Acer 23" Video Card
  • xclusiveplayer
    • 43
    Acer 23" Video Card
    I recently open my Acer 23" monitor and noticed that that have about 5 Su'scon caps which are on the list of bad caps. What kind of replacement caps should I get for video cards? I've read from another post that polymer caps works well with video cards so I did a search on digikey and found: Will this work?
    http://search.digikey.com/scripts/Dk...D The caps are
    4x: 100UF 16V Dimension: 6mm Diameter by 11mm Height
    1x: 10UF 16V Dimension: 4mm Diameter by 11mm Height
    Please help me find high quality replacements. Any help would be appreciated thanks.
  • Wrog
    • Oct 2009
    • 472
    Re: Acer 23" Video Card
    Just a minor comment on nomenclature... video cards are what you put into your computer to provide the data signal out to the monitor. The photo you've provided is a picture of the logic board (some call it the mainboard) of the monitor itself.
    Are you having a specific problem with your monitor, or are you trying to pre-emptively avoid issues? While polymers will work, they will be more expensive than electrolytics and I don't think they are a direct rating replacement. Hopefully the resident experts can expound on this further.
    Have you also checked the power and inverter pcbs for caps to replace, or does this monitor run with an external power supply (in which case, you should check the power brick)?
    I also forgot to mention, try to use the image hosting features of this site. Not only does it ensure the picture will be available in the future, but it eliminates any popups that are NWS! (I got a popup that was blocked because it said it was "Adult content")
    • xclusiveplayer
      • 43
      Yes this is the logic board off my Acer 23" LCD. I am pre-emptively trying to replace these caps on this board to avoid further issues along the road. As most of the caps on my power supply blew out and are being replaced with Panasonic FM. I have never dealt with logic board before therefore I need help on caps that would work with logic boards. Sorry didn't know imgavenue wasn't allowed, but I clearly selected that it wasn't adult content so I'm unsure why the pop up occurred on your computer.I apologize for that.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        These will work fine:
        https://www.badcaps.net/store/produc...roducts_id=101
        and
        https://www.badcaps.net/store/produc...roducts_id=102
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • seanc
          • Nov 2008
          • 1319
          I got that popup too, please just host it on the forum, if you have to use a third party service, please use imageshack or photobucket.
          • MDOC
            EngineeringTech
            • Mar 2010
            • 146
            Got a popup, too, but my software blocked it.
            • xclusiveplayer
              • 43
              So as long as the caps are low ESR they should work? So if I use Panasonic FM or FC, they should be fine? I thought Panasonic FM & FC are only good for power supply.I uploaded image using the built in hosting of this site. Sorry the "manage attachment" button just slipped my from eyes...
              • PlainBill
                • Feb 2009
                • 7034
                Got the popup too, but my computer didn't try to block it. Silly thing thinks I'm an adult. Go figure.
                PlainBill
                • MDOC
                  EngineeringTech
                  • Mar 2010
                  • 146
                  PlainBill
                  LOL
                  If you have a router, you can install OpenDNS in seconds. It's an Internet filter. It's free.
                  Wait, let's see... I think it's probably possible to install without using a router. Yes, I'm pretty sure of that.
                  http://www.opendns.com/
                  edit: BTW, there's virtually no software to install. OpenDNS is a DNS server.
                  • seanc
                    • Nov 2008
                    • 1319
                    Works best with a static IP, does come with an updater though.
                    I use it all the time as my primary DNS server, though the only blocking features are for Phishing sites.
                    • MDOC
                      EngineeringTech
                      • Mar 2010
                      • 146
                      Not just phishing sites, any sites configurable by you. There's a list of categories.
                      • seanc
                        • Nov 2008
                        • 1319
                        Oh whoops, I wrote that incorrectly.
                        What I mean is, I've only set it up to block phishing sites - it can block a whole range of things, as you say.
