CCFL wire insulator breaking down
  • sixstringartist
    • May 2012
    • 18
    https://imgur.com/a/yjEmFzT
    The white spot here is where the wire insulation to the CCFLs has broken down. This monitor has a 2 second to black problem and I can see an arc for a second when powering up the monitor and the backlight is lit.
    Is this a common failure pattern? Are there any component failures that are likely to be associated with a fault like this? Can I get by with wrapping the problematic area in electrical tape?
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: CCFL wire insulator breaking down
    Not really, bad insulation, you can try.
    Follow the white rabbit.
    • petehall347
      • Jan 2015
      • 4426
      • United Kingdom
      i would spray it with insulator spray .. and separate the wires .
      • sixstringartist
        • May 2012
        • 18
        Like this stuff? https://www.amazon.com/3M-Electrical.../dp/B074T4D93R
        • R_J
          • 9535
          A couple layers of electrical tape on both wires should work fine.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            If you have a piece of 3M Hi-voltage splicing rubber tape that would work as well>
            • petehall347
              • Jan 2015
              • 4426
              • United Kingdom
              Originally posted by sixstringartist
              yes .i use a clear one .
              • vinceroger69
                • Mar 2012
                • 6714
                can you remove that one wire out of the plug? (sometimes you can use a pin and press down on a lug and pull wire out of plug) then i would use some heat shrink tubing.
                • sixstringartist
                  • May 2012
                  • 18
                  I probably could do that, Ive done similar work in the past and I have the heat shrink tubing. Is the tubing much of an insulator though? Ive always used it as a more professional looking ziptie.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    Im not 100% sure but i would add two layers on each wire if possible and i think it would work fine i would certainly try it myself if i had this issue.
                    • sixstringartist
                      • May 2012
                      • 18
                      turns out at least 3 of the CCFL bulbs are toast. Fixing the cable is the least of my problems. Buying CCFLs online seems expensive. How to people normally replace these? Ditch the monitor? Pull from a donor? Thanks all for the responses.
                        master hoarder
                        • May 2008
                        • 12170
                        • Bulgaria
                        How did you determine that 3 (or more) of the CCFLs are bad? I think that's very very unlikely. They may be getting old and starting to pull more current, but it's very unlikely all 3 will fail at once.
                        As for the wire insulation: I suggest using at least several layers of electrical tape and then heat-shrink tubing on top. Most electrical tapes, if I remember correctly, are rated around 300-600V per insulating sheet/layer. So several layers should provide plenty of insulation. The reason I like to put heat-shrink tubing on top is because I often find that electrical tape tends to unwind/undo itself or just get loose and move around. The heat-shrink tubing will keep it all in one place.
                        Last but not least, as far as replacing CCFLs: if you have a donor monitor of the same size, that should work fine. I've bought discount bulbs before from CCFL warehouse, and they weren't too expensive ($5 per bulb with $5 shipping total). But they didn't come with wires, so I had to re-use the ones from the old bulbs, which is a bit more work - especially when it comes to making sure things are well-insulated. Otherwise, the more expensive bulbs should come with all leads/wires.
                        That said, what's the brand and model of this monitor, and how important is it to you? If it's just a standard 17/19" monitor, it's probably not worth going through all the hassle of replacing the CCFLs, unless you're doing it just for learning purposes. For bigger and/or some specialty application, it may be worthwhile doing. But again, that all depends on how much you value your time and what you're trying to achieve.
                        • ttmi100x
                          HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                          by ttmi100x
                          Greetings everyone,
                          I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                          The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                          Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                          Upon closer inspection...
                          07-31-2024, 06:36 PM
                        • wnlewis
                          New wire for my RDE3340 Whirlpool electric range
                          by wnlewis
                          OK. I got the rocker switch figured out thanks to the good advice on this forum.
                          Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                          This is a Whirlpool RDE3340 electric range.
                          The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                          Where may I find parts...
                          01-08-2025, 11:21 PM
                        • emeskay
                          Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                          by emeskay
                          We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                          08-06-2024, 07:13 AM
                        • mikey5791
                          Help on Samsung Syncmaster T220 dead ccfl lamp
                          by mikey5791
                          This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                          Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                          10-18-2020, 03:17 AM
                        • technicalspecialist
                          Vintage fan repair, copper wire question
                          by technicalspecialist
                          I currently have a customer's vintage fan on the work bench to repair.
                          It uses an induction motor with 4 poles. One of the poles is open.
                          I couldn't find the break so i cut off the original wire.
                          I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                          I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                          The enamelled copper...
                          03-16-2023, 12:54 PM
