Samsung 305T power board cable.
  • BringerOdeath
    • Dec 2012
    Hello everybody! I am trying to find the cable that runs from the power supply board to the daughter board that has the connectors(dvi, usb, etc). The one in my 3rd 305t(nvidia surround) melted into the socket in the powerboard on the last 3 pins which look to be the 24v lines. I have a replacement power supply, but I can't fin the cable anywhere or what part number it is to search! Its the 16 pin larger cable.
  • BringerOdeath
    • Dec 2012
    Re: Samsung 305T power board cable.
    I was able to find the part number from a german site that had a picture:
    BN96-04422A
    I was able to find one and order it. Not sure how you would be able to find a part number without a pic as there isn't one on the cable.....
    Thanks anyways, everyone!
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • Destroyer-Br
      [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
      by Destroyer-Br
      I'm working on an Acer Nitro 5 unit with the following specs:
      • Motherboard: LA-J871P Rev: 1B
      • Model: Acer AN515-55-59MT
      • S/N: NHQ7JAL00403906A973400
      • SNID: 03902728734
      Initial Issue
      The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
      After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
      04-17-2025, 08:18 PM
    • Nicktronic
      Samsung Power Supply Board BN44-00874F
      by Nicktronic
      Hey everyone,
      This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
      Anybody...
      03-17-2025, 06:20 AM
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • repair-it
      Need advice testing a samsung power supply board with scope
      by repair-it
      I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
      07-12-2025, 11:00 AM
