HP LA1905WG lcd monitor no backlight
  • shelby5041
    • Feb 2009
    • 1504
    • united states of america usa
    hi i have 4 of these monitors manuf 2011
    all 4 do not have backlight.....backlight does come on for 2 seconds but then goes off......
    you can see the image but no backlight
    i have repaired hundreds of lcd monitors 99% of the time its just bad caps but on these the caps are all good
    and its just weird they are all same model# and all have same problem
    im hoping someone can help me....i would love to find out what component is causing this issue....must be common
    thanks
  • shelby5041
    • Feb 2009
    • 1504
    Re: HP LA1905WG lcd monitor no backlight
    here is a photo of power board
      • 30978
      could be the ransformer or a bad tube.
        You can make two test lamps to test the inverter circuits.
        https://www.badcaps.net/forum/showth...er+testing+cfl
        • shelby5041
          • Feb 2009
          • 1504
          hi...thanks for replying the tubes are good i tested them a while back....im just trying to get back to this repair....have time now
          so it has to be a power supply inverter issue........
          the 1000uf cap in front of transformer to lights is good....how can i test the transformer?
          here is a pic of underside of board
            What is the P/N as printed on the inverter transformer? Did you also check those two SMD 8-pin MOSFETs that drive the inverter transformer?
            Check the two legs on the right side of the transformer as show in you bottom view of the board.
            • shelby5041
              • Feb 2009
              • 1504
              hi no i havent checked any mosfets...how do i test the 2... 8 pin mosfets? underside board
              • shelby5041
                • Feb 2009
                • 1504
                too hard to read
                darfon 80TL22t-4-dn
                not sure......
                  Get the P/N as printed on top of MOSFET and then do the search to get the spec sheet that will show the pinout, then you check the resistance between S and D pins.
                  • shelby5041
                    • Feb 2009
                    • 1504
                    ok thank you...ill try that when i can.......
                    • shelby5041
                      • Feb 2009
                      • 1504
                      part# too small cant read it.....oh well
                        OK, on the transformer, just check the resistance between the two legs on the right of the transformer.
                        http://www.ebay.com/itm/80TL22T-4-DN...-/161158475930
                        • shelby5041
                          • Feb 2009
                          • 1504
                          seems on 8pin mosfets one side has 4...d and other side 1 s and 3 g
                          ok trans has 2legs one end and 6legs other end.....check res between 2legs one end?
                          what value would be good?...and bad?
                          • shelby5041
                            • Feb 2009
                            • 1504
                            do i need to worry about main cap voltage?..board has been out of monitor for 2days
                              • 30978
                              meter it and see.
                              • shelby5041
                                • Feb 2009
                                • 1504
                                transformer 2 pin...resistance is 442 ohms on all 3boards
                                • shelby5041
                                  • Feb 2009
                                  • 1504
                                  mosfet may be APM4548A
                                  • shelby5041
                                    • Feb 2009
                                    • 1504
                                    on mosfets getting 17 m ohm s-d on all of 3boards
                                      17 m (mili) Ohms = 0.017 Ohms.
                                      Or you mean 17 M (Million) Ohms.
                                      • shelby5041
                                        • Feb 2009
                                        • 1504
                                        meter read 17M ohms
                                        • Zilicon
                                          NEWSYNC B27F165 MONITOR HAS NO BACKLIGHT. board no: JY85QS_UPH_LS_R10.3
                                          by Zilicon
                                          Greetings everyone.
                                          Please I need help with the above monitor.
                                          Below is the summary of what happened and what I have done:
                                          The monitor started by turning off 2 seconds after it was turned on. It displayed with a backlight when it turned on. However, the standby light remains on after it is turned off on its own, I have to press the power button again to turn it on, but it will go back to standby after 2 seconds.
                                          The backlight driver IC is 0b3350cp.
                                          I applied a 370k SMD resistor on the CMP pin which is pin 6, while the other...
                                          11-07-2023, 09:12 AM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • turmix
                                          AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                          by turmix
                                          Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                          The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                          At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                          During another reassembly, I made a mistake, and...
                                          01-29-2024, 03:48 AM
                                        • Chiro
                                          DIGMA PRO Art M Monitor 5K IPS 60hz only backlight
                                          by Chiro
                                          The monitor has no visible external damage and has not been dropped. Currently, the backlight is on, but no image is displayed. I have replaced the power and HDMI cables, and connected it to my laptop (the graphics card detects the monitor, but no image appears). The service menu is also unresponsive. Could anyone share insights on troubleshooting or repair options for this issue?
                                          07-06-2025, 02:21 PM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
