LG L1717 Monitor cap failure
  • abstractcult
    • Jan 2014
    • 8
    Re: LG L1717 Monitor cap failure
    ah okay, i was suspecting those parts because they look different from all the board, there are alot of blue thingies but none has that glue and i thought maybe it leaked or something. Ill just see what i can think of next. thx alot for your advice and for your time ! ill try finding a multimeter
    • abstractcult
      • Jan 2014
      • 8
      i have an update regarding my monitor , i did manage to find a bad cap, a lil swelled, i replaced it with a new one, same values, and now it is turning on but its displaying only white. did i do something or whats going on ? any advice ? thx !
        Check and reseat the cable between the LCD panel and the logic board, if still problem, then check the SMD fuse on the T-CON board of the LCD panel assembly.
        • abstractcult
          • Jan 2014
          • 8
          ok first of all thank you very much for the reply, i appreaciate everyone's patience with me. I managed from a no power monitor to get to power on but only white screen. I looked on the board then and i saw some fuses. I replaced some, some i just wired. Anyway now its powering on and its showing rainbow on display. What next ?
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            Wire replacing fuses is not the way to go. The fuse is there for protection and if the wire unsolders and drops onto the circuit - finished.
            Have you got pc connected?
            If you move the LVDS cable do the lines move?
            • T-con
              • Dec 2013
              • 57
              • Taiwan
              #26
              Sadly no, i do not have a multimeter, i just moved in a new rent place. Also by foamy i mean leaked i guess. I did manage to take pics of the board, the c102 and another leaked one which says th101. i also took a pic of the whole board. im attaching them. Thx for your reply !
              I see your c204 is bulging, maybe thats where your problem is.
              • abstractcult
                • Jan 2014
                • 8
                #27
                it was indeed, i did buy a new one and replaced it. after replacing, it did power on but it was showing white only. i replaced some fused and now its showing the rainbow (attached earlier in the thread). I guess the best thing right now would be buying a multimeter and see maybe i missed some fuses, i have no other idea
                  The fuse on the T-CON Blown? It looks like the panel is damaged by short circuit.
                  • abstractcult
                    • Jan 2014
                    • 8
                    #29
                    hey guys, would this be a good setup of the multimeter to verify the continuity in the fuses ? i really wanna fix this monitor it became a goal thx !
                    • abstractcult
                      • Jan 2014
                      • 8
                      #30
                      forgot the attachment sorry
                      • ArtBazz
                        • Oct 2014
                        • France
                        #31
                        Just a quick message to say that LG L1919S is the same kind of construction as the 1717. Toughest part of the job is removing the bezel, it's very hard to pull off, don't hesitate to pull hard. I broke some of the clips with no impact on remounting.
                        I just changed one cap: 1000uF 16V. The replacement one I found has same length but much bigger diameter, just enough room for it coming in contact with a nearby heatsink. It works fine now.
                        Bad caps fixed so far: Senseo coffee machine, Samsung 226BW monitor, LG L1919S monitor, PackardBell Maestro 191W monitor
                        • nobbnobb1
                          TVs vs Computer Monitor Reliability & Failure Rate
                          by nobbnobb1
                          Anecdotally, it seems to me that TVs fail much more often than computer monitors judging from personal experience and looking at the classified where people are getting rid of broken/malfunctioning TVs all the time.
                          So I'm just wondering if this is the case? Is there something inherent in the design of monitors that makes them more reliable? I would've thought they'd be operating under more severe conditions than a TV. For a typical family, a TV may only be on for a few hours every day. Whereas a monitor could be on 8+ hours, along with countless power cycles turning on/off as power...
                          07-07-2024, 10:57 AM
                        • wattage
                          by wattage
                          Hello Badcaps Community,
                          Yesterday, 04:41 PM
                        • ant3202
                          HP 27es - LED monitor - Monitor Flashing On - Off
                          by ant3202
                          Hi Everyone
                          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                          https://www.badcaps.net/forum/troubl...lashing-on-off
                          The monitor is HP 27es LED Monitor
                          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                          The monitor will randomly blackout and display no signal and will recover again.
                          Sometimes need to power and off again to restore the display but...
                          03-20-2025, 07:30 PM
                        • Rick_1234
                          by Rick_1234
                          Good evening, gentlemen.
                          Things I tried
                          06-22-2024, 04:44 PM
                          Wise Wing F199 19'' LCD monitor - recapped
                          by momaka
                          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                          When I saw the Craigslist post, I wasn't...
                          08-24-2020, 10:58 AM
