DELL U2311H 2 second issue but works after some try´s
  • schnub
    • Feb 2016
    • 8
    First of all please excuse my bad grammar
    One of my DELL U2311H got the following issue:
    Push the on button and the screen turns on and shows an image. After a few seconds it turns black and only the blue Power LED is on.
    That´s the "2 seconds to black" issue i guess.
    But the miracle is that when i try switching on and off a few times, the monitor switches on and the display flickers for a short time (10 seconds or so) and then the monitor works fine till i switch it off.
    maybe thats an indecator for this and that to be defect?
    could it be bad caps or inverter?
    i didn´t open the monitor yet to look for bad caps.
    regards schnub
    master hoarder
    • May 2008
    • 12170
    Re: DELL U2311H 2 second issue but works after some try´s
    Open it, take pictures, and post them here.
    It is more likely a capacitor issue since you can eventually make the monitor work when it warms up. But we will see with the pictures, of course.
    • schnub
      • Feb 2016
      • 8
      ok :P then i´ll strip down the monitor to show some pix
      • schnub
        • Feb 2016
        • 8
        So finally i made some pictures
        please klick *here*
        hope pictures say more than 1000 words.
        i didn´t saw any blown cap´s from my pov all looks fine. but i think also a cap could be altered and not fully working.
        i wrote down the specs of every cap i found so maybe i replace every cap that´s on there. do i need DC caps or normal ones?
        shouldn´t be that hard to solder?
        do ya think the power board is the one that failes or the logic board?
        best regards
        schnub
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          (Not so) Elite, and lelon= change em. "FDAI" on the signal board- change them too.
          Nothing on the power board has failed, yet; just those craps are making it act up.
          "pokemon go... to hell!"
          EOL it...
          All style and no substance.
          guilty,guilty,guilty,guilty!
          guilty of being cheap-made!
            master hoarder
            • May 2008
            • 12170
            Yup, those Elite and Lelon caps could be up to no good without showing any signs of it at all.
            My suggestion is to replace all of the electrolytic capacitors on the power supply board (except for the big Elite 450V cap - those high voltage caps on the input rarely fail when there is no APFC, which there isn't on your power board). Also make sure to replace the two small caps too - I'm taking about C613 and the other small cap directly below it. One of these could be the PSU start-up caps, which is rather important.
            As for the logic board - generally the caps on it rarely cause an issue, even if they are of an inferior brand. But changing them is never a bad idea. Plus, if you are already ordering caps for the power board and paying shipping, ordering a few more small caps will not cost you that much more.
            • kaboom
              "Oh, Grouchy!"
              • Jan 2011
              • 2507
              I'll add to this- I should've mentioned this in my above post. Sometimes, the heavy ground planes in those logic boards is too much for underpowered soldering irons. What works well for soldering the power board may be borderline on the logic/signal board. But it won't hurt to list/order new caps for it, even if just recapping the power board for the time being.
              Those black/gold lelons look really cheep- almost like low-end, worse than usual (ha!) OSTs. Without the "dimpled" vent stamp, of course. Those are quite likely (beyond?) junk.
              EOL it...
              • schnub
                • Feb 2016
                • 8
                First, thanks for the answers!
                Nice to know that DELL uses those cheap caps
                I will order all caps except the big one and re-solder all of them
                Panasonic caps should be fine?
                i´ll keep you guys informed if it worked. this weekend i should get this done.
                  master hoarder
                  • May 2008
                  • 12170
                  If you get FC, FK, FR, and FM series - YES. Here is a bigger list of caps that are generally suitable for power supplies and monitors:
                  Manufacturer................................Series
                  Nichicon ................................ PW, PM, PS, PJ, PV, HE, HD, HW
                  United Chemicon (UCC) ............ KY, KYA, KYB, KZE, LXV, LXY, LXZ, KZH, KZM
                  Panasonic .............................. FC, FK, HFQ (old stock only), FR, FM
                  Samxon ................................. RS
                  Rubycon ................................ YXJ, YXG, ZL, ZLJ, ZLK
                  • schnub
                    • Feb 2016
                    • 8
                    i got the FC Series of Panasonic should arrive here tomorrow.
                    i also got a heatable desoldering pump which should make things pretty easy i didn´t think that it would be hard without but im kinda lazy guy ^^ and the pump wasn´t that pricy.
                    i´ll let you know on the weekend if it worked or not
                    • schnub
                      • Feb 2016
                      • 8
                      so... soldering done, changed all the caps from the power supply except the big one. all solderings are good, contact wise.
                      but... no change
                      maybe it needs less on and off switch cycles to turn the monitor finally on, but that´s not a big change didn´t try that so often.
                      maybe is the backlight flickering (bright, a little bit darker, bright and so on, for about 10secs) after the monitor finally stay on the issue?
                      or should i change the caps on the logic board too?
                        It sounds like you need test lamps to narrow down the problem:
                        https://www.badcaps.net/forum/showthread.php?t=19987
                          master hoarder
                          • May 2008
                          • 12170
                          but... no change
                          Yes, change them first.
                          It could indeed be the lamps, as budm suggested. But it could also be those small caps on the video/logic board, which is why I suggested you get replacements for those as well. Some monitors (like the Hanns-G HG281D) are notorious for this issue.
                          If that doesn't work, then at least we know all cap-related (potential) problems should be eliminated and what you have left is likely either an inverter or lamp issue.
                          • schnub
                            • Feb 2016
                            • 8
                            hi guy´s
                            today i totally messed up the monitor
                            at least i know the "solution" or the error.
                            i had turned down the brightness to 60 or so and the monitor stays on every time. that worked for 3 days or so.
                            now i wanted to check if its the case at 100% brightness and yip 3 seconds to black and doesnt stay on.
                            i tryd to reset with holding 5 seconds the power button with everything unplugged but no change.
                            maybe its the inverter transformer ?
                              • 30965
                              more like worn tubes.
                                Worn out lamps.
                                  • 30965
                                  lamps or led kit.
                                  http://stores.ebay.com/lcd-led-parts
                                  • rounin
                                    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                    by rounin
                                    I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                    🛠 Original Issue
                                    The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                    04-19-2025, 01:18 AM
                                  • SuperJames
                                    Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                                    by SuperJames
                                    This one's a weird one, and still unsolved despite it having gone back to Dell once.
                                    Specs
                                    i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                                    Backstory
                                    I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                                    10-23-2023, 04:09 PM
                                  • Bowline
                                    by Bowline
                                    06-11-2025, 10:13 AM
                                  • computerbacon79
                                    Dell Inspiron 3480 All in One corrupt Bios issue: reaches Dell logo and stops
                                    by computerbacon79
                                    The Dell Inspiron 3480 I own (the all in one, not the laptop) is not wanting to turn on at all. It goes right to a dell logo, but it stays there forever with no other information on the screen. Holding the automatic Bios repair key combo (ctrl+esc) that should let it read a recovery file off a USB drive gets stuck on a black screen and does nothing. No amount of resetting anything so far has worked, and Dell's own support downloads have not really helped. Ive tried another BIN file I found online using my CH341A, and this got me slightly more, that time it displayed a loading bar that never moved...
                                    05-06-2025, 06:43 PM
                                  • Ven
                                    Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
                                    by Ven
                                    Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
                                    Issue Description:
                                    1. CPU Overheating to 100°C
                                      • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
                                      • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
                                      • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
                                      • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
                                      • Thermal
                                    02-12-2025, 03:57 PM
