AOC 2236Vw (TFT22W90PS) Blue power light flashing, no video
  • fuxxy
    • 318
    I have a AOC 2236Vw, Model TFT22W90PS
    The monitor refuses to power on. When I plug the power cord, the monitor's blue power light turns on, then after about 1 second, I hear a faint "tick", and the power light shuts off.
    I disassembled, and found "Elite" brand caps. None looked out of the ordinary, but I replaced them anyway, with Nichicon VZ series I had laying around. One cap I did NOT replace, was the orange cap labelled C920, an "Elite GP" series which I couldnt find a datasheet for a suitable replacement.
    Replacing caps had no effect.
    I also suspected the CCFL lamps may be bad, so I plugged in a couple of spares out of a Dell monitor.
    Replacing CCFL lamps had no effect
    At this point I'm chasing my tail, I don't know what else to look for. The board is heat-checked around the inverter transformer, but I see no other signs of damage.
    This looks like a very common design power supply, and the logic board looks identical to ones out of many threads I've read.
    Any suggestions to what I should look for next?
  • fuxxy
    • 318
    Re: AOC 2236Vw (TFT22W90PS) Blue power light flashing, no video
    AOC 2236Vw Service Manual
    Last edited by fuxxy; 05-10-2016, 05:49 PM. Reason: Correct revision manual, with updated Power Supply schematic
    • fuxxy
      • 318
      I get a solid 5.17VDC from the 8 pin connector on the power supply, even wen the blue power light is off
      Aside from +5VDC and GND, the other wires are labelled MUTE, VOL, ON/OFF, and DIM. I don't know if those will be useful for testing
      • fuxxy
        • 318
        I've been reading another post with a similar issue on a similar design here- https://www.badcaps.net/forum/showthread.php?t=50657
        In that thread, the OP mentions he shocked himself on one of the heatsinks. It looks like a double-schottkey - in my power supply I think the matching heatsink is HS1, with Q901 attached. I made the same measurement as he did from one of the GND pins to the heatsink HS1, and I get -78VDC. I don't know what this means, but it seems similar.
        • fuxxy
          • 318
          Q805 & Q806 Resistance check (Source-to-Drain)
          Q805
          Pin 1 to common drain = short, 0 ohms
          Pin 3 to common drain = short, 0 ohms
          Q806
          I'm inferring from the other thread that these shorts would overload the power supply. Are these components the cause?
          • fuxxy
            • 318
            well, it appears that the shorted mosfets are no longer shorted once I removed them from the circuit.
            • fuxxy
              • 318
              Removed backlight driver FETs Q805 & Q806
              Power supply starts up, steady 5V and steady 16V output. (no backlights, obviously. Image is displayed on screen when lit with flashlight)
              • fuxxy
                • 318
                Reinstalled FETs Q805 & Q806.
                Installed a 4.7Kohm resistor between backlight driver IC801 "timer" pin 12 and GND to disable shutdown. Original symptoms persist. Backlights flick momentarily before PSU shuts down.
                • fuxxy
                  • 318
                  Removed 4.7K ohm resistor. Removed backlight IC801 completely.
                  Power supply does not start up at all. No 5V or 16V output. (5V rail provides ~3V unsteady voltage)
                    So pin 1/3 to common Drain still showing 0 Ohm on board?
                    • fuxxy
                      • 318
                      With Q805 & Q806 installed, I get
                      Q805
                      S1 to drain = 1.4 ohms
                      S2 to drain = 0, dead short.
                      Q806
                      With Q805 & Q806 removed from circuit
                      Chip Readings:
                      Q805
                      S1 to drain = Roughly 10 MegOhms, and falling
                      Q806
                      S2 to drain = DMM reads "OL", open circuit
                      Board itself:
                      Q805
                      S1 to drain = Open
                      S2 to drain = Open
                      Q806
                      S1 to drain = Open
                      S2 to drain = Open
                      (this is understandable, on this board the common drains on each FET connect only to each pin of the inverter xfmr, nothing else)
                        So both MOSFETs (Dual-MOSFET P-CH/N-CH) are shorted out!
                        Chip Readings:
                        Q805
                        It is bad, shorted.
                        Q806
                        It is bad, shorted out.
                        The transfomer is driven by full-bridge setup, that is why it uses 2 dual-MOSFETs (N-CH/P-CH).
                        This will cause the power supply to go into startup/shutdown cycle when the current draw is too much.
                        • fuxxy
                          • 318
                          Would anything else on the board cause the shorted MOSFETs? Should I keep looking for a root cause, or replace the MOSFETS and call it fixed (If it works afterwards)?
                          I'll start looking for compatible replacements and return, thanks!
                            More likely the MOSFET just failed due to bad filter caps, as you can see the board around those two MOSFETs have dark color due to the heat from the MOSFETs.
                            Get the new MOSFETs and try.
                            • fuxxy
                              • 318
                              Replaced the two MOSFETs, and display works normally! Thanks for the help, budm.
                              • Elrynon
                                • Feb 2018
                                • 3
                                Hey Fuxxy,
                                I apologize for hijacking this thread but I'm a new member and it won't let me message you directly. I have this exact monitor and had to replace some caps myself. I was an idiot though and forgot to take pictures or mark how the pink/white, blue/black wires connect to the board. I know this is a long shot but do you possibly remember, have pictures, any advice? Thanks man!
                                • R_J
                                  • 9560
                                  If you mean the wires that connect the ccfl's to the power supply, it does'nt matter which one goes where. each connector goes to one lamp
                                  • Elrynon
                                    • Feb 2018
                                    • 3
                                    Yep, those are the ones I'm trying to figure out. Why would they have them different colors? Also, the service manual says the pink wires are high voltage and the blue wires are low voltage. Wouldn't that make a difference? Just to make sure I'm not misunderstanding you these are the wires/connections I'm talking about. (These aren't mine, just ones I found on the internet)
                                    http://stewartgreenhill.com/articles...orinterior.jpg
                                    https://www.electronicspoint.com/att...831-jpg.21562/
                                    https://i.warosu.org/data/g/img/0620...3272826722.jpg
                                    Thanks for the quick response so far!
                                    • R_J
                                      • 9560
                                      The plugs only go in one way, the low voltage is the thiner wire, each white plug is the same. In these pictures they have on plug with a blue and black wire and another plug with a pink and white wire, I see no difference between them but if you like connect them like the picture, blue/black; pink/white; blue/black; pink/white
                                      If you search Samsung 225bw, you will see them connected with the blue plugs to the outside and the pinks toward the middle, it just does'nt matter.
                                      The manual is only concerned about which wire goes to which pin of the plug, Pin 1 is high voltage, pin 2 is the return LV. Thats if you were replacing the plugs for example
                                      • Elrynon
                                        • Feb 2018
                                        • 3
                                        Ok cool, that's what I was looking for. I knew they could only hookup one way. I just wasn't sure about the "order" they needed to go in. Sadly it doesn't matter in the end. I'm still having the same issue Fuxxy had. Black screen, blinking blue power. I wouldn't even BEGIN to know how to desolder/solder a mosfet. lol I appreciate everyone's input!
