ACER GD245HQ totally dead no power
  • tbognar76
    • Jan 2021
    • Hungary
    Re: ACER GD245HQ totally dead no power
    My symptoms was the same:
    If I turned off the monitor, it no longer turned back on anyway I pressed the power button. The LED below it did not light up.
    When I pulled the cables (cord+hdmi)out of the monitor, and leaved there for 2 two days, it returned to normal state, until I tuned off the monitor again...
    I replaced the caps. But it didn't help.
    Thanks for this forum I ordered the suggested chips from
    https://es.aliexpress.com/item/4001229006335.html?spm=a2g0o.productlist.0.0.271f1fcdBjiJQ6&algo_pvid=a3ede4df-d7d6-4955-bd17-f2c0f7b66841&algo_expid=a3ede4df-d7d6-4955-bd17-f2c0f7b66841-1&btsid=2100bdcf16105485462928097e549a&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
    And I replaced the 2 suggested regulator chips. And the problem has been solved! Thank you lotas and willthrom!
    I leave some warning here:
    A very hard solder material was used + conducting bands are very tiny under the pins of the chip, and it easy to tear them.
    I used hot gun to remove the regulator chip. And I used bit more force to tighten the chip at the first chip swap. Resulting I have to rewire the connections under microscope. But I solved!
    • willthrom
      • Jan 2021
      • 15
      • spain
      It finally arrived, the chips.. but I have several issue desoldering the old ones
      I believe I am not skilled enough. I have one tiny soldering unit (60w) and I haven´t been able to take one pin.... I started with 300º but not even at 400º.. using one of those flat tiny tips.
      right now, every time there is a power outrage, the monitor stops workings for a day or two.. after that, plugin the power cord it works again.
      Will try again desoldering.. any tip?
      • willthrom
        • Jan 2021
        • 15
        • spain
        oh,, so cool, I don´t have a hot gun and I ended cutting the pins (crazy I know).
        but one of the point went off.. So I am quite screw now (not the ability or the microscope to find out where that ping is going... ;(
        • willthrom
          • Jan 2021
          • 15
          • spain
          Can someone tell me where the V5 (pin 1) is going? I see my ping 8 is off too but that one is a NC.
          All the other pins are fine (reaching the resistor and capacitors .
          Any help will be more than welcome..
          • R_J
            • 9558
            Pin 1 trace was likely connected to that feedthru next to it. Next time either use hot air station or carefully cut the pins off the ic body, then remove each pin separately.
            • willthrom
              • Jan 2021
              • 15
              • spain
              #26
              thanks for the advices.
              yes, the freedthru was there and it worked.
              Now the screen turn on (not sure if because I changed one of the chips).. but in my first try, half of the screen the image (Not Connected) is printed wrongly.
              • willthrom
                • Jan 2021
                • 15
                • spain
                #27
                This what I mean with the screen What can be wrong?
                Bad soldering for that chips?
                • willthrom
                  • Jan 2021
                  • 15
                  • spain
                  #28
                  I know by a fact it isn't the input as without it the floating "Not connected" message is only visible properly on the right side, not the left one, where it is flurry, like interference..
                  • willthrom
                    • Jan 2021
                    • 15
                    • spain
                    #29
                    Image without input..
                    What I have broken now? Any clue?
                    Thanks!!
                    • willthrom
                      • Jan 2021
                      • 15
                      • spain
                      #30
                      I fixed!
                      It seems my soldering skill are awful now after so many years and some pins where not properly soldered. I used the multimeter and track all the pics with the chips schematic and board schematic and now it is back!. Proper pic.
                      I have disconnected the cords 20 times and still turning on so I guess the new chips is doing its work... lets see next eletrict sortcut.
                      thanks guys.
                      • bob.gsm574
                        • Sep 2021
                        hello ... what this power board name plz .. i have the same problem and i wan buy new one
                        • gamecap2334
                          • May 2021
                          • France
                          #32
                          @bob I may be wrong but i think you can not just buy parts like this, your best best is to buy a used or even damaged one.
                          I just wanted to thank everyone on this thread for sharing their knowledge, thanks to i was able to repair mine. As many of you suggested the I204 and I207 could be the issue, i ordered some online and soldered the new ones in place and that feeling when you press the power button and it lights up is just like nothing else thanks again!!!
                          For those who want to attempt this and are scared about the desoldering/soldering process, i would suggest the 2 solder irons technique, that's what i used and it worked great, even with a very cheap solder iron: https://youtu.be/LL23ZJahcfY?t=454
                          I just wanted to share a picture i took from the inside for those wondering where exactly is the power supply and the electronic parts:
                          • Rigarovich
                            • Dec 2023
                            • 4
                            • Russia
                            #33
                            They are found on the main board.
                            Thanks a lot, ordered on "Ali" the chips, replaced those indicated on the scheme and it works fine now!
                            • PantherDave
                              by PantherDave
                              Hi all!
                              05-29-2024, 02:01 PM
                            • Destroyer-Br
                              [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                              by Destroyer-Br
                              I'm working on an Acer Nitro 5 unit with the following specs:
                              • Motherboard: LA-J871P Rev: 1B
                              • Model: Acer AN515-55-59MT
                              • S/N: NHQ7JAL00403906A973400
                              • SNID: 03902728734
                              Initial Issue
                              The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                              After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                              04-17-2025, 08:18 PM
                            • GLISIT
                              by GLISIT
                              01-16-2025, 02:29 PM
                            • Mike Russell
                              Lenovo 14ALC6 - NMD521 - No power, totally dead.
                              by Mike Russell
                              Machine won't power on, no power led, no fan spin, completely dead.
                              Checked PQ5400 - AONS32314 and pins 5,6,7,8 are 20v (AC adaptor voltage) but pins 1, 2, 3, 4 are 0v.
                              Following Gate Pin 4 to PU5400 - BQ24780SRUYR.
                              VCC 20v
                              ACDET 2.8v
                              ACDRV 0v (goes to pin 4 gate of AONS32314).
                              ACOK 0v
                              REGN 6v
                              According to datasheet, conditions are correct for ACOK to be high but it is not.
                              Tracing ACOK it's connected to ACIN which is connected to a pin GPB0 of IT8227 but also shown as connected to +3VL via a 100k resistor...
                              12-25-2024, 08:31 AM
