Dell 1905FP
  • ObsessionAudio
    • Oct 2008
    • 8
    Dell 1905FP
    recently I had replaced 3 bad caps on this monitor. Now upon powering up the display looks fine, all colors are good when its displaying the powersave logo, however when I connect it to a machine ( I have a good 60 some at my disposal) the display has a pinkish hue. Any suggestions?
  • Wizard
    • Mar 2008
    • 2296
    Re: Dell 1905FP
    Weak or no green. Are you on DVI or VGA?
    If the VGA video cable detachable, change the VGA cable.
    Does LCD have a color adjustment menu, check there.
    Cheers, Wizard
    • ObsessionAudio
      • Oct 2008
      • 8
      Re: Dell 1905FP
      It does it on both DVI and VGA, there is no color adjustment. the whole entire screen has a pink hue where i guess there should be white?
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Re: Dell 1905FP
        There are some LCD screens that only like 60Hz refresh from the video card.
        That's all you need anyway because LCD screens don't have flicker like CRT screens.
        Mann-Made Global Warming.
        - Dr Seuss
        • arneson
          • Sep 2005
          • 1267
          Re: Dell 1905FP
          The pink screened monitors were made special for women.
          Thats what the FP stands for.
          Jim
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            Re: Dell 1905FP
            do a factory reset.
            someone set a user color temp?
            settings corrupted by bad caps?
            if the no signal/check cable makes good white its got to be a color temp setting.
            • ObsessionAudio
              • Oct 2008
              • 8
              Re: Dell 1905FP
              So my monitor has went from "woman edition" to "demonic edition". My pda cam sucks but here is a pic of what it is doing. The dell menu shows up fine but everywhere that you see red it should be black. I've got about 60 pcs at my disposal and probably somewhere near 100+ VGA/DVI cables.
              [/IMG]
              • Krankshaft
                • Jan 2007
                • 2328
                Re: Dell 1905FP
                This looks like either a video board malfunction due to bad semis or a cracked solder joint or an EEPROM malfunction.
                Be sure to check the harness from the LCD to the video board and make sure that it's connected securely and none of the wires in the harness are loose or not making contact.
                • ObsessionAudio
                  • Oct 2008
                  • 8
                  Re: Dell 1905FP
                  harness is good, what gets me is that it will display its built-in menus fine but the the colors go to hell when i connect it to any machine.
                  • arneson
                    • Sep 2005
                    • 1267
                    Re: Dell 1905FP
                    The crystal control board is removeable on the glass panel if it's the LGPhilips
                    light guide screen.
                    I have that board and will send it to you for the asking.
                    I'd send the whole panel but it's deeply scratched which is why it was not fixed.
                    I just don't know if the menues are generated here. I do see seperate B G R components connecting to both ribbons by removing shield cover, 3 screws.
                    Jim
                    • Krankshaft
                      • Jan 2007
                      • 2328
                      Re: Dell 1905FP
                      In any case this is definately a logic problem it's not on the PSU.
                      Either the video board or yeah that little LCD control board mounted to the display (I forgot about that one).
                      I've seen on the new Dell LCDs the logic board and PSU are all in one.
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • Akhlz001
                        by Akhlz001
                        09-20-2025, 07:15 PM
                      • master3112
                        by master3112
                        07-29-2025, 01:55 PM
                      • F R 2568
                        Dell Latitude 5420 does not start (no post) need help to find the reason why
                        by F R 2568
                        Hello all,
                        this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                        I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                        If the laptop is only connected to the AC adapter (battery removed):
                        When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                        The power/battery...
                        01-08-2025, 05:45 AM
                      • diamon
                        Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                        by diamon
                        I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                        Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                        Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                        Pictures of these boards:
                        Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                        Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                        Dell...
                        02-28-2024, 12:51 PM
