BenQ T705 — Flash MTV312MV64?
  • piernov
    • Jan 2016
    • 4435
    • France
    The monitor doesn't power on, the LED is off (not orange). Sadly, it is not a power board issue. All voltages are here (5V and 3.3V) and the LDO on the mainboard seems to be working too (2.5V).
    I'm pretty sure there is an issue with the microcontroller, an MTV312MV64. It is powered on but RST is low. Either it is dead or the firmware is corrupt.
    Does anyone know how to dump/flash this MTV312MV64?
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: BenQ T705 — Flash MTV312MV64?
    Dropping some (maybe) interesting stuff, in Russian though:
    http://**************/forum/84-23134-1
    http://monitor.net.ru/forum/postal2-...fo-436716.html
    https://www.radiodevices.ru/postal2/postal2.htm
    • piernov
      • Jan 2016
      • 4435
      • France
      Turns out it was only the front panel switches which were acting up, sometimes showing a few hundred ohm to a few kohm resistance when not triggered.
      Also, RST is active high, not active low here.
      • ekozeko333
        by ekozeko333
        🧠 What I’ve Done So Far
        Flashed...
        06-21-2025, 02:48 AM
      • corrize
        Nikon D800 camera - flash don’t work and capacitor don’t charge
        by corrize
        Hello, I'm stuck in troubleshooting…
        The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
        In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
        When I press the flash button, it's detected by the system, flash icon appear on LDC display....
        10-01-2022, 10:02 AM
      • abajor
        Canon VIXIA HF S10 A read data from inernal flash memory.
        by abajor
        Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
        Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
        The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
        I think my best shot is to figure out a way to read the internal flash memory outside...
        07-20-2024, 12:04 AM
      • Ihandyrepair
        4 red flash led 65X950G boot Sony and android logo but then black
        by Ihandyrepair
        HI guys
        I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
        here is the issue
        I have Sony and android logo. but then 4 led red flash lights front of the tv
        I have 3.3v ref. 12v reg then T con 12v when I press the power on button
        but then I get black screen and 4 red flash light at the front LED
        but I get 3 led flash on the LED driver board.
        I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
        so I tried...
        07-11-2024, 01:45 AM
      • abhorsen
        Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
        by abhorsen
        Hey guys,
        Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
        Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
        Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
        07-06-2023, 10:22 AM
