Samsung SyncMaster 226BW
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    #361
    Re: Samsung SyncMaster 226BW
    1 Possibly- have you soldering equipment a multimeter, camera and determination.
    A 22 inch is always worth trying to save but if you have no equipment the cost
    rockets.
    2 You wont get lengthy explanations from me but some members can "Wax Lyrical"
    on the relativity of capacitors.
    3 Wouldnt worry about it you will be asked what is in there- You will be doing great clear pictures for us
    4 Could be - the tests you are asked to do will verify that. Cant say until we see your fuses. ( Just google fuses and click for images and you will get the idea)
    Open it up and re read this thread so that before you post again you have some more
    idea of what is inside and what we might ask you to do. Just reading the threaf will be mind blowing but its a lot easier with a board in front of you. Some of may even make sense
    • Bjerols
      • May 2011
      #362
      Originally posted by Bjerols
      hey everyone who helped out in this thread and who own this website, I am posting this message from my now refurbished Samsung 226BW! Cost me @ $5 shipped and an hour of my time but it was well worth it... thanks for all the help!!
      Update:
      1.5 years later and the $5 fix is holding up strong. I work from home and monitor gets used at least ten hours a day (less on weekends).
      Saved at least $100 and kept this monitor out of landfill
      BIG THANKS to BadCaps Community and this thread!
      • ausheaven
        • 16
        #363
        Hello uRdoomd,
        I may be a bit late to give you some tips.
        If have have not done soldering before. Do not dispare. If you have friend who can teach you of give you a few tips that wil be good. if not and you have the required soldering equipment, solder wig or sucker then a little practice goes a long way.
        First get the solder temperature right, it must just be hot enough to melt the solder to be able to suck if off with at solder sucker or wig. If you can get hold of some old printed circuit to practice it would be best.
        Next you will need to open the the monitor. To do this search Badcap forum there are quite a number of them similar to your particular model. You should have no problem locating a manual which have exploded view of all the component.
        The most simple method of removing is to have a flat spatular or scraper. Press press it between the joint at an angle, that way when you slide it along you will find several notches.. This is where the clip usually is. if you slowly press it down with the sharp end of the spatula it will pop out don't worry if you break the first one. There are many more. Alternatively a very thin screw drive will also do the trick. Continue locating the remainder and poping them out.
        Once you open it up, remove any screw that may be on the way to access the power
        supply.(Safety Caution - MAKE SURE THAT YOU DO IT WITH THE POWER CORD REMOVED AND DISCONNECT) You will very quickly establish which are capacitors, resistor etc, if not just do a search on the net. The faulty capacitors are the one that one that bulge up. You can now put your practice to remove them. Mark each capacitors as you remove them and take done their values so that you know which one goes where when you replace them.) I recommend that you replace all of them except the big power capacitor, they usually is not the problem. If you don't know the value take them as samples to your local electronic supplier and they can match them for you. Note - ONLY elctrolytic capacitor in aluminum casing swell (buldge) - sometime they leak -FEELS oily.
        It is worth repairing it yourself - I have fixed a few to date.
        Good luck.
        • baalzamon
          • Feb 2013
          • 6
          Well my beloved Samsung Syncmaster 226BW started the dreaded light flickering. Then it started off with a very black screen and then very fast flickering gradually slowing taking about 5 minutes for the picture to stabilise. Last symptom I saw before dismantling was half the screen being brighter that the other before stabilising.
          So I cracked it open and sure enough the 820uF capacitors are bulging. I'm sourcing capacitors on au.element14.com and have got the following capacitors in my basket
          RUBYCON 25ZLH820MEFC10X20 820uF
          PANASONIC - EEUFR1E681 680uF
          RUBYCON - 25YXF330MEFC10X12.5 339uF
          PANASONIC EEUFC1H470 47uF 50V
          RUBYCON - 450TXW150MEFC18X45 150uF 450V
          I then was looking at the tracks and spotted the marks in the attachment. They are located by D104. Replace, clean it? I've got rubbing alcohol. I've got rusty soldering skills and a basic soldering iron as well. Been thinking might get a kit to test my skills out on as well.
          Figure spend a bit on caps vs spend $300 on a new decent LCD...
          • baalzamon
            • Feb 2013
            • 6
            Picture from above and showing that D104 chip as well. The legs of that don't appear too crash hot.
            Anyone replaced that before? Appears to have either glue or thermal paste on the rear of it onto the heatsink. Blulging caps are visible here as well.
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              #366
              Bottom board pic is too blurred.
              The legs of that don't appear too crash hot. ?? Aus idiom?
              It will be thermal paste - may be ok when caps are replaced - it will have been running hotter because of them - (if its not gone altogether)
              If you do decide to take it off take care to replace any electrical insulation
              tabs or collars it might have ( Depending on type it might not have any so dont worry if it has not)
              • baalzamon
                • Feb 2013
                • 6
                Ok this photo appears better
                • baalzamon
                  • Feb 2013
                  • 6
                  So could the crud on the legs be thermal paste that has run hot and melted down the legs coating them?
                  If that is the case once I have the caps on, rubbing alcohol will sort that out and maybe some new thermal paste as well.
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    #369
                    The brown on the back of the board looks like flux can be cleaned off with your alcohol. Still cant tell what is wrong with the legs - maybe just a bit of heat/oxidation - I dont think its a problem - might clean off if you want to try.
                    I would just get the new caps in then go from there.
                    • baalzamon
                      • Feb 2013
                      • 6
                      So I was on au.element14.com and got the caps I wanted in the basket and it came to $34 AU. $12.50 of that was shipping. thought to myself I wonder what badcaps charges. Just under $18 shipped.
                      Now to wait for them to arrive and I can get myself some practice on a test kit
                      • Vegcrable
                        • Mar 2013
                        • 12
                        Hi, Sorry if I make some mistake in english,
                        I'm from Canada (Province of Quebec).
                        Someone gave me a 216BW, I know it's not a 226BW but the boards in it are similar or identical to 226BW. I've replaced the caps in it, with all the good specs.
                        Here are the caps I've changed : Power Board
                        1x 2.2uF 50v
                        1x 22uF 50v
                        1x 47uF 50v
                        1x 330uF 25v
                        5x 820uF 25v
                        I didn't change the 100uF 450v, With my "caps meter" I get 94uF.
                        Someone in the threat posted the same problem that I have """
                        The problem is that there are vertical lines across the monitor. The lines are really faded (very transparent), thin, and many in number (Virtually cover most of the screen). It's easy to see them in most darker colors (grey, blue, violet), and impossible to see them in White & Black. """
                        One of this link was posted by the same person, so I reused it for exemple """ http://i54.tinypic.com/vwstht.jpg """
                        These are pics found on google image for exemple, these boards are the one that I have in my monitor """ http://www.ccl-la.com/catalog/images...k3qutrg3m123e4 """
                        Driver Board """ http://www.ledbos.com/images/Driver_...N41-00885B.jpg """
                        So how should I proceed to fix that problem, Ty all and nice Job
                        • Vegcrable
                          • Mar 2013
                          • 12
                          Ok, I found this on your forum :
                          """Hooray, I've fixed it! I was right all along - EEPROM A81SC (24C08) got corrupted (probably due to the wild voltage swings because of bad caps).
                          So shorting pins 5 and 6 while turning the monitor on, cleared it and the monitor stopped freezing!
                          tom66, thanks for the info!"""
                          I might try to do that but should I remove the short after clearing menu... ?
                          • jetadm123
                            • 2169
                            #373
                            Yes, remove the short.
                            • baalzamon
                              • Feb 2013
                              • 6
                              Took the foray into removing the bad caps off my power board and replaced with the rubycons I had gotten.
                              Quick test and YAY monitor no longer flickers at startup. I'm going to go around and replace the remainder of the original caps with the rubycons I've got.
                              • selldoor
                                Slow Learner
                                • Dec 2010
                                • 7870
                                #375
                                Great! - take care putting it al back together - we have actually had members
                                do daft things like putting it down on a screw and so on.
                                • Vegcrable
                                  • Mar 2013
                                  • 12
                                  I was going to do some soldering tonight and I found on the chip A81SC that the pin 5 have bad solder joint.
                                  • Vegcrable
                                    • Mar 2013
                                    • 12
                                    Doh! wasn't a bad solder joint ... so I tryed short pin 5 and 6 ... and now it won't turn on at all.
                                    Even if I remove the short. Maybe I did overheat the chip. But I'm still ganna try to buy an other chip soon.
                                    • edster
                                      • Nov 2013
                                      On my pS unit (226BW) , I'm measuring the output and I'm getting an on and off- on and off 14 volts. Should I be getting a steady 14 volts ? Also, the blue on/off light blinks on and off as well. What should I look for that would be causing this on/off voltage?
                                      Looking for help,
                                      Thanks Ed
                                      • lexwalker
                                        • Feb 2011
                                        • 307
                                        • Malaysia
                                        #379
                                        Is that the supply rail that goes to the inverters? Its very common to find badcaps on this 226BW model (sometimes they do not bulge visually but measurements may tell a different story) First of all, replace all the capacitors in the secondary section. If that does not help, then start checking the feedback section (the area around the opto-isolator, including the opto-isolator itself)...
                                          Yes, look for bad caps with domed top, you should also replace them as a set.
                                          http://s807.photobucket.com/user/bud...?sort=3&page=1
                                          • soopacrucial
                                            Samsung Syncmaster 740BF repair
                                            by soopacrucial
                                            Hi folks,
                                            I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
                                            Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
                                            10-29-2024, 02:40 PM
                                          • jdfnnl
                                            Syncmaster 225BW Repair
                                            by jdfnnl
                                            I am working on repairing this Syncmaster 225BW for the second time. I don't remember if the symptoms were the same, but the first repair was replacing the caps of course. This time the monitor turns on for a couple seconds then goes black, but think I can still see a faint image. The power button does not seem to work, it just stays lit. Took out the power / inverter board and the tops of the caps seem completely flat. I do not have intuition about testing with a multimeter so was thinking of just replacing a part. I read somewhere that when the screen is on without being backlit, the inverter...
                                            11-02-2025, 02:45 PM
                                          • rattlesnake
                                            Samsung SyncMaster 955DF dim image fix
                                            by rattlesnake
                                            This display looks a bit dim but the image is otherwise fine. I already set the contrast to 100 and the brightness to 50 (more than that is counterproductive, it becomes hazy).
                                            To enable extra tuning, I have to enable the "Highlight Zone" function and stretch it to full screen. That way it looks really bright/intense and really good! I wish I could set it permanently like this, but as soon as you change the display mode/resolution or you turn the monitor off, you lose the "Highlight zone" config and you have to manuallly activate it again. Also, the manual says...
                                            08-12-2023, 07:03 PM
                                          • vincentedel
                                            Samsung SyncMaster 740n Phase Control Issue
                                            by vincentedel
                                            I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                            I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                            04-22-2025, 12:33 AM
                                          • Kyrtapy
                                            Syncmaster T220 flashing on and off
                                            by Kyrtapy
                                            Hi, my monitor started having an issue. While there is a vga or dvi cable connected to the monitor, the screen flashes on and off. If there is no cable connected, it shows the no signal warning without any issues.
                                            I tried different cables and nothing helped. I also tried using different monitor with my pc and the monitor was working normal so my computer is not the issue.
                                            Last year I replaced two of the capacitors because they were leaking and the monitor was having trouble starting up and it fixed the problem, but now, no leaking capacitors on the PCBs.
                                            12-24-2024, 12:21 PM
