Benq BL3200PT with a cooked PSU.
  • Noodles
    • May 2022
    • 8
    Re: Benq BL3200PT with a cooked PSU.
    Thanks! I'll take a look at it and get back to you!
    • R_J
      • 9565
      Also check R651, it is a low value (likely under 1Ω). It is connected between the modfet source and the primary (hot) ground, if this resistor is open, the ic would have been damaged.
      • Noodles
        • May 2022
        • 8
        i checked the resistors and other components between the ic and the mosfet, but everything was working. Do you know what the problem could be?
        • R_J
          • 9565
          If the resistors etc check ok, then like I said I suspect the ic is bad.
          • the.norbulus
            • Apr 2019
            • 12
            What was interesting with my monitor was that there was a tiny inspection hole cut in the metal plate covering the circuit boards. The hole let you see whether R616 had burnt out. This resistor was between the transformer and pin 16 of the IC. I'm guessing it was there to let the technician know that the IC had failed without having to further disassemble the monitor. Maybe they don't bother when they see that. I'm just curious to know if your monitor has a similar design?
            • Noodles
              • May 2022
              • 8
              I have not had any success fixing my cooked power board, does anyone have a working power board that they are willing to sell?
              • Noodles
                • May 2022
                • 8
                By chance, do you have a spare power board that works? Mine has not worked after numerous fixes.
                • valendorn
                  • Dec 2022
                  • 3
                  • Ukraine
                  #28
                  Hi guys. I am a radio amateur, and basically I solder serviceable boards, repairs are not my element. but... I have a burned out power supply 4H.2CR02.A21
                  this is very similar to what has already been discussed in this thread, and i need your help
                  spoiled R616, R623, R620, C615, C625, Q601, IC601
                  All these parts have been replaced with new ones.
                  but after replacement, I turn it on through an incandescent lamp, and the lamp is on and does not go out
                  what else could be the problem?
                  on a large capacitor C651 120 uF 450 V, I see a short circuit, but this is most likely the transformer windings
                  • valendorn
                    • Dec 2022
                    • 3
                    • Ukraine
                    #29
                    parameters for replaced parts
                    R616 - 10k - tanning
                    R623 - 0,1 Ω - tanning
                    R620 - 15k - tanning
                    C615, C625 - 22uF 50V - seems ok but has been replaced
                    Q601 - 11N80C3 - short circuit to all pins
                    IC601 - TEA1751T - there is a hollow in the microcircuit housing, 100% died, for replacement
                    The resistor R616, R620 was tanned and the marking could not be read. But I explored a typical drawing and realized that these must be the correct resistance parameters.
                    I have tested all the other components on the board and they seem to work. But I can't figure out some one... Why is the test lamp always on? and in theory, it should go out if the board is working, right? I switched on the lamp instead of the fuse to avoid global tanning for the board, this is standard procedure...
                    and yet, if I dropped out the Q601 mosfet for a while, then the short circuit on the capacitor 120uF 450V disappears. Although mosfet it still remains serviceable, I check its RLC tester. I also checked the ESR for this capacitor 120uF 450V, and it is also normal.
                    ...and by the way, the voltage of 220 volts does not go further than the inductors, L601, L602. 220 V does not come to the BD601 diode bridge, or how can this be, all inductances are working.
                    • R_J
                      • 9565
                      Here is the a/c path from the a/c inlet to the bridge rectifier, You must have an open coil or a broken trace
                      • valendorn
                        • Dec 2022
                        • 3
                        • Ukraine
                        #31
                        I found why i gat the short circuit for the capacitor 120uF 450V, the reason - is not isolated Drain mosfet 11N80C3.
                        I give a photo of the difference between what was and what I bought, and how to solve this problem.
                        Now i get standby voltages on the low voltage side of the load board.
                        • cheeky2
                          • Dec 2012
                          • 337
                          #32
                          A friend dropped one of these round today as its faulty however I am struggling to get it open as it appears sealed up!! Are these glued together as normally I would just separate them at the corner, but appears to be no edges to unclip?
                          Help would be appreciated from someone who has had them apart before. I have taken plenty of different size monitors apart but this seems to evade me. There are 4 screws that are behind the monitor fixing plate and two on the bottom of the base plastic (all removed ok).
                          My issue I hope is with the connections to the screen as the unit powers on but the screen goes black briefly (backlights still on) and then image comes up normal and then just cycles through the same all the time.
                          • Safrilhg
                            Look for the resistor value in the BenQ G922HDAL monitor's power supply
                            by Safrilhg
                            Hello guys, I had a problem where I didn't know the value of the burnt SMD resistor in the power supply circuit of the BenQ G922HDAL monitor.
                            In one of the parts, there is a burnt SMD resistor which leads to the LD7560GS IC as shown in the picture below.
                            How to determine the appropriate SMD resistor value for this condition? Thank You...
                            11-06-2023, 12:43 PM
                          • jinu_j
                            by jinu_j
                            Hi
                            05-03-2025, 10:51 PM
                          • mikey5791
                            Need help to replace burned resistor in 350w atx psu
                            by mikey5791
                            Hi to all forum members,
                            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                            12-26-2024, 04:55 AM
                          • MidnightRoller
                            Can a resistor lose resistance after hot air?
                            by MidnightRoller
                            I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                            I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                            02-02-2022, 11:46 PM
                          • artvandalai
                            What resistor ohm will work better to repair this waterpik?
                            by artvandalai
                            The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                            01-05-2025, 04:10 PM
