Samsung SyncMaster 226BW
  • PadMan
    • Dec 2013
    • Sweden
    #381
    Re: Samsung SyncMaster 226BW
    Hi
    I have a Samsung 226BW whitch had the flickering backlight problem.
    After exelent advice from this forum I have now replaced the caps.
    1x 47uf 50v
    1x 330uf 25v
    2x 820uf 25v (My local distributer only hade this cap as a 35v. But it fitts, just)
    2x 680 uf 25v
    To my delight the screen worked once again.
    For a few seconds until i got the computer to send a fully light screen.
    If the computer sends a dimed screen signal all works fine. But a fully light screen cases the backlight to go out after a second or two.
    I can see the image om the screen if I use a flash light even when thou the backlight is not light.
    When the screen receives a full light signal the IP-45130A rev 0.1 board starts to make a high pitch screetching sound. It sounds like the noise comes from the power half of the board. But this is more of a gues then anything else.
    The equipment i have to work with is basic. A soldering iron and a multimeter, that can not mesure capasitance.
    I have replaced this far:
    caps listed above
    3A fuse as this was also blown
    2x 4511GED ICs
    I have been scouering the forum for a simuler problem.
    I have been stretching my electronics knolage wafer thin.
    And this has now become a misson to get it to work.
    So any input or suggestions are greatly apreciated.
    Many thanks and happy christmas
    • edster
      • Nov 2013
      Originally posted by lexwalker
      Is that the supply rail that goes to the inverters? Its very common to find badcaps on this 226BW model (sometimes they do not bulge visually but measurements may tell a different story) First of all, replace all the capacitors in the secondary section. If that does not help, then start checking the feedback section (the area around the opto-isolator, including the opto-isolator itself)...
      Thank you for your reply Lexwalker,
      I have replaced the entire lot of caps on the power supply with Panasonic caps of same type. All of the large caps were bulged at the top (6 of them), the little ones weren't but I replaced them as well (3 of them).
      Yes, I measured the fluctuating voltage on the supply rail that goes to the inverter. It fluctuates 14 volts to 0 volts continuously. I would think this should be a continuous 13.5 to 14 volts but my electronic skills are not great.
      Ed
      • lexwalker
        • Feb 2011
        • 307
        • Malaysia
        #383
        What were the model/series used? I've replaced capacitors on quite a number of these monitors though mostly using Panasonic FR and Nichicon HE series. So far I have not much trouble repairing them as majority of the problems were due to badcaps...
        Does the voltage fluctuate even when the backlight is off? Problematic rectifiers (overheating ones) can cause such problems (try replacing them first). If that does not help then try changing the main filter/smoothing capacitor, that big 100uF 450V one, and test again. At the feedback section, check that "431" shunt voltage reference thingy (looks like a transistor, usually have markings such as TL431, LM431, SC431, etc) and try replacing that opto-isolator. Could also be that PWM I.C, but first check all the component around it first before pinning the source of the fault on it...
        • alternety
          • Jun 2014
          • 7
          • US
          #384
          I have been reading through the thread and have a question. I have (actually my wife has) the target 226BW.
          I have seen some references to different versions of the board. I have not seen a way to identify what is in there before hand. I would like to avoid taking the monitor apart, reassembling, ordering, disassembling and reassembling. Amongst other things it increases my chance of breaking something. If I take it apart and wait for parts I will not be fed and will have to live in an external shed. Is there information somewhere that identifies the caps based on a manufacture date or something else fairly easily found?
          As an alternative, can the caps called out at the beginning page or two of this thread be used in any version regardless of different specs in later versions? Like 8xx when a later version may have 470mf as I believe was the case in one post. I guess another way of putting this is that I want a universal cap set specification.
          • alternety
            • Jun 2014
            • 7
            • US
            #385
            I did not get a response to my post above so I went ahead and bought caps. But no 680mf. Not intended; just a mistake after dealing with Digikey's system for a while. I have attached an image of the board and the label on the back. I appears I have the earlier version with 680mf caps in C301 and C302.
            I also note that there is an empty space labeled C113 aside of C110. Some board versions have another 820mf in C113.
            I am not sure about C107. From reading this thread, I assumed there could be three different values in that position. Mine is 47mf. I got all three values to be safe. That worked.
            My questions:
            1 - Should I fill C113 if it is empty?
            2 - Can I use 820mf in C301 and C302.
            A reply soon would be appreciated. My wife will be back in a couple of ours to find her monitor is assorted pieces. It will not be pretty.
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              #386
              1 No just leave it
              2 Yes if voltage is correct and they will physically fit
              You didnt say at any point what the problem was but check small green torpedo fuse
              at F301
              • alternety
                • Jun 2014
                • 7
                • US
                #387
                It appears that C301 and C302 are simply across the supply voltage to ground. So I am guessing value is not critical. One supply leg does have a resistor between it and the main input power bus.
                C113 adds to the input bus filtering.
                • selldoor
                  Slow Learner
                  • Dec 2010
                  • 7870
                  #388
                  Did you see my post?
                  • alternety
                    • Jun 2014
                    • 7
                    • US
                    #389
                    No I did not. But I see everything now.
                    C113 goes from +13V before the inductor to gnd. Presumably that is filtering the raw 13V. The other two 820mf go between gnd and the downstream side of the inductor isolating this trace from the input trace that C113 bypasses to gnd. C113 is the only bypass cap in that isolated power input section of the board.
                    I will go with your recommendations.
                    Thanks.
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      #390
                      Ok - so how did it go?
                      • lexwalker
                        • Feb 2011
                        • 307
                        • Malaysia
                        #391
                        My questions:
                        C113 is optional, up to your choice whether to fill it or not. Its located right after a filter choke/inductor. You can fill that empty spot with any capacitor. Usually I would either use 330uF 25VDC (following the original 330uF 25VDC), or 470uF 25VDC (if I replace the other 330uF 25VDC originally on the board with 470uF 25VDC also). See attached first image...
                        For both C301 and C302, they are located near the inverter section. Usually the values for these are not that critical. You can use the original 680uF 25VDC, or something higher like 820uF 25VDC or the more common 1000uF 25VDC provided they fit in there (the capacitor height must be 20mm or less, with lead pitch of 5mm). Had plenty of these Samsung SyncMaster 226BWs that came in for repair, thus could experiment around with bigger capacitors. See attached second image...
                        • alternety
                          • Jun 2014
                          • 7
                          • US
                          #392
                          It fixed the problem. Left C113 empty. I looked at where the caps were electrically first. The 2 that are populated are on the supply after the inductor and C113 was before the inductor. I just left it alone.
                          After I got it repaired, and my wife assured me I had god like capabilities for fixing it (she is very smart; but a lit major), she told me that there were large square "pixels" on the screen sometimes. This had been going on for a long time. We had a brief discussion around "and why don't you tell me about these things?".
                          They are not a single LCD bit. The are larger. The are intermittent. Maybe 1/32" square or a bit bigger (from recollection after seeing them). And I saw them after the fix. Had I been aware of this I would have tried to isolate it to the monitor or graphics card replaced the monitor if it was in there.
                          Anyone have any idea what might be causing the squares. A large number of them scattered randomly, static when they are displayed, go away when it has warmed up. It could be a problem with the graphics card in the PC.
                          • lexwalker
                            • Feb 2011
                            • 307
                            • Malaysia
                            #393
                            Have you tried swapping monitors and see if this screen artifact also appears on a different monitor? Other than that, could be dirty LVDS connection thus try cleaning the connectors and re-seat the cable again...
                            If I recall correcrtly, C113 was after the inductor. You are looking at it from a wrong direction. The two populated ones are the main filter capacitors (both 820uF 25VDC), which is then followed by an inductor. Then after the inductor there is a 330uF 25VDC capacitor there. Usually I will also replace this one as sometimes will fail. Here is another 226BW that just came in. Symptom was having difficulty switching on. Has a different power supply board than the usual one (as shown the first image). See that smaller bulging 330uF 25VDC capacitor (as shown in the second image)? Replacing it revives the monitor. Anyway, gonna replace the rest of those awful Samwha XC capacitors (as there is a slight hint of audible hissing from the transformer)...
                            • alternety
                              • Jun 2014
                              • 7
                              • US
                              #394
                              Looks like the little guy gave up his life for the big ones. Brave cap. I think you are right about the sequence. I was viewing that connector as power in. It is not of course. What makes me suspicious that it is an output is that big AC socket at the other end of the board and all that power supply stuff around it. Duhh. Old brain, getting older.
                              I replaced all of the electrolytics. I was not going to save a buck and have to do it over again. I even got the big one. That one cost more than all the others together. But I tend to believe that if is worth doing, it is worth overdoing.
                              The little squares are not bothering her. And they go away quickly as something warms up. The only reason I am concerned is as a precursor to a bigger problem. That was why I asked if anyone else had seen these and a possible cause. Should that happen then I will swap monitors as needed. Way too much hassle to extract my monitor from my desk.
                              • lexwalker
                                • Feb 2011
                                • 307
                                • Malaysia
                                #395
                                You can find some LCD monitor power supply schematics around. And even looking at those schematics (from left-to-right), can see that small capacitor is after the inductor...
                                Well, I also replaced all the crap Samwha XC capacitors including those on the primary side, except for that big one (which looks like a Samyoung based on the sleeve and text coloration). Using Rubycon ZLH series for the 820uF 25VDC capacitors this time, as I've ran out of Panasonic FR series (already ordered new batch). See attached images. Currently putting the monitor through burn-in testing...
                                Some pictures of the problem would be useful. Otherwise you could try another PC or laptop on that monitor, if not swapping monitors...
                                • _Jay_
                                  • Aug 2014
                                  Just fixed my 216BW by replacing the caps from page 2 of this thread (post 24, 28 and 29). All the caps listed first in post 28 were available at Mouser. Thanks!!!
                                  • stavros67
                                    • Nov 2014
                                    • Greece
                                    #397
                                    Hello from Greece.
                                    I have a 226BW with IP-43130A board, 226BW-VE REV.0.0, 2007.04.18.
                                    I know what capacitors i want to replace expect the big one C105. I don't know if it is 100uF or 150uF at 450v. I am confused, could someone help me?
                                    Thank you in advance and sorry for my bad english.
                                    • selldoor
                                      Slow Learner
                                      • Dec 2010
                                      • 7870
                                      #398
                                      I believe there are different versions of the power supply some have 150uf some have 100uf. You should use the same value that you took out.
                                      It is not usual to change the BIG cap unless it is known to be bad or has signs of leakage
                                      or bulging.
                                      You need to be careful with the height of some caps on this board.
                                      Unless there is no other option do not buy off ebay or online from China.
                                      Use good make caps from a known good seller
                                      • stavros67
                                        • Nov 2014
                                        • Greece
                                        #399
                                        You mean that exist different versions of this particular board (IP-43130A, 226BW-VE REV.0.0, 2007.04.18)? Because i want to replace all the capacitors of the board and consider changing and the big one but i can't see the uF value.
                                        • selldoor
                                          Slow Learner
                                          • Dec 2010
                                          • 7870
                                          #400
                                          I dont have time to read all the thread to see which board is which I just know
                                          there is mention that 2268A has more than one. Post a picture of both sides
                                          of your cap -someone may be able to identify it.
                                          To be honest, if in doubt, I would just fit a 150uf cap.
                                          Do you think it looks bulged or leaky?
                                          • soopacrucial
                                            Samsung Syncmaster 740BF repair
                                            by soopacrucial
                                            Hi folks,
                                            I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
                                            Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
                                            10-29-2024, 02:40 PM
                                          • rattlesnake
                                            Samsung SyncMaster 955DF dim image fix
                                            by rattlesnake
                                            This display looks a bit dim but the image is otherwise fine. I already set the contrast to 100 and the brightness to 50 (more than that is counterproductive, it becomes hazy).
                                            To enable extra tuning, I have to enable the "Highlight Zone" function and stretch it to full screen. That way it looks really bright/intense and really good! I wish I could set it permanently like this, but as soon as you change the display mode/resolution or you turn the monitor off, you lose the "Highlight zone" config and you have to manuallly activate it again. Also, the manual says...
                                            08-12-2023, 07:03 PM
                                          • vincentedel
                                            Samsung SyncMaster 740n Phase Control Issue
                                            by vincentedel
                                            I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some timeβ€”like after playing a gameβ€”the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                            I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                            04-22-2025, 12:33 AM
                                          • Kyrtapy
                                            Syncmaster T220 flashing on and off
                                            by Kyrtapy
                                            Hi, my monitor started having an issue. While there is a vga or dvi cable connected to the monitor, the screen flashes on and off. If there is no cable connected, it shows the no signal warning without any issues.
                                            I tried different cables and nothing helped. I also tried using different monitor with my pc and the monitor was working normal so my computer is not the issue.
                                            Last year I replaced two of the capacitors because they were leaking and the monitor was having trouble starting up and it fixed the problem, but now, no leaking capacitors on the PCBs.
                                            12-24-2024, 12:21 PM
                                          • nh2
                                            Samsung SyncMaster 215TW buzzing / lightning in power board socket
                                            by nh2
                                            This is my first post here. I just fixed my first 2 broken displays by replacing broken capacitors (Samsung SyncMaster 226BW, and Samsung SyncMaster 213T). But I have a third one I'm unable to fix, and am eager to fix as well:
                                            My Samsung SyncMaster 215TW makes a buzzing / hissing sound when turned on.
                                            The sound is louder the brighter the monitor is, e.g. in the "Game" preset is is even louder than in a softer preset.
                                            Opening up the monitor and unplugging the small socket cables that run from the power board to the LCD, I can see a small blue...
                                            08-31-2021, 02:23 AM
