Re: GNR TS902W no power , help please
I get a reading of about 500 mV
what shall i test next, please
thanks so much for all your help in advance
Did you test the Drain-Source diode junction?
With positive (red) multimeter probe on Source and negative (black) probe on Drain, you should get a diode reading in diodes test mode - anywhere from about 400 to 800 mV, depending on other parts in the circuit. Reversing the probes should show nothing, both in and out of circuit - at least not when you keep the probes connected for more than 2-3 seconds (in order for your multimeter to bias any large caps in the circuit, so that they don't give false readings).
And when measuring the MOSFET out of the board from Gate to Source or Drain, regardless of the orientation of your multimeter probes, you should get open-circuit reading.
Additionally, you may be able to do a "basic" check of the MOSFET function when out of circuit with your multimeter by connecting the negative probe to Source and the positive probe to Gate. Then, if you remove the positive probe from Gate and touch the Drain lead with it, you should get a very low resistance/diode reading - ideally short-circuit. And if you touch the Gate lead with your finger, the MOSFET should turn off and the short-circuit between Drain and Source disappear.Leave a comment:
what is the markings on the mosfet?Leave a comment:
No resistance readings at all?Leave a comment:
i tested the transistor but get no readingsLeave a comment:
I think you might want to take a look at the components on the other side of where I marked it in the picture. It's hard to tell from the photos, but it looks as if something heated up here on the other side, probably the mosfet bolted to the heatsink.
Please let us know what resistance readings you get on that mosfet. Also, I am attaching a manual for a power board that is similar to yours, not exactly the same model but very similar...it might help.Leave a comment:
Well, it's a process of elimination. Next up, replace the start up cap. If that doesn't help, replace the output caps. There's just no telling with those CapXon and Taicon caps in there which (if any) is bad. If that doesn't work, then we go further troubleshooting from there.Last edited by momaka; 06-22-2018, 08:35 PM.Leave a comment:
ok tested diodes all ok
have not replaced the start up cap yet
what elese can cause this please
thanks
That's be the start-up cap.
2.8 Ohms ESR is a bit high, but not too terrible for a small cap. I suggest replacing it first, to see if that brings the monitor back up.
But since you say you read no voltage on it at all, then check resistors R128, R129, and R130 (they are small SMD resistors on the solder side of the board, in the area of the start-up capacitor... and to the right of that SMD PWM controller chip). Looks like they are all 560 KOhm resistors (they have "564" written on them). See if any of them is open-circuit.
Yes.
You should get a diode reading in one way (positive multimeter probe on anode and negative probe on cathode), and nothing or very very high reading when you reverse the multimeter probes. If not, take diodes out of power supply and test them again. Out of circuit, they should definitely show no reading in the reverse direction.Leave a comment:
I tested the resistors and all are ok within range
I have not replaced the start up cap yet but wanted to know
when i read the diode using diode mode what would be the approx values for both ways please
thanks
Yes.
Yes.
You should get a diode reading in one way (positive multimeter probe on anode and negative probe on cathode), and nothing or very very high reading when you reverse the multimeter probes. If not, take diodes out of power supply and test them again. Out of circuit, they should definitely show no reading in the reverse direction.Last edited by momaka; 06-20-2018, 12:18 PM.Leave a comment:
ok found the startup capacitor
, 10uf, 50v and there is no voltage on it
The esr is 2.8
That's not the start-up cap, that's your main input cap (CE106).
The start-up cap is that small one between the main transformer and primary heatsink. I can't read its board designator from the pictures, but it's usually something in the range of 4.7 to 47 uF typically and 25-50V. You will probably need to replace that cap. But before doing so, remove it from the monitor and check it on your ESR meter (and post the results here).
I see your power supply also has the original CapXon and Taicon caps, which could be another source of the problems. Might want to remove and check those on the ESR meter as well, if that small cap turns out not have failed (yet).
If those caps are not the problem, you might have a shorted output rectifier - that would be diodes D101 and D102 near the output caps. Also the TO-220 device bolted on a heatsink, again near the output caps.
And last but not least, there is a small white fuse on the bottom of the board labeled "P 260". That looks like a resettable poly-fuse, but check it with your meter anyways. Should give very low resistance (less than an Ohm or two, depending on how low your meter can measure).
Also, when you were checking the output voltages, was that with the power supply connected to the rest of the monitor boards or by itself?
I usually suggest checking LCD monitor power supplies by themselves, as many are of the "always on" -type (i.e. should be outputting at least one or more standby + main voltages).Leave a comment:
Hi
Please could you highlight the startup capacitor as i am not sure
I test all voltages on the power board on its own
The fuse is ok, i tested with continuity and it beeped
How do i test the diodes, continuity mode and same with transistors
please, sorry newbie qs
thanks
I usually suggest checking LCD monitor power supplies by themselves, as many are of the "always on" -type (i.e. should be outputting at least one or more standby + main voltages).Last edited by momaka; 06-20-2018, 10:55 AM.Leave a comment:
I tested the esr of the big startup cap and got a reading of
0.19 to 0.20Leave a comment:
Hi
Thanks for the reply
I checked the startup cap and got 324V
I did not change
It looks flat, i just checked
I checked all the voltages on the connector using the ground pin but nothing
i checked again using a screw hole, also nothingLeave a comment:
As Momaka suggested, have you changed or checked the startup cap? Can't really tell from the photos but it looks a bit bulged?
Also, when you say there are no output voltages voltages, what are you using for ground for checking? You can't use the same ground as on the hot side of the power supply (do you see the line separating both sides of the PSU) ? Use a ground on the cold side of the PSU and measure the voltages that are on the connector (they are printed on the circuit board)....do you get anything?Leave a comment:
Hi
Yes in EU-UK
240V AC
Stuck on what next to do
checked fuses and zero ohm resistors againLeave a comment:
Sorry for asking again, but can you post clear large photos of both sides of your power board, we can then help you diagnose the problem.
If you measure 324V on the big cap (be careful when measuring on the hot side of the power supply), are you in Europe?Leave a comment:
Assuming...7 Photos -
by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
Initial Issue
The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... - Loading...
