Replacement inverter board for HP 1940
    Re: Replacement inverter board for HP 1940
    Originally posted by dmbj
    I can swap the 2 boards from one panel to the other or mix and match the 4 board in any combination with the 2 panels and there respective ccfl's and the problems follows the inverter boards. So as far as i can tell the bulbs are good in both panels, and the lcds are both good.
    The good news is i just got an email from a free cycler that i can pick up an unknown brand 19"er that just went bad the other day for FREE and its just done the road from home.
    Hello again dmbj
    With what you said in this post I agree with you on the good CCFLs and LCD panels, so it looks like to me with help from Eguevarae that the white panel may be a fault with the 5v rail on that Inverter/P Suppy board,
    and the inverter on that board seems fine because you have B/Light
    The other Inv/PS board seems like its still your Inverter by what you have said
    So i would compare voltage outputs on both boards with M/meter to search for fault in 5v rail by comparing readings
    And search both inverters with continuity and resistance (not powered up obviously) so as to find the fault in the bad Inverter
    ( thats my suspicions ) hope it helps, with the free cycler and patience you may get 3 working monitors, Good Luck
    bob
