HP monitor clicking
    Re: HP monitor clicking
    Please take the resistance reading on the B again without the CN701, and also take the DCV reading of A, B, and C.
    I wonder what the B is for, it's showing around 300 Ohms compared to A and C.
    • Joe Black
      eager to learn
      • Sep 2015
      • 173
      • southeastern europe
      Hmmmm, OK. Here goes: MEASURED WITHOUT CN701
      GND and A= 9.57 Kohm
      GND and B= 0.310 Kohm
      GND and C= 2.77 Kohm
      Voltage over suggested points with reference to suggested ground:
      A - jumps from 21 to 23V;
      B - jumps from 0 to few hundred mV;
      C - stays firm at 0.03mV
      BOTH WITH AND WITHOUT CN701 CONNECTED.
      /rant
      I'm just trying to learn here, I figure out you believe some component is shorted to ground, and we're trying to figure out if it's on main or power board, right?
      These readings I got would mean it's on power board definitely? And on the line where the B point is located?
      Or maybe I'm completely off trail.
      stay classy
        Clicking is the sign of either too much load for the power supply to handle so it goes into shutdown/restart mode.
        I do not expect 21V to be present on this 15" monitor, something is not making sense for me right now.
        I also do not expect 'C' to be in mV either but then again I need find out what are feeding A, B, and C.
        • Joe Black
          eager to learn
          • Sep 2015
          • 173
          Reading online, I found out that this could be caused by SMPS not having load and therefore being unable to start.
          But I can't find what generally should be dummy load, or any explanation of that...
          Will do more research when time allows.
          stay classy
          • Joe Black
            eager to learn
            • Sep 2015
            • 173
            Turns out that is OK, there is an SMD resistor between that rail and GND labeled 331. I circled that resistor in black.
            I did more examining on the power board, and found out this:
            The rails circled in red are shorted between them. One goes through big diode, and I traced the other to side pins of the regulator circled in blue. ( I think GND).
            However, if I desolder those two corresponding transformator legs, there is no more short between rails, but trafo legs are still shorted.
            I don't know if those trafo legs should be shorted, but my guess is NO, which would leave us with a shorted secondary.
            stay classy
              Transformer DCR will be very very low, it is normal. If the transformer was bad then you will not have any DCV on the secondary side when the main board is not connected to the power supply board.
              The part circle in blue is the Common Cathode dual diodes connected in parallel (the two outer pins are connected together), the center pin is Cathode.
              • Joe Black
                eager to learn
                • Sep 2015
                • 173
                #27
                Hmmm, I understand. Thank you very much for your time and effort, I will abandon this one and focus on others lying around.
                stay classy
                  • 31265
                  unless i missed it, you didnt replace the startup capacitor(s) yet.
                  and check all the diodes in the psu - not just the ones on a heatsink.
                  • Joe Black
                    eager to learn
                    • Sep 2015
                    • 173
                    #29
                    Checked all diodes already, but not sure on startup caps since I don't know which are those...
                    And can you guys please tell me what are those on picture...?
                    stay classy
                      https://www.badcaps.net/forum/attach...1&d=1467235478
                      Two small green sleeve electrolytics caps next to each other, one of them is C606.
                      • Joe Black
                        eager to learn
                        • Sep 2015
                        • 173
                        #31
                        Thanks again, budm. I have checked those with my ESR along with other capacitors; they tested out perfect; both capacitance and ESR rating.
                        Can you please tell me one more thing: those components I circled in red on that picture; what are they?
                        stay classy
                          • 31265
                          inductors, ferite blocks with copper wire threaded through them a few times.
                          they should look like a short on a meter.
                          • Joe Black
                            eager to learn
                            • Sep 2015
                            • 173
                            #33
                            They do, just never saw them before. Guessed they're inductors based on L markings, but thought I'd better check with you
                            stay classy
                            • Joe Black
                              eager to learn
                              • Sep 2015
                              • 173
                              #34
                              Alright, finally got the time to get back to this.
                              This short jumper (0 Ohm resistor - circled in black) had a hairline crack along it, and measured as OL. So I removed it and made a blob of solder there-monitor turns on, no clicking.
                              Now it behaves like this:
                              -Turns on, squeals a lot, flickers so badly you can't recognize the image.
                              -Eventually the BL turns off, and as BL turns off, image stabilizes nice and clean w/o BL, visible under flashlight.
                              -Sometimes it turns on w/o backlight, but squeals the same.
                              After more inspecting I noticed that I somehow managed to rip of diode circled in red, and lost it.
                              Are those zeners? Best I can do is take similar one from other board, how different do they get?
                              stay classy
                              • keepread
                                Dell monitor PSU vs Dell laptop PSU
                                by keepread
                                Hi there!
                                Someone gave me their old monitor, it's Dell S2715ht.
                                The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                10-30-2025, 04:45 PM
                              • wattage
                                AOC AG493UCX 49-inch monitor - Firmware request
                                by wattage
                                Hello Badcaps Community,
                                The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                07-13-2025, 04:41 PM
                              • ant3202
                                HP 27es - LED monitor - Monitor Flashing On - Off
                                by ant3202
                                Hi Everyone
                                Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                https://www.badcaps.net/forum/troubl...lashing-on-off
                                The monitor is HP 27es LED Monitor
                                https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                The monitor will randomly blackout and display no signal and will recover again.
                                Sometimes need to power and off again to restore the display but...
                                03-20-2025, 07:30 PM
                              • Rick_1234
                                LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                by Rick_1234
                                Good evening, gentlemen.
                                I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                Things I tried
                                - Bought a new AC adapter thinking that was the problem but the problem...
                                06-22-2024, 04:44 PM
                                Wise Wing F199 19'' LCD monitor - recapped
                                by momaka
                                Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                When I saw the Craigslist post, I wasn't...
                                08-24-2020, 10:58 AM
