where the bridge rectifier is.There are 10 kind of people in this world: those that understand binary, and those who don't.- ASUS ROG Maximus IX Code
- GeForce GT1050
I just fixed one an hour ago. Complaint was "Flashes and dies". Powered up and lit up the bulbs for several minutes until ... (quiet snap) then dead.
Fuse open. ohmmeter showed a short across the big cap. It was the smps FET had shorted. The BIG cap esr was over 100 ohms. Replaced big cap, FET and Fuse and all is good.
MikeComment
Mike
I've been looking around the internet for weeks and still haven't found a solution. This, however seems closest to what I'm dealing with.
When I plug the cord into the power supply, theres a sound like one of the capacitors is dumping it's charge. I've replaced all the other ones BUT the big one in the middle of the board. I'm having trouble getting it OFF the board (power board) cause the glue that's holding it down, so I don't know what it's charge is to buy a proper replacement.
My theory is that either that big cap is bad or shorted, or that the fuse next to the ac-inlet is bad...
Long story short, I was wondering what capacitor you used as a replacement for the big one, and where did you get it? Also, what the other term means. FET? What is that?
Sorry, I know I'm a total n00b when it comes to this electronic stuff. I've been out of the loop for 8 years ><Comment
If you need to cap the big capacitor, use an exacto knife to cut away the glue. The glue is used at the factory to hold the components in place until it is soldered.
A FET is short for mosfet.--- begin sig file ---
--- end sig file ---Comment
I get power. After about an hour of sitting there, it'll power up and whatever video source is currently feeding it is what comes up. But the panel control on the side doesn't work. Sometimes it does, sometimes it doesn't. It's extremely temperamental. I have it working somewhat right now, but it'd be nice to be secure in knowing that i can switch sources without consequence.
Forgive me, you're going to have to talk a bit stupider for me. A lot of the terms you're using I don't know what they are, what they do, or what they look like. Or what their relevance is to my debacle....Comment
For the big caps, either take pictures and post them so that someone can identify them, or list the make/model/series (and diameter/height). Putting your location in your profile will help someone suggest a place to purchase them, or you can check the FAQ here in the forums for a list of good places to buy.Comment
EDIT: Forgot to mention -- posting pictures of your board(s) along with as much detail as possible is the fastest way to get help. It's much easier to point to a picture than it is to describe something.Comment
Ok, I'm retarded. I don't know how to post pictures on here. I've tried that attachment thingy below the reply box, but it's not working for me at all.. Any help?Comment
https://www.badcaps.net/forum/showthread.php?t=1868--- begin sig file ---
Definitely follow the link that retiredcaps provided on how to attach pics. Also keep in mind the quality of info that you give affects the quality of help you get. Using this topic as an example, you should give more specifics about what's not working... Are you getting some sort of error message?Comment
Well, my computer is retarded I suppose, since I've tried 3 different web browsers and different file extensions and it STILL won't work. Yes, the images are smaller than 2000x2000px So I'm uploading them to a third party and will link them as I go along.
I've had this monitor for well over a year now, and it's always been the same since I got it. I can get it to work, IF the video source is on and feeding it, AND if i can plug it just right. I used to have to plug the cord in the back of the monitor at certain angles and listen for a specific pattern in the electric shock to get it to turn on. Now, i've lost my patience with doing that so I let it sit there for an hour and wait for it to decide to turn on.
Afterwards, whatever video source was plugged in must stay on or the monitor wigs out. If I want to turn off the source, I.E. a computer or my Xbox, i'd first have to press the blue power button on the side touch panel, wait 10-20 seconds for the monitor to decide to turn off, THEN turn off the computer or xbox.. If i wanted it to keep working, i'd have to make sure that the computer or xbox was on beFORE i turned the monitor back on.
So that's really my main problem. It'll power up after a while, but the touch panel controls lag beyond all reason. If i press the menu button above the power button, it'll wait 40 seconds, then think i'd held it down, pulling up the product tour, rather than the main menu. Then to get it to go away, i had to wait another minute before the touch panel would respond to touch again, THEN press the "exit menu" button...
All in all, it's extremely temperamental.
Now. I've replaced all THESE capacitors in the picture below.
http://img265.*************/img265/3264/replaced.jpg
That didn't fix anything.
So here are my thoughts.
When I plug it in and listen closely, it sounds like the power shorts out somewhere ON the power board. Somewhere around HERE.
http://img195.*************/img195/6264/suspectq.jpg
So it's either this transformer:
http://img52.*************/img52/2698/transformer.jpg
This fuse:
http://img514.*************/img514/2861/fusea.jpg
Or any ONE of these things I don't know what they are.
http://img690.*************/i/redcapunkown.jpg/
http://img148.*************/i/coilsunknown.jpg/
http://img294.*************/i/blackboxunkown.jpg/
I've ordered a replacement fuse and we'll see what happens when i replace it. But other than that, I don't know what else to say. I think the problem mostly has to do with the power board, not the inverter or the processor board. Cause it's obvious the sound is coming from the power board. I've removed it from the monitor entirely and carefully plugged it in, so i know for sure there's a problem THERE.
Beyond that, I'm clueless..
Was that descriptive enough? Or do you need more?Comment
See what good/bad joints look like at
http://workmanship.nasa.gov/lib/insp...uirements.html
PS. JPEG files are limited to 2000x2000 and 1.91MB which is why your photos won't upload. Right underneath the upload button is a grid of the file types, their max size and dimensions.Last edited by retiredcaps; 08-02-2010, 10:42 PM.--- begin sig file ---
I left the images HUGE this time so you can see it up close. Sorry if that's a problem.
Top Side of Logic Board:
http://img208.*************/img208/3773/0000295.jpg
Underside of Logic Board:
http://img814.*************/img814/9801/0000297.jpg
There's no obvious signs of any damage or improperly soldered parts on either the power board OR the logic board.
I've heard tell of a component going bad on the logic board though that causes the touch panel to respond slowly. It's some kind of a timer or limiter next to where the ribbon cable plugs in.
Shown HERE:
http://img121.*************/img121/3964/logicboard.jpg
I don't remember what they're called, but if it's possible they're the problem, that'd be good to know..
Thanks again for you help...Comment
by BabbarI found a project in the electronics trash yesterday. A nice Argon SA1 audio amp with some electrical issue. Took it apart and saw that the 4A250V fuse was blown so started lifting components to find the short. Eventually got to two MOSFETs (model FTA14N50C) that are shorted and when i took them out the short was gone.
Now i didn't have any replacements of the same model of course but i found a couple with pretty similar spec i thought (K10A60D & K12A50D) and put them in. Also replaced the blown fuse with a 3.5A250V one. Checked another time for short circuit and plugged it in.... -
by drscootHP Modelnumber: 14-dh0061nb​
This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
All these 3 batteries are charging...2 Photos -
by beetle1303I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...3 Photos-
by jesteraceHi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
by whc14765Hey,
I have a Gigabyte 980TI Windforce. No shorts on the main 8 pin PCIE power connectors. The 8 phase buck converter inductors are showing 2.5ohms.
The card doesn't power up at all - no lights, no fans, nothing. I noticed that all of the 8 phase inductors are showing 0V. I couldn't find a fuse for the 8pin power connectors.
I did notice that the PCIE x16 connector 12V line has a fuse F3 (10A marked on it) which is blown. It is reading 16ohms on one end.
1st Question: Is there some logic on the board that checks the 12V on the PCIE x16 bus connector... - Loading...
