Samsung Syncmaster 245BW
Re: Samsung Syncmaster 245BW
What we have to do is balance time vs cost vs convenience when trying things. Testing the transformers was quick, cheap, and easy. Replacing all the CCFLs and wiring harnesses is slow, expensive, and difficult. Substituting known good CCFLs is easy if you have a similar monitor on hand.
I keyed on the caps because 'Sam Young' is a cheap Chinese brand in the 'replace on sight' category. If you are in the US, it would cost under $5.00 for 4 caps plus shipping from Digikey, delivery would take two days. To me that qualifies as quick, cheap, and easy. At a very rough guess, replacing the caps on the output of the 24v (inverter) supply would cost under $5 more if they were ordered at the same time. And of course, a complete recap of the power supply isn't a bad idea either. That could boost the total cost of the order to $15 - $20.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
flickering backlight on samsung LCDs usually just means bad caps.. especially if it does actually work for some time or it works after warming up..
(unless it was used (despite the flickering) for too long and it damaged other components..)
i'd say go ahead and do a full recap. that's the only way to really rule out a cap problem.Comment
okay i changed the "BIG" cap not sure if that didnt anything since i didnt test it without the back casing but it works now..but with one problem only with the back casing off. when i put it back on it goes back to flickering then going black.
EDIT:i See some ARC on the inverter area when i press down the the silver covering that goes on top of the inverterLast edited by antok86; 02-11-2011, 08:09 PM.Comment
Isn't there an clear insulator sheet that goes in between the board and
the shield cover ? I think that is shown on the left hand side of your picture.
Do you see any arcing marks on the shield in the area you added the electrical tape ?
In any case the electrical tape seems to be providing you the needed
insulation and should work for the long haul but if you were curious and want
to know exactly where the arcing spot is we will need to dig into it a little
more.Comment
It works. Can't tell you what happiness this has brought. No longer have to use my spare 20" Belinea. Many many thanks to you all, you have provided me with a fix for £2 - £3 where Samsung would have charged me £130. BTW the resistors I bought first were way too large to fit on the board so I went to some 68R 2.5W ones with long leads and they were perfect even with some dubious soldering.Comment
more.Comment
hi.
I have the same problem as a couple of people before me. I have the 5.2V standby voltage but no 24V or 5.3V.
- the 68ohm resistors are fine, fuses are fine
- no capacitors seem bulged,
- there is vcc on the F9222l and ICE3B....
- the PFC is working since there is 380V on the CP803( fattest capacitor
Ironically the F9222l was replaced and the problem remains.
I don't have an ESR meter so I cannot test capacitors. From what my father (he fixes stuff like this) can see the F9222l simply isn't oscillating.
edit: the next step is probably measuring what kind of output the f9222l gives out with an oscillator (needs to be isolated first)
Anybody has any ideas???Last edited by blblb; 02-15-2011, 12:26 PM.Comment
hi.
The vcc on the F9222.. and ICE..., are they within specs? Are they fluctuating?
Have a look at post #51 of this thread.Comment
The voltage on the ICE is within specifications but it rises from 12V to 15V and then back to 12V and it keeps doing that.
Voltage on f9222l is 18.6V (stable)
ICE voltage seems mighty strange to me... although nothing was connected to the board.Last edited by blblb; 02-15-2011, 02:31 PM.Comment
Looks like the ICE is trying to start up. Usually, on these type of controllers, you have a diode and a startup cap connected off of a tertiary winding of the main transformer that supplies the Vcc pin of the controller chip. The cap is typically 22uf-47uf. Check the diode and if it checks ok, try replacing the startup cap.Comment
Well I replaced the 22uF capacitor and the problem remained. I then hooked everything to the board except the LCD screen itself and the voltage stabilized at 15.5V, so the capacitor wasn't dead
Unfortunately I still don't have 5.3 and 24V.
The only thing I could try to replace is the NPN transistor that some people had problems with. But mine seems fine...Last edited by blblb; 02-17-2011, 12:41 PM.Comment
You will probably have to post some good focused photos of top and bottom of the entire power supply, since there's apparently a few different versions of it. Do not post inline. With that being said:
1)The ICE produces the 5V standby. Verify this by measuring across CB876 (1000uf 10V cap).
2)Without the 24V output, you cannot get the 5V, since the 5V is generated from the 24V.
3)With power off. Go to post #45 of this thread. There's a diagram of F9222L. The F9222L generates the 24V output. On the diagram, there's two mosfets, Q1 & Q2 inside the F9222. Check these mosfets for shorts.
4) The NPN transistor you mentioned. Same one as in post #51 of this thread? If yes, check it for shorts.
5) Also, check resistor RB805, 68ohms.Comment
Just wanted to let you know that I've had success repairing my monitor.
I replaced every capacitor on the board, simply because it's easy, cost be about $10 and I don't want to fix it twice. However, that didn't fix it.
I checked the three 68 ohm resistors and they were dead, even though they looked perfectly fine. I ordered three metal film 68 ohm 3 Watt (+/- 5% and 750V rating) Vishay resistors and installed them.
After reassembly the monitor turned on without any drama. YAY!
Thank you very much for documenting this so well....Comment
Hi, sorry if hijacking a thread but had read mention of flickering earlier on and wanted to clarify/ask a question please in terms of the flickering.
I have a 245B which is just over 3 years old now, I use it with DVI connection 1920x1200 on Custom Magicbright with brightness/contrast (5/50) as anything else is just too bright..
However there is a persistent background 'flicker' which you can see and I'm sure its giving me headaches... you can mostly 'forget' about it but it is there and I don't think it's helping my head! It doesn't SEEM as noticeable the brighter you go (but is there).
It's like a 'pulsing' around (I'd guess 25Hz) of the entire backlit area most noticeable on plain white) certainly not "in your face" but nevertheless its "there". Side by side with Acer AL1722 (no flicker at all).
I also notice a low frequency audible 'hum' probably around 200Hz...
Is this something that anyone has noticed/fixable?
Regards,
Keith.Comment
Whilst I may do just that out of precaution, given some of the tales earlier in the thread about blowing other components, this monitor has always had this flicker that I can recall (yes I know probably should have mentioned sooner whilst in warranty!), however I want to know if anyone else has seen it (and if it's what is being referred to earlier on in the thread).Comment
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by soopacrucialHi folks,
Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...3 Photos-
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
- Loading...
