Dell 2407wpf no source picture.
  • bakke33
    • Oct 2014
    • Sweden
    I have tried to search this issue, to no avail.
    The dell 2407wpf gets a picture when I turn it on and displays the OSD.
    I can't get any source video from any of the inputs.
    I have tried with DVI,VGA,RCA,S-video.
    DVI just goes to power save, rca and svideo flashes the connection icon(like it doesn't get a sync signal).
    What I can see on the logic board is that the different inputs goes to different chipsets. That to me indicates that the fault must lie further in.
    Where they join together. Altough the OSD works.
    Anyway I haven't found schematic for the logic board only the power board.
    So I can't check where the issue might be before I begin to randomly check voltages from the input sources.
    Anyone here have a good clue what this might be and how to proceed the repair ?
    Regards B
    master hoarder
    • May 2008
    • 12175
    Re: Dell 2407wpf no source picture.
    Well, before you go poking in there trying to find out what the issue is, first rule out the simple things - that is, make sure all electrolytic capacitors on the power board and the logic board are fine. If they are not a quality Japanese brand, it's probably a good idea to pull them out of the board and test their ESR, as they can be bad without bulging at all. Bad caps can cause all sorts of random problems like this. On that note, the small capacitors filtering the linear regulators on the logic board will often go bad without any visual signs, so those are even more critical to check.
    Once we know the caps are okay, then we can go from there to try and figure out the problem (if it persists).
    • bakke33
      • Oct 2014
      • Sweden
      Ok thanks.
      I'll get back when I have exchanged/measured the esr of the caps.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • ohren
        Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
        by ohren
        I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
        I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
        The models launched in 2018 and 2019 respectively....
        09-08-2023, 05:24 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
      • Garret Matt.
        DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
        by Garret Matt.
        I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
        Thank you in advance for any assistance you can render.
        Inductor In question. Buzzes like...
        06-20-2025, 01:21 PM
