ADI Microscan A707 & BenQ FP731 LCD's
  • Norm_au
    • May 2009
    • 4
    Hi All,
    I have an annoying issue with a ADI monitor I have, I turn it on it boots up then 20 to 30 seconds latter it goes black, the led is still green but no monitor, turn it of then on, same deal, I have looked at the boards in it for a dry solder or a dead diode or a rounded pot, but nothing that catches my eye, I hope I'm in the right place for this post, and let me say what an impressive forum you lot have here, going to be a great help for future situations I can see that, ( I like playing with things that stop lol )
    I also have a BenQ FP731, model Q-7T3, it just stopped one day for no reason, I thought it might be the fuse in it "T2A H250V" I took it out tonight to see if it is any good, need to get a multi meter tomorrow, any sort of a heads up with this would be greatly appreciated as well. thank you in advance and much Peace to you all.
    The best mathematical equation I have ever seen: 1 cross + 3 nails = 4 given.
    Gigabyte G31M-S2L
    Intel Pentium Dual-Core E5200 @ 2500 MHz
    Memory:4096 MB (2 x 2048 DDR2)
    2x Video:Radeon HD 2400 PRO & Radeon 9200 SE
    320 & 500 Gig sata hdds
    DVD-Rom Drive :SONY DVD-ROM
    DVD-Rom Drive :TSSTcorp CDDVDW
    Monitor Type :CMC 19AW-19"
    Monitor Type :LG - L1717S-17"
    Monitor Type :ADI Microscan A707-17"
    Operating Sys:Windows XP Home 5.01.2600 SP-3
  • EGuevarae
    • Nov 2008
    • 1336
    Re: ADI Microscan A707 & BenQ FP731 LCD's
    Welcome yo the forums. As always, pictures would help.
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • Windows 10 Pro x64
    • GeForce GT1050
    • Norm_au
      • May 2009
      • 4
      Hi eguevarae, thanks for the welcome and reply, here are some images, the ADI one, I could be wrong and no dought am, but I think the small board to the right could be my trouble, and of course there is the BenQ I replaced the fuse today I couldn't get the ceramic one so I just got the glass one, any way still only getting the green led to say it is on but black screen, I hope these pics are what you were asking for, if not please let me know. Peace
      Gigabyte G31M-S2L
      • EGuevarae
        • Nov 2008
        • 1336
        Right. The right side board is the inverter (ADI). What brand/series/rating are the two caps at the inverter's input? I fixed a similar inverter changing the caps for two Nichicons 150uf 16v. The monitor just flickered a lot, and after a while it just turned off. After the recap, no problems , and it has been working 24/7 for a month.
        As for the BenQ, you should check the 5707s, check the fuse at the inverter's section input, and resolder all the transformer's pins as a start. I can't see any bulged cap on the pics. If you post the info on them, someone will jump in with a replacement suggestion in no time.
        There's a great thread in the forum for the Q7T3/4 around. I think the credit goes to Davmax for that one.
        • GeForce GT1050
        • Norm_au
          • May 2009
          • 4
          ok, first the ADI here is all the markings from the two caps [105 degree c] temp it can go to I guess, then [M2026] [EVL] [NKcon] [56UF] [25V] I looked on the BenQ board and could find nothing even close to 5707 or F707, and are the two square box's either side of the brass coil block the fuses you talk of ?. thx for your help.
          Gigabyte G31M-S2L
          • EGuevarae
            • Nov 2008
            • 1336
            5707 is the part no. of the transistors that drive the transformers.
            Look at the picture (is a bigger/better picture of your board). Green ones are the 5707. Blue ones are something you should check too. And yellow is the picofuse you must see if it is open or not.
            • GeForce GT1050
            • Norm_au
              • May 2009
              • 4
              Hi eguevarae,Thanks for the picture and heads up on what to look for, I'm very new to all of this and appreciate your patience and your time, I will get all of the said items you shown me latter today and replace them all I got to get a result out of that lol, and do you think I should replace those two caps on the ADI board ? might as well it can't hurt right ?. Peace
              Gigabyte G31M-S2L
              • ronaldopdias
                14" MacBook LCDs - has Apple re-introduced a new serialisation type?
                by ronaldopdias
                Since about a month or two ago, we've observed a new type of 'serialisation' on the LCDs and we're just curious whether anyone has seen this
                • New LCDs straight from the factory (not programmed)- if the Mac is restarted or switched on from a cold boot, you must close the lid, then open it again (so two cycles of opening and closing the screen) in order to get display.
                • Transplant the IC onto another screen:
                  • If the model and revision match exactly then it will perform as normal
                  • If the manufacturer matches exactly BUT its a different revision, the colours are mostly in
                06-28-2025, 09:56 AM
              • seppde
                Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
                by seppde
                I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
                ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
                The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
                In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
                02-09-2024, 05:19 AM
              • AJ847.63e
                BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                by AJ847.63e
                Hi All.
                Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                09-18-2023, 06:42 PM
              • ChatBTC
                Benq EX3501R
                by ChatBTC
                Hi!
                I am new to this site, and found it via LLM ChatGPT.
                I got a BenQ Ex3501R monitor which i have had for a while now, it works pretty good until recently, it struggles to turn on, i can see the purple welcome screen is shown for a brief time before it vanish again, usually it stays on for a couple of seconds before the main computer screen is shown, but image is still kept black, before i just had to turn it off and on a few times and that would leave it on, but now it takes ever longer to stabilize the image on the screen, ocasionally i can see the computer desktop...
                01-24-2025, 08:49 PM
                BenQ JoyBook S52 S53 Laptop Schematic
                Quanta ED3...
                11-01-2024, 02:03 PM
