Samsung 2223NW - lines and broken image [pic included]
  • DeerDance
    • Jan 2019
    • 9
    • Slovakia
    • would not start at all
    • replaced six 470uF caps, three of which were bulging
    • afterwards it starts but image has colorful lines and is generally broken
    Any ideas on what to focus next?
  • R_J
    • 9551
    Re: Samsung 2223NW - lines and broken image [pic included]
    You replaced 6 caps, I see 9 caps, I also see 5 caps on the main board, start by replacing the caps C138, C103 and the one between these two next to the regulator ic's on the main baord
    • DeerDance
      • Jan 2019
      • 9
      • Slovakia
      Thank you.
      I replaced three remaining caps on the powersupply board, two were 680uF and I did not have those, so I used 1000uF instead to just check and see what it does. Then moving to the other board...
      The monitor started with very bronken changing colorful lines.
      Wanted to take photo for the forum to update, but afterwards when I power it up, it started absolutely normal - fixed.
      I guess the caps got charged and act more normal than the first cold start, will got buy 680uF tomorrow and put those there. Will see if it will be "fixed" tomorrow too.
      I also learned that pressing power button for few seconds before disassembly does not always discharge the caps and got healthy kicked few times.
      Measured voltage on the big one at around 350V. Discharged using resistor.
      I fixed few monitors before - replacing buldged caps, replacing a nano fuse, replacing a transformer. Never got kicked before so I kinda just assumed that the pressing of the power button without power did its job. Dumb me.
      Thanks for reply!
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4349
        • Italy - Milan
        This has not any sense, i guess there is a contact problem on the lvds connectors.
        • DeerDance
          • Jan 2019
          • 9
          • Slovakia
          Ok, its back with vengance, I got 680uF and put them in but still random lines
          any tips what to check next after caps change on the power board if this is how it looks?
          I am going for change of the caps on that other board now
          • R_J
            • 9551
            Caps on the main/logic board can cause this, it is usually the low voltage regulator ic's that can oscillate at high frequency when there bypass caps go bad as in almost open.
            There look like there are 3 caps near the two regulator ic's. These small caps usually look ok because they don't bulge or leak but they DO dry up.
            • DeerDance
              • Jan 2019
              • 9
              • Slovakia
              Ok, update after 1 hour of dicking with those little shits with bend legs.
              All caps on the logic board are replaced
              3x 22uF
              2x 100uF
              old ones had really high resistance, one was 22 ohm another 12 ohm
              I assume this is high considering new ones are like 0.X or 0.0X ohms
              Now, after I switched it on the first time it was still fucked.
              After switching it up second time normal image appeared,
              it is the very same behavior like with the first cap change on the power board.
              Will see, tomorow I try to run it most of the day
              • DeerDance
                • Jan 2019
                • 9
                • Slovakia
                OK, not much testing done as the moment I turned in on I noticed that theres some color/pixel issues.
                Like if pixels were 20 times larger with 8bit colors resulting in banding...
                Yesterday I did not notice, as I was just looking for the moving square telling me no signal.
                This is the bad one
                This is how it suppose to look on a good one
                Play with the control board and you pay the price.
                  09-07-2024, 05:50 AM
                • Falki
                  Colorful LCD Vertical Lines on Samsung ue55es8090
                  by Falki
                  Hello there, ive recently found an older 55inch Samsung SmartTV.
                  A similar issue has been posted as well but also with no actual response ...
                  08-12-2025, 04:19 AM
                • Rubenlily
                  Samsung QE50Q67TAU - horizontal lines
                  by Rubenlily
                  First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                  I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                  I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                  I'm no expert but I've done the tape...
                  08-16-2023, 01:12 PM
                • jeyoung12
                  Samsung QN50Q60t lines on screen
                  by jeyoung12
                  Hi all
                  I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                  My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                  This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                  It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                  So....i don't know what end of the C ribbon to work with...
                  02-26-2024, 10:38 AM
                  09-06-2024, 11:40 PM
