Dell 3008wfp - messed up grey screen, only backlight
  • guppy78
    • Feb 2016
    • canada
    Good Day All,
    This is where I'm at...
    My much loved Dell 3008wfp turned on me and went funny as you can see above.
    1) We replaced the usual diodes, no difference
    2) replaced the whole power board, no difference
    3) checked all internal connections and resoldered one point (circled in pic)
    kinda at a loss here - any suggestions are greatly appreciated
    high-res pix of boards here
    https://www.dropbox.com/sh/4zylqksun...H_G1BMz6a?dl=0
    master hoarder
    • May 2008
    • 12175
    Re: Dell 3008wfp - messed up grey screen, only backlight
    Problem could be on the main board, the t-con board, or the LCD panel itself (bad tab-bonds).
    First check all regulator output voltage on the main board. That would be anything with a "1117" and "1084" written on it. I see quite a few.
    Post some pictures of the t-con board as well (this is the board that is *usually* attached to the LCD panel on the top side).
    Which diodes would that be? And which board?
    Again, which board and which picture would that be on?
    You can help us help you by being more specific.
    • guppy78
      • Feb 2016
      • canada
      Good Day and Much thanks for the feedback.
      We replaced the D22 diode as per
      http://forums.overclockers.co.uk/sho...php?t=18460501
      That did not work, so we replaced the full Power Supply board from one off ebay (China, remanufactured, from a respected buyer)
      If you check the dropbox link (bigger pix)
      The Last picture (IMGL5911) shows the one solder point we redid
      Again huge huge thanks for the reply - I liked the monitor a lot and would rather try a couple hours of repairs before giving in.
      When it went, it was all of a sudden. There were no glitches leading up to the failure.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Looks to me like the Lcd panel has failed IMO seen plenty of Tv's with symptoms issues and the Lcd drivers had failed.
        • HTR-Informatique
          Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
          by HTR-Informatique
          YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
          I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
          On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
          I also changed the screen because the PC fell and the screen was broken.
          I changed the battery with a new and original battery.
          I also had corrosion/oxidation on the...
          02-09-2025, 06:51 AM
        • Swedishpower
          Dell G3 15 3500 black screen
          by Swedishpower
          Hello
          I have search everywhere for a solution for my problem, but cant find it anywhere.
          When I was away to trow some garbage i always look in the electronic bin.
          and this time i find a laptop.
          Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
          the lamp for charmig is white.
          Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
          but no Dell logo.
          I tryed with a hdmi cable to another screen, still black.
          I started to search solution and tryed...
          07-06-2025, 06:18 AM
        • jake-b
          dell e6540 boots to black screen (no dell logo)
          by jake-b
          good morning all,
          i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
          01-08-2024, 10:29 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • hcinne
          Dell G15 ryzen edition black screen 2 amber 1 white
          by hcinne
          I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
          07-23-2024, 07:56 AM
