Replacement transistor for AOD417 for Benq Monitor inverter
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. I've got a Benq monitor which has a shorted transistor on its inverter section: it's the one in the first picture. It's an AOD417 P-channel MOSFET (datasheet here) and I could not find it locally so I'm curious to see what can be used as a replacement. I found the FQPF47P06 (datasheet here) which has fairly similar (if not better) specs (package aside for now) and I know the FQPF family is easier to find, so how about it ?
    Now this inverter uses 4 transistors: 2 P-channels and 2 N-channels to run the two transformers in what I believe is called push-pull configuration (feel free to correct me on this), so is it possible to get away with replacing just this one P-channel if it's no longer matched with it's N-channel "co-worker", or do they all have to have some similar characteristic ? If so, I should find a suitable N-channel match for the FQPF47P06, so I can replace the N-channel as well. Cheers.
    Wattevah...
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Re: Replacement transistor for AOD417 for Benq Monitor inverter
    Just realised I made a boo-boo: it's not a Benq monitor, it's Vortex TV....I'm sowy Not that it'd matter too much, the issue can apply to any inverter with this configuration. I recently "fixed" a Benq monitor which had a faulty CCFL and I bypassed the timing capacitor on the control IC to extend its usability just a little bit more that's why I had Benq on my mind...
    Wattevah...
    • 1supertech
      • Apr 2012
      • 384
      https://www.utsource.net/sch/AOD417
        • 31094
        utsource are not sellers, they are brokers - avoid them.
        • 1supertech
          • Apr 2012
          • 384
          I never had a problem with them they ship very fast parts are very good.
          • R_J
            • 9560
            Do you have access to Digikey? they list Romania, there Pt# is 785-1106-1-ND
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              Already ordered it from someplace else....I don't usually go through the trouble of ordering small components online since the time it takes plus the costs defeat the purpose.
              Wattevah...
