Acer AL718: It Goes On And Off
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4302
    • Italy - Milan
    #61
    Re: Acer AL718: It Goes On And Off
    "The Mosfet 27G11 gives (Cold)fluctuating readings on one the right leg .625 on the left
    leg noting at all"
    I don't know how you've made the readings..
    lets imagine the item, the label on the front, heatsink in the back, legs under.. leg to the left is most of the times g, then d, then s to the right, report the radings in each combination like (+ is the red probe):
    G-D G-S D-S
    G-D G-S D-S
    Bye..
    • nick2012
      • Nov 2013
      • 40
      • NL
      #62
      It has only 3 legs ?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4302
        • Italy - Milan
        #63
        yes like all mosfets.. i repeat but you re-read my past message, there are 2 bigger heatsinks, the one smaller of them has the mosfet connected..
        • nick2012
          • Nov 2013
          • 40
          • NL
          #64
          Okay I' had the Mosfet taken out and maesurd G=open D&G=close in beeb mode.
          In Diode mode G+=0,D-,G+=.28 and G-=0,D+=0,G-0,So only the center and
          Right leg gives a' reading,hope thats understandeble else I have to make a' photo
          perhaps.
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            #65
            I dont follow it here is an easy way to present results
            Mosfets
            If you have a manual range multimeter, set it to 200 ohms (two hundred). This is for 3 pin ICs only. You can test a mosfet (Q, IC designation) "in circuit" by (power off and unplugged)
            a) black on pin 1- red on pin 2 - record ohms
            b) black on pin 1- red on pin 3 - record ohms
            c) black on pin 2- red on pin 3 - record ohms
            If any reading is less than 30 ohms you might have shorted mosfet. Remove from circuit and repeat the tests to verify.
            This test is from retiredcaps 2 seconds to black - there are a lot of useful
            tests in there the next one tells how to test the 8 leg mosfets.
            see here
            https://www.badcaps.net/forum/showthread.php?t=10419
            start at post 19
            • nick2012
              • Nov 2013
              • 40
              • NL
              #66
              Okay I'll get zero on all legs in Ohms mode,so its defect for sure,I have already removed it
              from circuit,and still read 0 ohms on all legs.
              so i got to search for a replacment part.
              • nick2012
                • Nov 2013
                • 40
                • NL
                #67
                Found a' other from the outher board with readings,
                A.Black
                B.24 Ohm
                C.36.5 Ohm
                A.13.2 Ohm
                B.Black
                C.13.2 Ohm
                And has a marking on it like ->|o|<- .
                name&type.
                LT6207
                SBF1045CT
                Maby usseble as replacment ?
                • selldoor
                  Slow Learner
                  • Dec 2010
                  • 7870
                  #68
                  I am still not sure you are understanding the instructions.
                  No answer should be Black and you should only have three readings
                  not 2 sets and if any reading is less than 30 ohms it is likely to be bad.
                  So
                  a) black probe on pin 1- red probe on pin 2 - how many ohms?
                  b) black probe on pin 1- red probe on pin 3 - how many ohms?
                  c) black probe on pin 2- red probe on pin 3 - how many ohms?
                  I have to go out now for a couple of hours.
                  • nick2012
                    • Nov 2013
                    • 40
                    • NL
                    #69
                    then it's defect ,i'll get no readings ,on none of the legs !,its dead for sure,
                    the other one hoever gives good readings.
                    Will look for replacement tomorow at the local store.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4302
                      • Italy - Milan
                      #70
                      nick i've understood you, the symbol ->.<- means it is a double diode and is not suitable..
                      report the label on the mosfet so we can help to find a replacement. Then measure all the 3 legs chip on the other heatsink like this:
                      in diode mode
                      red on central pin, black on outer pins > must read infinite
                      invert probes > must read something like 0.150 - 0.600 (sorry i don't know common values for shottkies), in any way if shows 0.00 is shorted. Test also in ohm the big resistor connected to the S leg of mosfet and each pin with each other of the 8 pin chip on the back..
                      • nick2012
                        • Nov 2013
                        • 40
                        • NL
                        #71
                        the ID of the Mosfet is 27G11 ,939030 could not find anything on internet of this type.
                        the 8 leg chip on the backside will I' later check,but i'am litle baffeld on how to do it,
                        sounds verry complicated.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4302
                          • Italy - Milan
                          #72
                          i don't even find anything with that label, you have to take one 600v 10A N channel minimum, 8 leg chip it checks like i said, in ohm low scale measure from each pin to each other and write down results...
                          • nick2012
                            • Nov 2013
                            • 40
                            • NL
                            #73
                            It's whay to complicated for me now,and trow everyting in the trashcan,thanks for
                            your time and info.
                            • selldoor
                              Slow Learner
                              • Dec 2010
                              • 7870
                              #74
                              "It's way to complicated for me now,and throw everything in the trashcan,thanks for
                              your time and info. "
                              Sorry to hear that
                              What about plan B or was it plan A.
                              I felt that was a good price and good idea but thought Davi-p had hands on experience of faulty bulbs.
                              As the main board was not connected when you "shorted" it should still be ok.
                              Originally posted by nick2012
                              its way to dificult for me,
                              As alternite I'found that it may be beter to buy a' replacment board at:
                              http://nl.aliexpress.com/item/ViewSo...944393283.html
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4302
                                • Italy - Milan
                                #75
                                Yes, what about a plan B? Since your lamps are good with much probabilities.. you can inspect the lamp ends and if you don't damage them by a error after that you order a new psu board.. (think to the green..)
                                  09-06-2024, 05:27 AM
                                  Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                  This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                  09-07-2024, 05:00 AM
                                  Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                  This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                  Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                  This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-07-2024, 04:10 AM
                                  Acer Swift SF314-511-55X6 + Pack Gold Acer 14'' Notebook 3 Specification for Upgrade or Repair
                                  This specification for the Acer Swift SF314-511-55X6 + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF314-511-55X6 + Pack Gold Acer 14'' boardview and SF314-511-55X6 + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                  09-07-2024, 03:10 AM
