Dell 2408 power problem
  • cacvn
    • Dec 2015
    • vn
    Hi everybody,
    I have a Dell 2408 with this problem: everytime when I turn on the monitor, the power led doesn't go on. I have to unplug the power cord and then pluggin, and repeat 3 or 4 time, after that the monitor works well. But after not use about half an hour, the same thing happened.
    I changed two caps 47mf/50v and the IC KA431 from another power supply board of a Dell 2047 (This Dell 2407 is working, only one thing that I cannot access the menu).
    Can anyone help me ? Thanks a lot.
  • gipiv
    • Nov 2009
    • 12
    • Italy
    Re: Dell 2408 power problem
    I am in very much the same situation, but I haven't changed anything yet. I tried some simple measurements and it seems D701 and D703 "seem" to be faulty, so I will try to change them .
    Have you taken any readings?
      master hoarder
      • May 2008
      • 12175
      I suggest you post pictures of YOUR board so we can suggest what to check.
      In general, when a switching power supply (be it from a monitor, computer, or just a stand-alone power adapter) starts only when warm, it's very likely the caps are the issue.
      • masoksian
        Dell latitude e7470 not turn on .power buton on off and Run Power problem
        by masoksian
        I am dealing with the problem of turning on and off my Dell e7470 notebook.
        The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
        The system does not turn on, there is no post.
        I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
        The problem continues in the same way.
        I tried to turn on the Fn key, nothing came to the screen....
        02-15-2025, 12:08 PM
      • Cicciotest
        DELL IPCML-CT rev a00 pOWER ON PROBLEM
        by Cicciotest
        I have a problem with this dell mini desktop, no LED lights up and there is no response from the front power button. It literally feels defunct, with no feedback whatsoever.
        IPCML-CT motherboard rev.A00
        CPU: Intel Celeron G5900T
        I tested the power supply (19.5v correctly) but to be careful I also used an alternative power supply to test, nothing. No LEDs, no power on.
        I tested the power button pins and they correctly measure 3.3V, so when I press the button or put a bridge with a wire, the pulse seems to be there correctly.
        06-06-2024, 08:48 AM
      • Mark01
        Dell Optiplex 7490 AIO - red power led after flash
        by Mark01
        Hi guys,
        This is my first post! 🚀
        I have no idea what I’m doing, but I’m learning by trial and error.
        I’m currently working on a Dell Optiplex AIO 7490—one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
        07-04-2025, 12:54 PM
      • zlr8r
        Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
        by zlr8r
        hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
        Ill try and give as much info as I can.
        Dell Inspiron 17 (7786) Laptop
        Service Tag: 5J0NHT2
        Bios: 1.9.0
        When I received this , it would only flicker on the KB backlight for a second, then off and on.
        Then it started getting weirder!
        Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
        12-12-2023, 09:31 PM
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
