Problems with Samsung 740N monitors
  • Behemot
    • 4845
    • CZ
    #301
    Re: Problems with Samsung 740N monitors
    As these have exactly the same board as 740N's, that is also the reason Search pointed me here, I would stay in this thread, thank you very much;-)
    Line is the same, 7 means 17", 9 means 19", yes?
    • pedro
      • 199
      • AUSTRALIA
      #302
      Boards are often "re-used" between models, but if your monitors were listed under their actual model# then a basic newbie search would find them, and all it would take would be a cross-ref there to the 740 thread(s).
      Friends don't let friends buy Samsung ....
      • Behemot
        • 4845
        • CZ
        #303
        Here it is again as an attachement.
        • retiredcaps
          • Apr 2010
          • 9271
          #304
          What is the pwm IC chip on the back of the board?
          --- begin sig file ---
          --- end sig file ---
          • Behemot
            • 4845
            • CZ
            #305
            I am not able to read that clearly, it looks like BIT3195(0?). However, earlier posts here talk about BIT3193.
            • retiredcaps
              • Apr 2010
              • 9271
              #306
              http://pdf1.alldatasheet.com/datashe...C/BIT3193.html
              According to datasheet, pin 7 is GND and pin 10 is VDD.
              1) See if pin 7 and pin 10 are shorted.
              2) If not, measure the DC voltage on pin 10.
              • mockingbird
                • Dec 2008
                • 5486
                #307
                Can you post a picture of the logic board please?
                • sowi
                  #308
                  I have an 740N with a IP-35155A board. After switching the screen on the backlight is on for about two seconds and then goes off. The screen itself is still displaying, i can see it with a flashlight.
                  I replaced all capacitors which didn't help. The board has both transformators in one shell instead of two separate ones. The resistance on output side between 1 and 2 is about 1kohm, between 3 and 4 about 7.5kohm. So i think the transformer is faulty. On the upperside it has printed TM-1017, on the downside SEM1852. Where can i get a drop-in replacement for this transformer? I'm in europe.
                  Thanks.
                  • jetadm123
                    • 2169
                    #309
                    Thanks.
                    TM-1017 is readily available on Ebay.
                    • indrair
                      • Mar 2012
                      • Jakarta
                      #310
                      Dear all.
                      I have 740N and totally dead, led off dan smell something burn before it's dead. Before dead my 740N can be displayed but need about 5-10 minutes. I cek, one component, i don't know what it's melt, i can identified the series because the mark is missing, anyone knows what the cmponent it's?.
                      I'm also already change the 3 cap (1000uf/16v) and 1 470uf/25v, but it's not working. and where is the 3A pico fuse found? am i must change this fuse too??
                      Thanks for help.
                      • indrair3
                        • Mar 2012
                        • Jakarta
                        #311
                        Originally posted by indrair
                        Dear all.
                        Thanks for help.
                        up..up.. help please
                        • selldoor
                          Slow Learner
                          • Dec 2010
                          • 7870
                          #312
                          Ok - you are not going to get much help by bumping a post.
                          You would get more help if you didnt post pictures in line and if the front of the board picture was the other way up so the numbers could be read.
                          A quick look through this thread doesnt show a board like this one and I have tried to find the board but failed - didnt spend a lot of time as I cant really read the model no.
                          Please state the model number and revision of the board and get a magnifing glass and post any numbers off the burnt component that you can decipher.
                          • Behemot
                            • 4845
                            • CZ
                            #313
                            This board does not look very good to say. It seems there is no fuse at all, thats usually the reas for half of the components to burn. Also thre are ordinary diodes instead of bridge rectifiers.
                            Anyway, to me, the component looks more like manual (re)soldered/changed to me. Is that some kind of dual transistor in one package?
                              @INDRAIR3:
                              Service manual:
                              http://elektrotanya.com/?q=showresul...oria=&kat2=all
                              That DUAL MOSFETs are badly burnt out, you need to look at the service manual for the P/N first. The IC (on the bottom side of the board) that drives the MOSFETs may be damaged also.
                              • selldoor
                                Slow Learner
                                • Dec 2010
                                • 7870
                                #315
                                Having enhanced your pic I think it might be one of these
                                http://ndft.com.ua/sites/default/fil...ic/stu407d.jpg
                                • Behemot
                                  • 4845
                                  • CZ
                                  #316
                                  Anyone has the board shown in my earlier post (#304)? What is the R316 value please?
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    #317
                                    @behomot
                                    Hi - have you taken it out - can you see the colours on the underside?
                                    What does it measure?
                                    Here is another board http://obrazki.elektroda.net/58_1284496626.jpg
                                    Is that Brown Grey Black Gold - 18ohms 5%
                                    Or Brown Black grey silver 1000M ohms 10%
                                    • selldoor
                                      Slow Learner
                                      • Dec 2010
                                      • 7870
                                      #318
                                      Better Idea - PM Bocca and ask him he has the same board and is working on it now.
                                      • Behemot
                                        • 4845
                                        • CZ
                                        #319
                                        I have it but the restistor is totaly burned and reads as wire :-D I have replied in the thread of his…
                                          More likely to be low Ohm (18, if those are the colors) since it will be impoosible to have high enough voltage on the board to generate enough current through 1000M ohms to burn it up.
                                            09-07-2024, 05:50 AM
                                          • vincentedel
                                            Samsung SyncMaster 740n Phase Control Issue
                                            by vincentedel
                                            I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                            I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                            04-22-2025, 12:33 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
